Insignia NS-LCD22-09 keypad & Remote not working
  • jstiene
    • Feb 2013
    • 148
    Hello. I have a an Insignia NS-LCD22-09 TV. When I turn it on, the input menu defaulting at "Composite" appears on the screen. I cannot use the remote to change the inputs and none of the buttons on the side of the TV work. Is there a fix for this? Maybe a reset of some kind?
    any advice is much appreciated.
    Thanks!
  • tmhobadcap
    Pioneer VSX-522-K remote control not working???
    by tmhobadcap
    I have this receiver for at least 10 years. Usually, we just use the remote for turning on/off and adjusting the volume. Recently, the remote control started not able to turn the receiver on. Later, the volume also could not be adjusted by the remote control.
    At first, I thought that it was the usual problem which can be fixed by cleaning the contacts on the switches and the pcb. I opened the remote and clean it with alcohol. The remote did work again after that. But after one day, it did not work again. I opened it again and clean with alcohol and contact cleaner. Again it worked...
    12-24-2020, 01:44 AM
  • CdDvdFlash
    DSE GE6878 possible TV receiver dying remote not working well
    by CdDvdFlash
    For this Dick Smith TV GE6878 (Thompson) I replaced the broken remote with a universal it kinda works though if its more than a few meters away sometimes the buttons register and sometimes they wont so I bought another remote from another brand and it has the same problem, I've had an old TV in the past that the sensor died completely and I replaced it to fix it could this be a similar problem? I tried looking for a service manual, spare parts for a receiver and a parts list but I couldnt find any info. can someone please help me to find the info online for a service manual or where I can buy...
    07-03-2024, 03:55 AM
  • dorfman
    Samsung LN32C350 Remote not Working
    by dorfman
    Im working on a 10 year old 32" Samsung LCD that the remote suddenly stopped working. No response from the tv and no blinking standby led. Its not the remote. I tested it on another Samsung TV and its fine. The IR sensor is on a separate board with the capacitive touch buttons. The buttons worked so I figured the main board was good and it had to be the IR receiver. I tried swapping the IR / touch board with another one. Still no response.
    I'd like to try a main board diagnosis/repair because it would be a shame to trash the TV just cause of the remote. The panel still looks...
    07-07-2021, 02:02 AM
  • cstout
    DeLonghi AC Remote only accepts 3V
    by cstout
    Hello all, I've been looking into this portable air conditioner's remote control and can't find what could be causing the problem - or possibly this remote is just terribly designed.
    The remote only works at exactly 3V - if I drop it any lower, using my bench power supply, to say, 2.9V then the remote will not flash the display and turn off. I don't have any AAA batteries that are exactly 1.5V each so I'm not sure if this remote is designed this way - to only use the freshest possible batteries, or if there's a failed component in the mix.
    I can't find any schematics...
    06-03-2024, 03:53 PM
  • MMH3
    Dell Optiplex 5050 SFF - strange behavior and service_mode jumper not working anymore
    by MMH3
    i have many 5050sff. all of them, and how i experienced over many years for all about 250 DELLs goin through my hands, are fully flashable and can be serviced in any way when the service_mode jumper is set.
    Never ever i experienced problems with that.
    Now i have one 5050sff machine, where this jumper isnt working at all.
    I do not get the normal messge that the jumper is set when booting and a short test with FPT just confirms this. Everything is locked -->> EVEN for reading !?
    The history of the machine is that i used it in my office...
    03-23-2025, 09:28 PM
