Have a 50" insignia VS voltage slowy rises!
  • football0062
    • Dec 2011
    • 98
    have a NS-PDP50HD-09 insignia. The VS voltage slowly rises, if i have the xmain and y sustain unplugged. jumps to 25V then up to 45 and slowly climbs to 170. waveforms look good on primary side, but secondary you can see the slow rise before it even makes it to the diodes. anyone seen this before or have any ideas?
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Re: Have a 50" insignia VS voltage slowy rises!
    PSU's do weird things sometimes when Not loaded....
    Attach a 250V 100W Lamp to the Vs output and re-test...
    TELEFIX
    • football0062
      • Dec 2011
      • 98
      Re: SOLVED! Have a 50" insignia VS voltage slowy rises!
      after getting some sleep i took another stab at it this morning and decided to trace back the primary side of the VS. mostly because the smaller voltage that also runs off that line(15V) was rising slow too. found the problem to be the 2 caps that run in parallel with eachother directly off one side of the primary. attached a picture. replaced these and fired right back up. instant 210V even under load. hope this helps many.
      • Fernon@Repair
        Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
        by Fernon@Repair
        i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
        VCCIO voltage ok
        VCCSA Voltage OK
        VCCPLL Voltage OK
        Ram Voltage ok
        RamVTT OK
        VPP 2.5 OK
        But No Core Voltage
        and i want to this vrm ic datasheet or pinout (ISL69269)
        anyone have this ic pinout voltages?...
        06-25-2025, 07:19 AM
      • electron_jj
        Panasonic TH-L42D25A checking the PSU output voltage
        by electron_jj
        Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
        I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
        08-29-2021, 08:13 AM
        ISL95831HRTZ ISL95831HRTZ-T ISL95831IRTZ ISL95831IRTZ-T Voltage Regulator Datasheet
        3+1 Voltage Regulator for IMVP-7/VR12 CPUs
        Compliant with IMVP-7/VR12, the ISL95831 provides a complete solution for microprocessor and graphic processor
        core power supply. It provides two Voltage Regulators (VRs) with three integrated gate drivers. The first VR can be
        configured as 3-, 2- or 1-phase VR while the second output is 1- phase VR, providing maximum flexibility. The two VRs share the
        serial control bus to communicate with the CPU and achieve lower cost and smaller board area compared with the two chip approach.
        Based on Intersil's Robust Ripple Regulator...
        11-05-2024, 03:24 PM
      • master_haze86
        A1990 820-01814-A dead not charging - need help with diagnostics.
        by master_haze86
        Good day everyone,
        Let me preface this with letting you know that I have a smalltime computer repair shop but do not have a lot of experience when it comes to board diagnostics. I am good at soldering etc but finding the issue if there isn't an obvious burnt component is not my strong suit.
        The other day I got a customer come in with a macbook A1990 (motherboard 820-01814-A) that would not turn on and had previously been getting the warning message that the battery needed servicing. (Most folks seem to ignore that message, just like the check engine light in vehicles.)...
        09-13-2025, 06:01 PM
      • ruletero
        Acer a515-43 low battery charge voltage
        by ruletero
        Hi
        Acer A515-43
        LA-H801P
        Fail: Does not charge battery, has low voltaje on connector.
        Laptop didn't want to turn on, only charge led blinked.
        I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
        I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
        Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
        10-24-2022, 02:31 PM
