Sony KDL46W2000 standby light flashing 3 times.
  • Dang
    • Aug 2013
    • 440
    So I managed to buy this tv off someone from here asking for help in trying to fix it and I can understand why their thread went dry, the BE board is shot, 1) a connector socket has been broken off, 2) it's had work done and I wouldn't exactly say it's any good either, it looks like two fuses have been bridged so it's a case of a replacement BE board so I ask, where would be a good place to start looking for a replacement? Ebay has a selection of boards and I'm drawn to one for a 40W2000, would that be compatible do you think?
    Board numbers are: 1-871-229-12 a-1196-582-c
    These are what I have found on the bay: http://www.ebay.co.uk/sch/i.html?_od...29-12&_sacat=0
  • Dang
    • Aug 2013
    • 440
    Re: Sony KDL46W2000 standby light flashing 3 times.
    The one I'm looking at ends with "D", where as mine ends with "C", I know Sonys can be fussy about board changes so would this matter? thanks, Andy.
    • Dang
      • Aug 2013
      • 440
      Any ideas on the above please?
      • Dang
        • Aug 2013
        • 440
        Decided to check all the voltages, firstly for the PSU. all check fine and then the BE(main board), it seems the bottom two thirds are dead, no voltages seen anywhere hence the error code and I think I've located the reason why but I can't be sure, it looks to be IC 1CY103 made by sharp: http://pdf1.alldatasheet.com/datashe...Q1CY1032Z.html, checking voltages from PIN 1 through to PIN 5 measure:
        1)18v, (Vin)
        2)0v, (Vout)
        3)0v (common ground)
        4)0v, (Oadj) I'm not too sure what this means but could be an oscillation adjustment,
        5)6.4v, this is for soft starting.
        As you can see Vout is showing as 0v(this leads all the way through the central part of the board), I'm sure there has to be an output here although Oadj may have something to do with this, I just don't know, if you help please it would be much appreciated, thanks.
        • Dang
          • Aug 2013
          • 440
          What I'm asking is does the absence of Oadj make a difference to Vout? Tom66 maybe?? if not then I would have to say the IC is faulty, I would also like to ask again, it has been said Sony Tvs can be fussy about replacement boards, so is it worth the risk in trying one from the 40" version? thanks, Andy.
            OADJ = Output ADJust.
            This should be approx 1.25V.
            Note since softstart voltage is HIGH, the IC should be on (switching.)
            Two possibilities:
            - Bad IC
            - Shorted output (diode or load)
            You can narrow it down with a scope. With a shorted output you will see infrequent, stunted pulses on the output. Defective IC - no pulses. Without a scope you'll just have to lift parts until you find the bad one.
            • Dang
              • Aug 2013
              • 440
              Two possibilities:
              - Bad IC
              For as long as the tv stays on, which is about 8 seconds, I see no pulses from Vout, I tried warming it too to try and get some kind of response but nothing, so I guess the IC is bad, if I can ask, if I had Oadj at the voltage stated, then Vout should show some kind of response? if I get a chance I'll lift it tomorrow and have a look, thanks.
                Oadj is the result of Vout - not the other way around. It's how the IC knows if the output is in regulation. Usually there are is a resistive divider feeding a fraction of Vout into Oadj.
                • azza1234
                  • Nov 2013
                  • 124
                  • united kingdom
                  Did you ever get this tv going?
                  • Dang
                    • Aug 2013
                    • 440
                    Hi Azza, no, not yet, it's stored away for a rainy day but it definitely needs a new main board as described above, of course I have no idea on the state of the rest of the Tv until I have that main board so with any luck it's just a simple change and will cure the issue. I keep looking periodically for a replacement but they are quite rare for this Tv so another similar board is going to have to suffice.
                      Hmm, I might have a 40" W2000 board from a set with a cracked screen? I'll check, it is at a friends house. PM me if you are interested.
                      • Dang
                        • Aug 2013
                        • 440
                        Tom66, very and thank you, I'll PM you now.
                        • Dang
                          • Aug 2013
                          • 440
                          Been a while but finally decided to get the board for this, all now working and a good picture it is too, had to get a a board for the 40" version as the 46" just isn't available, all appears to work just the same, £55 for a 46" tv, can't be bad.
                          • 7ony
                            Samsung plasma - flashing standby light
                            by 7ony
                            The TV is a 2013 Samsung plasma, model # PN60F5300AFXZA.
                            Snagged it up in non-working condition a couple years ago. Previous owner said that sometimes he could get it to come on after repeated tries but other than that he couldn't get it to turn on.
                            Personally I haven't been able to get it to turn on at all. The standby light comes on solid when plugged in, but pressing the power button results in the standby light flashing once every 4 or so seconds. No "click" noises, no light from the panel at all. Just the flashing standby light.
                            No visible...
                            08-31-2020, 05:18 PM
                          • Bloopeta
                            Samsung UE43KU6400U Flashing Red Standby Light
                            by Bloopeta
                            Have a Samsung UE43KU6400U that will not turn on, just continuous flashing red standby light.
                            Power button does nothing
                            Have unplugged the mainboard, and backlights illuminate.
                            Have tried removing panel ribbon cables one at a time, and that makes no change.
                            With mainboard unplugged, all voltages from powerboard seem ok, but with mainboard connected, they never quite reach full voltage, and drop and raise in a constant loop (in time with click noise from mainboard.
                            Using backlight tester, I get 63.6v on both sides, so seems like no bulbs...
                            09-11-2023, 02:34 AM
                          • fuxxy
                            Samsung UN55D6000FXZA - Won't stay on, standby light flashing rapidly
                            by fuxxy
                            This is a set I posted about a few years ago. Replaced LED strips and worked fine until now.
                            Plug the set in, and it will turn on and functions with no issues.
                            After a while, (sometimes hours, sometimes minutes, sometimes immediately) the tv shuts off. When I approach the TV I notice the standby light is flashing rapidly, but the pulse of each flash is not long enough to notice from afar.
                            Other than the standby light, the unit is completely unresponsive until the power is removed and reapplied, then the cycle starts over. It does appear that the time it takes...
                            08-02-2022, 09:44 AM
                          • ChristianBr01
                            LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                            by ChristianBr01
                            I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                            The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                            What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                            04-23-2025, 01:48 AM
                          • noinimod
                            Sony 55X900E no standby light, no power. Replaced mainboard already
                            by noinimod
                            No standby red light, nothing
                            This Sony has a separate AC->DC power adapter supplying 19.5V to the TV power board (JK3)
                            Disconnected JK3 power board from main board, checked voltages on all the pin outs
                            At a few pins I can see the power supply providing 19.5V to the main board
                            Based on the service manual triage.. it seems to be pointing towards the power board (JK3) being the most possible culprit
                            LED light turns on when I disconnect LED driver board ribbon from mainboard (so i thought it is the mainboard,...
                            12-22-2021, 12:58 AM
