What is an OFL?
  • MandoZink
    • Aug 2013
    • 7
    • US
    What is an OFL?
    I'm troubleshooting a "no backlight" condition on a Sharp Aquos LC-37HV4U (I think I am anyhow)
    Flow diagram reads:
    "Is a control signal appearing at pin (2) (OFL1) and pin (3) (OFL2) of P7506 and P7616?"
    Couldn't find the terminology for OFL online for some reason.
    The display's power light blinks red - one blink per second.
  • T30M31
    • Feb 2014
    • 58
    Re: What is an OFL?
    If you know what P7506 and P7616 are you might be able to find a datasheet which should help you determine what OFL is.
    Can you provide any numbers from these two devices or provide good pictures?
    • Reda123456
      Tenda AC1200 wifi not appearing
      by Reda123456
      Hello everyone, i got this Tenda AC1200 SMART DUAL-BAND WIFI ROUTER, the problem is my electricity went off while the router was updating so it never worked, so i tired a firmware dump, it worked but the wi-fi won't appear, please help
      06-29-2024, 07:23 AM
    • kazzek
      caps terminology and technical terms used by some manufacturers
      by kazzek
      I came across some technical terms that are used to describe some capacitor types, mostly in the US. I was wondering what axialytic rabro and radialytic rabro mean? I can guess that axialytic is perhaps a combination of words axial and electrolytic. The same applies to radialytic. What does rabro mean?
      04-20-2020, 07:41 PM
    • naujguerrero
      Yoga Slim 6 14IRP8 bios
      by naujguerrero
      My Lenovo Yoga Slim 6 14IRP8 - Type 82WV laptop is not boot up after BIOS update through Lenovo Vantage app.
      It display a message box with a question "Do you want to recovery ROM Part? (Caution: Not every OS is bootable in Recovery Mode.)" With a couple of choices as below.
      YES, this choice will flash ROM Part. NO, abort Recovery mode and restart system.
      Both choices do not seem to work and the same message keeps appearing every time I restart. Even the novo button did not help and displays same message.
      06-21-2025, 01:24 AM
    • Thefixinator
      Having trouble getting Flexbv to work to view openboarddata files
      by Thefixinator
      Hey guys, I'm feeling like a noob trying to get flexbv to work to be able to download and view a particular board view of a mac mini 2018. Ive tried to read how to use the open board data but it's appearing to be a little confusing on how to actually look up a particular boardview. I'm using the free version to get my feet wet with the software. Ive checked to make sure under the program preferences the openboarddata.org is in the right spot which appeared to be there by default but im not able to open up and board preference to search for a specific board view. I'm probably confused on how it...
      06-18-2025, 11:51 PM
    • reessi
      ACER BM320 Monitor - Horizonal Flickering Lines After a While
      by reessi
      The monitor started off showing flickering thin (1 pixel) lines horizontally every say 3mm..
      They are black on the right and gradually fade to nothing on the far left.
      They start either after 5 mins or up to 2 hours after so annoying for testing.
      They flicker continuously very fast! With a slight pause milli-second every second.
      Initially I cleaned the LVDS cable and connected to the T-Con and then it worked fine for 3 weeks but not sure if this was just co-incidence.
      I tested each half by removing the first the left flex from...
      06-03-2025, 09:58 AM
