Set is in standby and wont power up. In standby I get 5.02V on 5VSB and the rest of the pins are 0V. If Short PS-ON to GND with a 1K resistor I still get nothing. Anyone have history with these sets? Common issues. A quick google didn't turn up much in the way of Youtube repair tutorials. No burn marks on front or back of the power board or main board. I also don't have a remote so hoping its not just a power button issue but the lack of voltage on 12v or the other 5v pins is leading me to power board problems.
RCA LED32B30RQD - Standby Only
Thanks Lotas! I just did that and have all 12v and 5v. However there was an unused 24v pin on a different part of the board and I probed that and it only has 18v on it. Not sure if its important as it doesn't have a connector soldered to it and its not being used. I do see that 18v jump to 19.2v in unison to a faint tick I can hear from the board. - This is all being done with the mainboard disconnected.Comment
As I understand it, your motherboard (chassis) is T.RSC8.78, and it has a non-MStar processor, so I won’t be able to restore it..Last edited by lotas; 08-20-2024, 04:48 PM.Comment
According to the photo on the Internet, you have a processor under the heatsink. Do not tear it off (heatsink), otherwise you will damage the processor.
As I understand it, your motherboard (chassis) is T.RSC8.78, and it has a non-MStar processor, so I won’t be able to restore it..Comment
Thanks Lotas,
It was the button control board, the power button was stuck. After disconnecting it and shorting the pins that would go to Power momentarily the set powered right on. I went back and checked my original main board, it was also good. Now I have a spare! I cleaned the button board and it's working again. Glad to have the TV back up and running. Thanks again!
Early in troubleshooting I tried to short the GND and Power button pins but still had the button board connected, thanks for pointing out that one of them could be stuck and blocking functionality of the others.
Much appreciated
If anyone was curious I tried a RE010C878LNA-A1 main board instead of a RE010C878LNA-B1 and it still worked just fine. Shop Jimmy says they are different but they both worked with my hardware.
Here's the board I picked up: https://www.ebay.com/itm/156339499551 Note the "DVD Signal" just behind the component barrels.Comment
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
Assuming...7 Photos -
by HakuuHi There,
More Details
TV Model - LG OLED77G1PUA
Got the same exact TCON board from TVPartsToday and replaced it. But didnt transfer the EPPROM data (didnt... -
by jb_BakHey guys great forum glad to have found it. I bought a Sony XBR 65X900C cheaply because it didn't work. No signs of life at all not even a light/led. All I hear is a brief high voltage sound when I throw the power to it.
CN6401
Pin 01 NC
Pin 02 NC
Pin 03 "BL_ON": 0V
Pin 04 "N/C"
Pin 05 "STBY 3.3V": 3.5V
Pin 06 "GND": N/C
Pin 07 "AC_OFF"... - Loading...
