hyundai 32hyn3210 look for dump
  • wolf1976
    • Oct 2023
    • 109
    • Ελλάδα
    hi to all
    on above tv when i insert it on netz the red led blinking continoously
    it has to have problem with the dump file
    has anyone this file or someone compatible ?
    thanks on advance
  • wolf1976
    • Oct 2023
    • 109
    • Ελλάδα
    panel wes315wnda-2d-n21
    main 17mb140​
    • lotas
      • Jan 2016
      • 4665
      • Russia
      There is USB firmware for "Digihome 32HD273T2 (A)" 17MB140, VES315WNDA-2D-N21.
      • wolf1976
        • Oct 2023
        • 109
        • Ελλάδα
        hi sir
        where can i find it ?
        i look for find it without success
        • lotas
          • Jan 2016
          • 4665
          • Russia
          So it's not publicly available, so I'm posting it, I don't know, maybe the remote control won't work...​
          • wolf1976
            • Oct 2023
            • 109
            • Ελλάδα
            in that case i will have problem the tv has not buton so i cant test it if it works normal
            i will look on internet if there is someone application on mobile to use it like remote and after i will try your file
            thanks sir lotas
            • wolf1976
              • Oct 2023
              • 109
              • Ελλάδα
              sie lotas i transfered the three files in a usb 8 gb and before transfer i ues fat32 configuration
              iwhen i connect in the netz the device i press the ok on the remote control started to read the usb flash blinking but its not continues stop to read
              i used and ntfs configuration thze same
              what i do wrong
              • lotas
                • Jan 2016
                • 4665
                • Russia
                Try to find an old flash drive, smaller in size (1-2 Gb).
                • wolf1976
                  • Oct 2023
                  • 109
                  • Ελλάδα
                  thanks for one more time
                  the smaller that i have is 4gbyte i will try with this
                  do you have this file and to load it with programmer ?
                  e.g ch341a ?
                  • lotas
                    • Jan 2016
                    • 4665
                    • Russia
                    There is no such dump for the programmer, try writing the “mb140.bin” file through the programmer (it is the same size as your spi flash 25Q128), just be sure to save your original dump!
                    • wolf1976
                      • Oct 2023
                      • 109
                      • Ελλάδα
                      can i do this with the ch341a programmer
                      or i need other ?
                      • lotas
                        • Jan 2016
                        • 4665
                        • Russia
                        Well, try it, install the program for CH341A "NeoProgrammer V2.2.0.10".
                        • wolf1976
                          • Oct 2023
                          • 109
                          • Ελλάδα
                          unfortunately
                          i found a very small in capacity stick 30mbyte
                          i try to transfer the files and something goes wrong
                          now nothing doesnt light on motherboard so
                          sir lotas the original flash is 25l12835f
                          what equivalent of winbond must i use to read with the ch341a ?
                          thanks on advance
                          • lotas
                            • Jan 2016
                            • 4665
                            • Russia
                            I wrote that you need to save your original dump!, and then conduct experiments.
                            • lotas
                              • Jan 2016
                              • 4665
                              • Russia
                              unfortunately
                              Where did I find it, you have 25l12835f - this means your spi flash is 16 MB.
                              What program do you use for CH341A?
                              • lotas
                                • Jan 2016
                                • 4665
                                • Russia
                                You don't need any equivalent of WinBond, install the original flash from MXIC (MX25L12835F), it is in the list of this program (NeoProgrammer V2.2.0.10).
                                • wolf1976
                                  • Oct 2023
                                  • 109
                                  • Ελλάδα
                                  sir i have confused now
                                  I unzipped the file you gave me and put it on the stick of 30mbyte capacity
                                  I also send you a photo
                                  My mistake was that I didn't backup the original file of the completed MX25L12835F which has a character according to the manual of 128 mbyte correctly
                                  I just made several attempts to read the file you gave me to no avail when I pressed OK on the controller it would start and read the USB but then the USB would turn off and the light would go quickly on the TV
                                  And another time it stayed on permanently and the light flashed quickly on the TV to no avail until at some point it didn't even blink rather crashed the Now I have hopes of doing something to restore it with your file I mean also with the Programmer CH341A ?​
                                  • lotas
                                    • Jan 2016
                                    • 4665
                                    • Russia
                                    MX25L12835F - 128Mb bits serial Flash memory, which is configured as 16,777,216 x 8 internally. (128 Megabits =
                                    16 Megabytes)
                                    All three files should have been unpacked on your USB flash drive..
                                    • wolf1976
                                      • Oct 2023
                                      • 109
                                      • Ελλάδα
                                      you are right at first I did it as you showed from the many times I configured the stick I was wrong I admit it
                                      Now I can use a WinBond Flash and program it with CH341A Programmer with the file you gave me to restore it or it is not done
                                      I'm just asking to know​
                                      • lotas
                                        • Jan 2016
                                        • 4665
                                        • Russia
                                        How difficult it is to understand you...
                                        What other WinBond?, you have an SPI Flash from MXIC (MX25L12835F), it is in the program database for CH341A, so set it up and write the file “mb140.bin” to it!​
                                        • Ahari
                                          by Ahari
                                          I...
                                          08-13-2025, 06:12 AM
                                        • ugura09
                                          Hyundai N91W DUMP
                                          by ugura09
                                          Hyundai N91W DUMP
                                          200-100-2A1D-CH
                                          CPU:TSUM66AJ-LF-1...
                                          06-03-2023, 06:06 AM
                                        • Habble7
                                          by Habble7
                                          Suspected Cause:
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • Mephysis
                                          DUMP DVR HIKVISION DS-7208HGHI-K1 (80389 Rev 1.3 Firmware)
                                          by Mephysis
                                          Hello guys i really need help, i recently updated my DS-7208HGHI-K1 and it somehow got bricked, I've got it up and working now by flashing a new dump file i found but the serial number is really wrong and the uploader of the dump file probably intentionally did it.
                                          I still have the bricked dump file is it possible to transfer the serial number of the "bricked dump" to the "working dump"?
                                          03-27-2025, 02:34 AM
                                        • Citymin
                                          by Citymin
                                          S/N : 5RNK9FFT70...
                                          08-05-2025, 05:12 AM
