Panasonic TC-P50G25 10 blinking light failure.
  • ecdm98
    • Mar 2014
    • 3
    TV is just over 3 years old. Was going to bed and turned off TV using the power button on the TV and it made an unusual noise. Did not try to turn on tv till the morning and it gave the 10 bliking lights. I have gone through the technical guide for this series and have checked for the shorts.
    P11 - pin 1 - 1.4 kohms
    p11 - pin 4 - 13 kohms
    p35 - pin 1 - 20 kohms
    I also followed the flow chart to diagnose 10 blink failure which after checking for shorts says to disconnect SC20 and powered up tv and I still had 10 blinking lights which suggest to replace A board.
    Does this seem like the proper conclusion or am I missing anything?
    Thanks,
    Eric.
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic TC-P50G25 10 blinking light failure.
    Thanks,
    Eric.
    No, there's another Panasonic TC-P50G25 10 blink thread yesterday you can have a look at it.
    before you race off and get an A-board I would disconnect SC2 and measure the resistance across those pins at SC2.
    P11 pin 1 is Vsus and should be much greater than 1.4k, I get 1 Mohms on my Tv.
    disconnect SC2 and redo the resistance check with p11 connected to SS11.
    You could also check the transistors on the SC mounted on the heatsinks for short. Q661 is one that normally goes bang along with others.
    Bad SC is a common failure and can cause SOS 4 & 10.
    • Noobomatic
      • Feb 2014
      • 25
      • australia
      ive got a panasonic viera i picked up for cheap & repaird even cheaper, had the 10 light blinking blah blah , its the 15v rail fault i belive (dont quote me) theres a little chip on the board for the 15v rail i cant remember off hand but you remove a 1uf smd cap and then the tv should fire up again http://i1179.photobucket.com/albums/...IMG_3251-2.jpg thats a picture of what you may be looking for if you own a plasma, get some freeze spray ( i used butane) crazy i know but i blew away the flamable gas anyway that worked for me to remove the tiney capacitor and tv worked fine there is 2 of them on the power supply board, posting pics of your boards would help alot more.
        Completely different TV.... I've done a few of those and they are easily fixed but unfortunately it's not so easy on these sets.
        • ecdm98
          • Mar 2014
          • 3
          I really appreciate the help and have to make a correction from my first post were i mixed up the numbers.
          p11-pin1-(Vsus) - 200kohms+
          p11-pin4-(P15V) - 1.4kohms
          p35-pin1-(Vda) - 250kohms
          I also disconnected SC2 and measured across those pins and got 28kohms and then with SC2 disconnected.
          p11-pin1-(Vsus) - 400kohms
          I didn't have time to measure the transistors yet.
          • tw2005
            • Oct 2011
            • 6458
            To eliminate PSU & A board
            try disconnecting the 3 white ribbons at the A board, disconnect P2,P11, p35 and power up.
            Should turn on and stay on and then you can probe the voltages
            Confirmed normal results are:
            stay on for about 30seconds, after which it shuts down and gives me 4 blinks.
            Read this if not already.
            https://www.badcaps.net/forum/showthread.php?t=36183
            • tw2005
              • Oct 2011
              • 6458
              SC2 gives 300K - 2M, 28k is too low
              • NJRoadfan
                • Sep 2014
                • 15
                Bumping this thread,
                I have a TC-P50G25 (US model) here with the 10 blinks code on power on.
                Using the diagnostics PDF found here, I determined the TV has a short in the P15V line (reads 15-20ohms on my meter). Following the P15V flow chart, removing the SC20 ribbon cable resolves the short (meter jumps into the k ohm range), which Panasonic indicates is a failure of the SC board.
                Testing Vsus reveals no shorts, and testing across the SC2 connector reveals no shorts as well.
                Does this definitely point to the SC board as being bad? I'm looking for some confirmation before I send the board out to be repaired as this doesn't look like the same common failure these boards tend to suffer from.
                • tw2005
                  • Oct 2011
                  • 6458
                  Ok, so you know how to use a meter. On the SC board, locate Q661, smallest heatsink 2 transistors mounted, check the RJP63F3a IGBT and see if it's shorted usually all 3 pins.
                  • tw2005
                    • Oct 2011
                    • 6458
                    Alternate to the above, TV off, disconnect, Sc2,SS11, P35, remove the 3 white flat ribbons on the A board. turn the Tv on as normal, if it strats up normally and no blink codes, A and PSU are good, Vsus at P2 could be checked (200v) and any other voltages, if the optical jack on the A board is lit red, that would mean it's running too. Only leave it on long enough to check, 30 secs or less. don't do what someone else did and leave it running , it will eventually fail and go 4 blink. manual says no more than 30 secs.
                    there will be no display, some expect to see something.
                    Don't reconnect any power cable especially p35 for 5 mins or zap and could spike panel which would be very bad and terminal
                    • tw2005
                      • Oct 2011
                      • 6458
                      Shorted 15V line at Sc20 will be a failed FET driver IC, IC521
                      What resistance did you get at SC2?
                      • NJRoadfan
                        • Sep 2014
                        • 15
                        I'll double check tonight, but I recall it was pretty high, in the mega ohm range. I have the SC board pulled out of the set already, so testing Q661 shouldn't be a problem either.
                        • tw2005
                          • Oct 2011
                          • 6458
                          Ok , well I guess I won't hang around waiting, it's 1241am here, I'll check where you're at when I get up
                          • tw2005
                            • Oct 2011
                            • 6458
                            That can happen, if it went low enough you'd have 4 blinks, have read with people at 10 then 4 maybe if the board keeps getting powered it may short it more. self repair is not impossible but I think you have rev Ap which is a little cheaper at modus but they should be the same cost.
                            Actually looks like it's AF rev. Either will work in this set
                            • NJRoadfan
                              • Sep 2014
                              • 15
                              The set definitely has the AF board. Anyone here use modus to rebuild their board? I haven't come across any reviews of this company's services.
                              • NJRoadfan
                                • Sep 2014
                                • 15
                                Resistance on SC2 tests 1.5-2 mega ohms.
                                Q661 tests as follows
                                E-G = short
                                C-G = open
                                E-C = short
                                • tw2005
                                  • Oct 2011
                                  • 6458
                                  Quite a few have and most reports are good. I think I've read of one return on a different SC board that came back still faulty. Some take the time to report it here.
                                  • tw2005
                                    • Oct 2011
                                    • 6458
                                    E-G = short
                                    C-G = open
                                    E-C = short
                                    So obviously we're talking dead short cct. Usually it goes dead short on all 3 legs but if it's dead shorts, yep it's a goner
                                    Other victims are DG402RP,DG502LW,30F125,45G128.
                                    Did you try the other test and have it turn on with no 10 blink?
                                    If you have not read and interested, over 200 posts of TNPA5081 repair
                                    https://www.badcaps.net/forum/showthread.php?t=26322
                                    • NJRoadfan
                                      • Sep 2014
                                      • 15
                                      I haven't tried the other test yet, but its a bit late here now to rip apart the TV again. As for repairing it myself, I really don't have the patience, plus my surface mount soldering skills are umm.... a bit lacking. I'm also afraid of pulling traces on this PCB, it feels like its going to break by just picking it up!
                                      • tw2005
                                        • Oct 2011
                                        • 6458
                                        Fair enough. Yeah I'd like you to try that test and check out some of those other parts to be sure but if it was a dead short 0 ohms on Q661 it's the SC.
                                        If you checked the P15V at the P board and it was short and cleared with Sc20, that would be good enough for me.
                                        I forget if you have but resistance test the Sd/Su boards before you fit a working SC board, they can fail and I've had one with shorted SC/SD/SU all together.
                                        • riparo
                                          Panasonic Oled 55EZ950E, no picture, red led blinking every 4 sec
                                          by riparo
                                          Hi everyone, I have a Panasonic OLED TV model 55EZ950E, as soon as I turn it on I don't have any image the LED goes from green to red LED blinking every 4 sec, I found the service manual suggests checking OLED PANEL, PB BOARD, T-CON connectors but it seems like everything ok, I didn't find any burns under the pb board
                                          I attach a link to download the service manual, thank you for anyone who can help me
                                          https://tel-spb.ru/download/?brand=P...0E_LA73.rar​
                                          01-11-2024, 12:35 PM
                                        • Andre Gilbert
                                          by Andre Gilbert
                                          Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                                          Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                                          11-20-2024, 08:52 PM
                                        • ItepK
                                          Panasonic TX-P42G30E green light blinking, no video, no audio
                                          by ItepK
                                          Hey everyone!
                                          I've gotten this TV for free, neither have it seen a TV repair man, neither have it been opened before.
                                          This post describes my entire troubleshooting process of this TV.
                                          When I turn it on using the ON/OFF switch at the side of the TV, the light rapidly flashes green, then it stays on, but it does not react to any of the remote buttons, side buttons, and doesn't play audio.
                                          I've taken the unit apart, and I've started to check some voltages:
                                          • On the P11 connector, there is 15V DC only for a brief moment, then it goes
                                          12-22-2023, 05:06 AM
                                        • Tof
                                          Panasonic Oled TX-65FZ800E, no picture, red led blinking every 4 sec
                                          by Tof
                                          Hello everyone, here is the issue I am facing with my Panasonic Oled TX-65FZ800e.
                                          When the TV has not be used for some hours, I power up the TV with a video input and the image is displayed perfectly for 30seconds and then the TV switch off with the red light blinking every 4 seconds for ever.
                                          The service manual explanation: EVDD_SOS (EVDD 24V error) with check point (oled panel, P board, A board, T-CON)
                                          I opened it and found a burned connector on PB-board on the 24V pins.
                                          The 24V wires have change a bit of color due to the overheat and the corresponding...
                                          02-01-2022, 03:18 PM
                                        • itachi
                                          Panasonic TC-50AS630 No Image - Blinking LED
                                          by itachi
                                          Hello good people, I have another unit here which is giving me problems. Upon plugging the unit it, after a few seconds the front LED will start blinking 3 times in a row and repeating indefinitely. No image or sound.
                                          The first thing I checked was the backlight. It's a single vertical strip on one side of the panel which has 8 groups of 7 LEDs. (Part #V500D2-LS1-TREM3) I used a backlight tester and each group lit up without issue.
                                          The standby 5.3V is good, the 16V and 24V from the PSU board both come up for a few seconds while the TV_SUB_ON signal is high. Both 16V and...
                                          01-05-2021, 12:12 AM
