hitachi 75hl16t64u - not responding to remote control
  • dfear
    • Mar 2013
    • 53
    I have a hitachi 75hl16t64u tv in for repair and it is driving me crazy.
    It came in for a power issue which I have finally resolved by replacing the power supply.
    The current issue is that the TV does not respond to the remote control. I have replaced the IR sensor board with a used one but the fault persists.
    Anyone have a clue how to fix TV?
    FYI: I have checked the remote work s by pointing it at my camera on my phone.
    • 12081
    • U.S.
    New batteries in the remote? try a universal remote, just to see if it will work, do the buttons on tv work? Something that works sometimes is take batteries out, push all the buttons several times and retry.
    • lotas
      • Jan 2016
      • 4459
      • Russia
      The IR sensor might not fit the pinout you installed; they have different pinouts.
        • 12081
        • U.S.
        Put the old one back in and test with multimeter, one of the connector pins should change voltage when you give it a signal from remote if working, may be some mlc capacitors on the ir board to check.
          • 12081
          • U.S.
          Can try a simple reset, take batteries out of remote, unplug tv, hold power button on tv down for 30 seconds, wait 2 minutes plug tv in put batteries in remote and retry.
          • lotas
            • Jan 2016
            • 4459
            • Russia
            This doesn’t mean anything, even if the sensor is not working, the output voltage will change, but the processor will not understand the commands...
              • 12081
              • U.S.
              can also try take batteries out, hold power button down on remote for 1 minute, push all the other buttons a few times and retry.
              • Diah
                • Feb 2013
                • 6343
                this is Vestel 17MB130S MB, put every things back as original and use Mouse IR Keyboards or universal RC--- when there are response then some one play with it before it come under yours hand... or glitch at Profile firmware happened.. need to check after download the profile on USB if it marked Hitachi RC
                MB
                  • 12081
                  • U.S.
                  Originally posted by lotas
                  This doesn't mean anything, even if the sensor is not working, the output voltage will change, but the processor will not understand the commands...
                  Just knock it off, I'm talking about the IR sensor; If the IR LED is working, the multimeter should display a voltage drop, typically around 1.2 to 1.7 volts, depending on the specific LED.​
                    • 12081
                    • U.S.
                    Told you before to knock off those snide comments that are completely WRONG didn't I. Just like the guy with the blue ray player needed a remote with a dimmer, THAT was wrong, I told him it was a capacitor issue, which was right. So go run your BS at someone else. Because you will just come away looking stupid when you direct it at me.
                      • 12081
                      • U.S.
                      And YES mods, I am driving home the point, because this guy never quits, just like davi. And before the owner or anyone else, says oh you're being over sensitive, it is not when it happens time and again constantly. Is this guy your hero, maybe he is BUT to me he's just an assshole who obviously thinks he knows more than everyone else here combined. And he sure as hell does NOT.
                      • EazyBone
                        • Jun 2023
                        • 1305
                        • United states
                        Get a different remote. I have a universal one for most rokus. Hitachi won't work on Onn and TCL not for Hisense (or some variation) sometimes. Try a new one. I have a bag of them so that's what I'd do. I've had this happen before to me and that's what handled it.
                        Maybe but may be not.
                        • Diah
                          • Feb 2013
                          • 6343
                          try to own old mobile Samsung galaxy s5 it had ir sender,,, put on sw and use it over all brands... so easy so i do have
                          • lotas
                            • Jan 2016
                            • 4459
                            • Russia
                            There is no need to be so nervous, nerve cells are not restored, take care of yourself!
                              • 12081
                              • U.S.
                              Not nervous, just have no tolerance for stupidity. This isn't rocket science, so even if you did know everything there was to know it still wouldn't be very impressive, can you grasp that. So instead of wrongly making statements about others being wrong when they're right, maybe you should try checking facts first...sooo maybe it is thou that are nervous.
                              • EazyBone
                                • Jun 2023
                                • 1305
                                • United states
                                I use a flipper zero. Fun little device
                                • dfear
                                  • Mar 2013
                                  • 53
                                  I have done that today. There is no change in voltage on any pin (of the is sensor connector board on the main board). I Have done the same test with two mains boards and two IR sensor boards. All tests result in no reaction from the remote control.
                                  • dfear
                                    • Mar 2013
                                    • 53
                                    The two IR sensors have the same part number: 17LD186.
                                    • dfear
                                      • Mar 2013
                                      • 53
                                      I have tried new batteries. the button on the TV does work.
                                      • dfear
                                        • Mar 2013
                                        • 53
                                        I have tried 2 different IR sensor boards, each with 2 different main boards, and both sets of tests have very similar results.
                                        • tmhobadcap
                                          Pioneer VSX-522-K remote control not working???
                                          by tmhobadcap
                                          I have this receiver for at least 10 years. Usually, we just use the remote for turning on/off and adjusting the volume. Recently, the remote control started not able to turn the receiver on. Later, the volume also could not be adjusted by the remote control.
                                          At first, I thought that it was the usual problem which can be fixed by cleaning the contacts on the switches and the pcb. I opened the remote and clean it with alcohol. The remote did work again after that. But after one day, it did not work again. I opened it again and clean with alcohol and contact cleaner. Again it worked...
                                          12-24-2020, 01:44 AM
                                        • Chrissygizmo
                                          Panasonic tx-40cx400b not responding to remote control
                                          by Chrissygizmo
                                          Hi all
                                          I've just repaired the backlights on this tv. I didn't get a remote with it so I'm using a universal one. The tv works properly via the buttons on the back but the only remote command it registers is the power off. It will power on if I try immediately after switching off, if I leave it until the standby light stops blinking then it won't turn on again from the remote.
                                          I don't think the remote is at fault as I've got other remotes that do exactly the same thing.
                                          Any help would be really appreciated....
                                          Thank you...
                                          08-29-2021, 09:48 PM
                                        • piipo
                                          Old Privileg 5.1 speakers remote control question
                                          by piipo
                                          Hi, I have an old Privileg brand 5.1 speakers. I have lost the remote control. I have an universal Harmony remote but there is no Privileg brand in it's software to add. Does anybody have an idea what alternative brand for a remote can I try instead? I'm attaching an image of what the speakers looks like. The image shows 2 main speakers, they are 5 + 1 in total. Thank you very much
                                          09-18-2024, 01:55 AM
                                        • vincentedel
                                          Samsung SyncMaster 740n Phase Control Issue
                                          by vincentedel
                                          I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
                                          I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
                                          04-22-2025, 12:33 AM
                                        • hemant_2222
                                          Schematic for Denon Remote Control RC1156
                                          by hemant_2222
                                          Hello Everyone,
                                          Hope everyone is enjoying their repairs at hand!.
                                          I am looking forward to get the schematic of Denon remote control RC1156. Actually long time no use of the remote leaked the battery thereby corroding few parts as well as the tracks.
                                          I was able to join few of them but the remote is still not working, so i am looking forward for your help, in case anyone understand the schematic or the remote circuit diagram and could me assist me in repairing it.
                                          Please refer to the attached picture, i think the voltage divider is missing...
                                          10-06-2023, 02:05 AM
