Yoga Slim 6 14IRP8 bios
  • naujguerrero
    • Jun 2025
    • Mexico
    My Lenovo Yoga Slim 6 14IRP8 - Type 82WV laptop is not boot up after BIOS update through Lenovo Vantage app.
    It display a message box with a question "Do you want to recovery ROM Part? (Caution: Not every OS is bootable in Recovery Mode.)" With a couple of choices as below.
    YES, this choice will flash ROM Part. NO, abort Recovery mode and restart system.
    Both choices do not seem to work and the same message keeps appearing every time I restart. Even the novo button did not help and displays same message.
    Click image for larger version  Name:	image.png Views:	170 Size:	780.2 KB ID:	3664050
  • peste
    • 13573
    • ROMANIA
    Originally posted by naujguerrero
    Hello, can you reupload?, i cant download this file, thks.
    post the contents of the bios chip even if it is corrupted..
    post S/N, full name and model, motherboard model, TYPE,etc.
    • naujguerrero
      • Jun 2025
      • Mexico
      Hello, here is more info. Thanks.
      ​​​​​Yoga Slim 6 14IRP8 - Type 82WV
      Serial number: YX07B213
      Processor: 1x 13th Generation Intel® Core™ i5-1340P Processor(Core™ i5-1340P)
      Motherboard model: MB H82WVI51340P_UMA_16G_L_WINRM (Part number: 5B21J35939)
      • hoaca388
        Badcaps
        • Jan 2022
        • 12326
        You MUST:
        • Read BIOS guides, methods, resources and tools
        • Try the method at BIOS guides, methods, resources and tools before requesting help
        • Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
        • Use search function in case someone already answered your request
        • Post under a related thread if it exists
        • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
        • Name your thread with make, full model numbers and request
        • Provide a BIOS/EC dump if possible
        • Attach files directly to your post instead of linking to external websites
        • Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms
        • bojoe15
          • Aug 2025
          I was in a middle of a bios update and accidently turned my laptop off. Now, my bios is corrupt and I am greeted with a "Do you want to recovery rom part" screen.
          Laptop Info:
          S/N: YX066EBM
          Factory ID: HQ006
          MO: YX60B3316019
          MTM:82WVCTO1WW
          MFG Date: 2023/03/16
          Things that I have tried:
          - downloaded "LGCN25WW.exe" bios, extracted it, renamed the "WinLGCN25WW.fd" file to "lgcn.bin" and "Fn+R" bios reflashing -> usb bios got recognised however, got an insyde screen that said "not allow flash, boot guard version verification failed. Error: update bios failed!"
          - red the content of the 128mbits and 64mbits rom memory ic, the dump is attached
          - programmed the 128mbit memory with the first 128mbits of .fd file and the rest on the 64mbits memory ic -> didnt know what i was doing, probably made it worse, the screen didnt turn on and my power light was flashing one long and two short pulses
          - reverted both ic into the orginal state -> back to the "Do you want to recovery rom part" screen.
          - actually extracted "LGCN25WW.exe'" using biosutillities -> dont know what to do with the extracted .fd file, i guess i got some hints on the memory location of bios, cert, islfash and platform
          Thing that I am going to try:
          - Combining the backup with the lenovo bios and flashing it on the 128mbits ic, keeping the 64mbits the same (no idea what I am doing, chat gpt suggested this)
          Some help/advice would be appreciated!!
          Thank you!!
            SMDFlea commented
            Editing a comment
            Thread merged.
        • m1ch43lzm
          • Mar 2019
          • 909
          • Peru
          You were close, the extracted .fd that is 24MB "BIOS-UEFI [0x001E6690-0x019E6690].bin" should be split in 8MB + 16MB, then from your backup of the 16MB you have to extract the DMI data (serial, MTM, model name, Win key), it's encrypted on this model, there are 2 blocks that start with LENV, open with hex editor and copy to the 16MB file after splitting
          The range is from 1D9000h-1DAFFFh, I copied it to the attached 16MB BIOS
          ​S/N YX066EBM​
          MTM 82WVCTO1WW​
          BIOS Ver. LGCN25WW
          DMI 1D9000h-1DAFFFh (on 16MB BIOS)
          Try flashing only the 16MB BIOS first
          Latest version is LGCN34WW by the way
          • maurorhkg3
            • Aug 2025
            • colombia
            buenas tardes tengo el mismo equipo con el mismo problema, agradeceria la ayuda mis archivos son:
            • m1ch43lzm
              • Mar 2019
              • 909
              • Peru
              Please write in english (use Google translate if you need) and
              RULES UPDATE for BIOS requests/offer...EFORE POSTING*
              You MUST
              • hoaca388
                Badcaps
                • Jan 2022
                • 12326
                PLEASE , communicate in English and serial number .
                • maurorhkg3
                  • Aug 2025
                  • colombia
                  HELLO, APPRECIATE THE COMMENTS.
                  THIS IS MY LAPTOP'S DETAILS
                  Laptop Information:
                  Serial Number: YX08CTDC
                  Factory ID: HQ006
                  MO: YXN0B3A0900N
                  MTM: 82WV0006LM
                  Manufacture Date: 2023/10/09
                  MOTHERBOARD DATA:
                  MV-6
                  94V-0 2338
                  E89382HSB J A-01
                  I'D APPRECIATE IT IF YOU COULD HELP ME WITH MY LAPTOP'S BIOS. I'LL LEAVE THE FILES ATTACHED. I HAD THE EXACT SAME FAILURE AS THE OTHER PARTNER.
                  • m1ch43lzm
                    • Mar 2019
                    • 909
                    • Peru
                    BIOS extracted from Lenovo website with serial/MTM/Win key inserted
                    Bios ver LGCN29WW
                    S/N YX08CTDC
                    MTM 82WV0006LM
                    Try the 16MB (128) file first
                    • to5it0
                      by to5it0
                      10-24-2025, 01:35 AM
                    • beogeek
                      Lenovo Yoga Slim 7 14APU8 Bios Request
                      by beogeek
                      I've currently got a Lenovo Yoga Slim 7 14APU8 that is not posting. Its fan spins, the keyboard lights up, and the caps lock doesn't work. It was taken to some shop for cleaning, and then they updated or tried to update the bios. After that, there was no display and no post. I've removed the bios ic from the board and made a bios dump. I need some assistance going forward, as I suspect this is probably just a bad bios issue. I've tried searching for a dump, but no luck; if anyone can throw me a bone, it would be much appreciated!
                      Attached is the bios dump in the state I received it...
                      10-24-2024, 12:54 PM
                    • pavel.kinc
                      Lenovo Yoga Slim 7 Pro 14ACH5 bios
                      by pavel.kinc
                      Hello everyone, I would like to have the bios file for this laptop please. After the bios update it stopped working, only a black screen.
                      Lenovo Yoga Slim 7 Pro 14ACH5 , S/N:PF3DGGVN, motherboard HS45H NM-D691 Rev:1.0
                      There is no working file. Thanks for any help....
                      03-17-2025, 02:16 AM
                    • macabook
                      by macabook
                      🧩 Initial Issue
                      07-24-2025, 02:17 PM
                    • rushouse77
                      Yoga Slim 6 14APU8 clean bios
                      by rushouse77
                      Hello! i need cleam bios dump for Yoga slim 6 14APU8
                      Does anyone have or can help correct my dump? There is absolutely nothing on the Internet about this model...
                      MTM: 82X3000NRK
                      Board: NB6287C_MB_V5
                      Here is my original bios with pass:...
                      12-13-2024, 10:52 AM
