LG OLED77C19LA Standby Issues
  • Bitvive
    • Oct 2023
    • 14
    Hi mates,
    I've an issue with the standby function of the LG OLED77C19LA from a colleague.
    Device
    Model: LG OLED77C19LA
    PSU
    PCB: EAX68999802
    LG P/N: EAY65689422
    He described the problem to me as follows: The device can be switched on normally and does not cause any problems.
    As soon as you switch it to standby, it stays on for about 3 minutes and then switches off. It can then no longer be switched on.
    If you then disconnect the power using the plug or a power switch, the TV switches on normally.
    Could this be a defective electrolytic capacitor from the fault pattern?
    As I have read in some places on the net that it is often related to the PSU PCB, I have now received this from him and have it here.
    The power supply is huge and I have hardly any experience with it... but now I want to use it to learn a few things.
    I hope you can help me to find the error and eliminate it. How to proceed etc., that would be great
    Best
    Sebastian
  • Diah
    • Feb 2013
    • 6497
    there are no fault unless if he or any other do before work repair on PSU... its pixel refresh timing., send IN_STOP command via service Rc or APK or DIY wave files could bring the timing Bach as it should... in case the first point i mentioned not account.
    • Bitvive
      • Oct 2023
      • 14
      I don't quite understand? So I hope I've explained correctly that the TV itself runs for hours at a time.
      • Diah
        • Feb 2013
        • 6497
        google after IN_STOP command for LG and pixel pixel refresh for LG OLED, or search this forum we did explain it manyr of times
        • Bitvive
          • Oct 2023
          • 14
          Hi Diah,
          I have now spent some time googling and have also read up here in the forum. Now I think I understand the In_Stop command. This simply resets the TV to the model-specific factory calibrations?
          But I can't find anything about my error anywhere. As I said, the TV runs without any problems and goes into standby after being switched off manually. After 3 minutes the standby goes off and the TV is dead. If you disconnect the cable from the socket and then plug it back in, it works normally until you switch it to standby manually.
          Maybe I have not understood something of your suggested solution?
          So I understand that you are assuming that there is an issue in the OS?​
          • Diah
            • Feb 2013
            • 6497
            first of all you should do In_STOP. if the issue after that no change or get better... then we talk on HW
            • Bitvive
              • Oct 2023
              • 14
              I understand the process of first ruling something out with In_stop. However, are there any useful measurements I can make on the PSU board to rule out errors on it? My colleague won't be back for another 2 weeks.
              • Diah
                • Feb 2013
                • 6497
                any measurements on PSU or other parts are useless before sending IN_STOP. LG platform are digital controlled vie MICOM which it depending on IO controlled via OS. bringing OS to first state are the first things need to do. or you want to missing with yours friends set..!!
                • EazyBone
                  • Jun 2023
                  • 1360
                  • United states
                  Put board back in, leave it off stand turn TV on. Use multimeter on the main caps. Hit power, check the readings, see if voltage starts dropping. Or on the 12v/24 line (I can't read the picture) that connects to the main board. See where the voltage is when you turn the TV in die the first time and where it drops to when the TV light dies. Measure before TV on first time, while on, and once off for that 3 minutes. It should always be a constant voltage . That's what I would check. Beyond that if it ALL stays constant I would assume it's probably fine. Would also do as diah said but I would try this since you got 5 minutes
                  • Bitvive
                    • Oct 2023
                    • 14
                    All right, let's do it like this. We'll try the IN_Stop command and then we'll see. Do you have a simple, clear guide for the IN_Stop without Service Remote that works for this LG model?
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4516
                      • Italy - Milan
                      I see no problems (never seen this board anyway) in testing the PSB in standby and full ON modes, simply provide the turn on commands (are you able?) and see if the defects are present, for my experience i see no way how it can be the PSB, is trust more a MB defect, maybe bad standby processor if present separately, the sad part i never seen one that shared info or files about those chips.. bye..
                      • Bitvive
                        • Oct 2023
                        • 14
                        Hi together,
                        now the update.. As I thought, the IN_STOP command didn't help at all. The IN_STOP command is sent -> the TV wants to restart -> and no longer switches on due to the standby problem.
                        The TV switches itself off or tries to restart, but does not manage to wake up the standby, as the lamp stays on for a maximum of 3 seconds.
                        ​I guess there are problems with the standby voltage on the PSU or the T-CON board? There must be a component responsible for this. Since apparently the voltage cannot be maintained. hmm, some kind of buffer capacitor?
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4516
                          • Italy - Milan
                          The standby voltage is normally not present only in st.by state, but always, this rail can be tested easily with a resistor, load it with 0,5A around (5v/0,5A=10ohm/5w), if the voltage remains, the resistor heats, then ok, but i know it's not power supply problem, it is one of these: bad standby software, bad BGA balls on cpu or ram..
                          • Bitvive
                            • Oct 2023
                            • 14
                            So first check the standby voltage to see if it is present everywhere? Unfortunately I can't find any schematics for this model. Up to from the PSU is still visible on the plug.
                            Ouh ouh, very bad.. Do you mean that it is more likely to be CPU or RAM? Then it must be bad solder or oxidation on the balls? Do you think a reball attempt would be successful?
                            Edit:
                            Whereby the TV runs for hours without any problems - until it is switched to standby. Are you really thinking of problems with the RAM or CPU? Then normal operation should not work until the standby state.
                            • Diah
                              • Feb 2013
                              • 6497
                              Hi together,
                              disconnect only the lower LVDS ( you have 2 the lower which are close to screen ) between T-CON and mainboards then start the TV.... the screen will remain black but the sign of running you will see the audio optic port on the Main board will lit red and remain on.
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4516
                                • Italy - Milan
                                1) i mean isolate the power supply and load only the standby 5v
                                2) The main processor could have an integrated standby MPU, with separate contact balls, their contact balls could be bad, if the standby mpu is external, it could be the cause, i need EAX code of the main board.. for the RAM discourse, it could be possibile that the standby software, to be more fast, could be copied in a certain area of the RAM, especially if there is no SPI flash, there could be a bad RAM or its balls for that..
                                The economical aspect of doing a reball of such an amount of chips is out of my knowledge, especially if based on my examination, i'm still a passionate hobbist.. even if with years of readings..
                                • Diah
                                  • Feb 2013
                                  • 6497
                                  hahahaha MPU... LOL this is TV not PC... learn about the different between PC CPU and TV SoC
                                  • Bitvive
                                    • Oct 2023
                                    • 14
                                    Resetting via the stop function did not help. I think there seems to be a fault on the power supply PCB?
                                    • Davi.p
                                      Hobbist Tech
                                      • Sep 2009
                                      • 4516
                                      • Italy - Milan
                                      So can you post the EBT/EBR codes of main board? I think you are not following well at least my posts, or your effort is not enough, with theese today's beasts of technologies you can't approach them with such no knowledge, i' m sorry, if you do things ok, otherwise, it's not a cheap tv, aren"t there service centers?
                                      • Diah
                                        • Feb 2013
                                        • 6497
                                        now we can talking on HW.... take the PSU alone on the table.. just plug it in wall and write the V you have on the socket with pin name.. which it goes to MB
                                        • DeanWy
                                          WD Sentinel DS5100 (NAS) boot issues
                                          by DeanWy
                                          I have a Western Digital Sentinel DS5100 NAS system which has stopped working. It has dual BIOS. I bought the system second hand with an already broken primary BIOS (it rebooted multiple times until second BIOS was used).
                                          It worked until recently. The system was idle in Windows Server 2012 and a BSOD occurred, I think it was 'critical process died'. Thereafter it didn't boot, it just sat there with no video output and fan speed at 100% (there's a proprietary Windows driver by WD which controls the fan, outside of that it always runs at 100%).
                                          There...
                                          07-30-2024, 04:13 AM
                                        • fharris1977
                                          Vizio D50u-D1 Dead Set No Standby
                                          by fharris1977
                                          Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                                          12-28-2023, 10:25 AM
                                        • gretti
                                          MSI Z370-A Pro, works but does not power off or reboot and USB issues
                                          by gretti
                                          I have a MSI Z370-A Pro. The board does not reboot or shut down from the Windows recovery console. USB communications stop and the status light on USB 1 stays on and does not blink. I have programmed a new BIOS with a CH341A programmer already, swapped RAM, PSU, CPU. The board will power off when the power button is held and resets when the reset switch is pressed, but it will not react to the reset switch if already told by software to shut down or restart. The board will reboot from BIOS after a save and exit command.
                                          The MSI BIOS included the ME firmware for the board. The size...
                                          10-16-2025, 02:14 AM
                                        • Crystaleyes
                                          Samsung BN44-00259A standby question
                                          by Crystaleyes
                                          Hi all.
                                          I started a thread while back regarding TV power supply standby circuitry as it is something I am not quite on top of.
                                          SMPS theory and function is becoming more familiar, however the standby part is still a bit of a mystery.
                                          Anyway, a friend has this TV with the above mentioned power supply board which has no standby voltage, nor any other voltages leaving the board.
                                          The mains AC comes in fine, gets filtered and rectified with power is on the main filter cap as well as the transformer and drain pins of the ICE3B0665J, but that's it.
                                          08-11-2023, 05:15 AM
                                        • fuxxy
                                          UN55D6000 - Multiple issues, now no standby light
                                          by fuxxy
                                          UN55D6000 I've posted about before.
                                          Initially had bad backlights, of which both entire strips were replaced.
                                          Then TV started not staying off. Every poweroff command was recognized, TV would power off then power right back on, even with nothing attached.
                                          Now, no output at all. No red Power LED, No response to remote. No clicking or coil whine.
                                          From other threads, tested various outputs on the PSU. Noticed that when the mainboard was unplugged, the backlights would turn on.
                                          Backlight Connector CNL802:
                                          Logic board unplugged:
                                          pin...
                                          12-23-2022, 08:49 PM
