Help with Vizio E320-A0
  • wreese06
    • Feb 2014
    • 3
    Re: Help with Vizio E320-A0
    Where did you buy the main board?
    • Jay4065
      • Nov 2015
      Originally posted by wadehavens
      Yes. I am getting 24v to the two wires going to the panel.
      Thanks for your help!
      I have the same problem but am only getting 19V at the pins? Bad power board?
      • cheeky2
        by cheeky2
        05-25-2024, 03:27 AM
      • Dani_2024
        by Dani_2024
        10-28-2024, 05:06 PM
      • gavric
        Vizio M70-C3 Half picture is bad, main board on its last leg?
        by gavric
        Hello, i am working on Vizio M70-C3. It can hardly power on, it takes 15 power button presses or remote. Seems like eeprom problem that I seen before but all reading online says that this tv has power board or main board problem.
        When tv powers on vizio V logo shows nice on whole screen. picture 1
        When it goes into tv mode it only shows good picture on left side of screen, right is all scrabbled up. pic 2
        When i start youtube picture shows on left side fine, right is all scrambled. pic 2
        When i click video to start playing picture goes black(like when you change...
        09-02-2021, 08:55 PM
      • fharris1977
        Vizio D50u-D1 Dead: PSU or Main Board?
        by fharris1977
        Hi. Anyone who has experience with these vizio sets, which pin on this connector is the standby, the 5V pin? Trying to rule out the PSU before ordering a mainboard. I'm getting 0 Volts on all pins on this connector. Trying to jump the standby and PS ON pins to see if the PSU is functioning. Thanks in advance.
        03-12-2024, 12:22 PM
      • mrtek
        Vizio M65-C1
        by mrtek
        Hi.
        picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
        When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
        This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
        07-14-2025, 07:28 PM
