Philips 37PFL7662D/05 losing channels, no factory reset.
  • baddesley
    Engineer
    • Dec 2012
    • 55
    Hi Guys, I have been given a Philips 37PFL7662D/05 37" LCD TV. It powers up and all menus are available - to start with anyway. If I do a digital retune, it will usually find channels and display them (sometimes not!) If left on, it seems to work OK, but if I use any of the menus, it will occasionally 'pop' and either shut down, or reboot, while at the same time losing all of the channels. If the TV is put into standby and back on, all channels are lost and often, this also loses all menus (just get a blue screen) and the set has to be fully powered off/on to get anything back. Retuning will then get the channels back, until next time it's switched off, or put into standby! Basically, it's acting very weirdly!
    I have tried to do a factort reset, but nothing happens - I have tried holding the menu button in on the side of the TV (for 30 seconds or more) as stated in the manual (in normal TV mode, menu mode and all other modes I can think of!), but, apart from the power LED flashing, that either does nothing, or occasionally makes the set 'pop' off and on again, but it does NOT reset the memory. I have also tried the reset procedure given in another post on here (069526 i+ (I think)), but that doesn't do anything either.
    Any ideas on what could be wrong and, especially, how can I force a factory reset, which I'm hoping will fix it. Signal levels are good by the way; I have another Plasma that works faultlessly on the signal and levels are shown as 'very good'. Thanks in advance.
  • baddesley
    Engineer
    • Dec 2012
    • 55
    Re: Philips 37PFL7662D/05 losing channels, no factory reset.
    Code tried is 062596 +i. Does nothing.
    • baddesley
      Engineer
      • Dec 2012
      • 55
      OK, managed to fix this myself and can confirm that it was indeed a corrupt Non-Volatile Memory (NVM, or NVRAM), which is why the menu button wasn't doing anything and why it wasn't storing channels.
      Getting into the Service Menus isn't quite so simple as at first thought, but I finally found and downloaded a Service Manual (LC7.2E LA chassis). Reading throught this, I found out how to get into these menus, though it was not very clearly described. It seems that at first you need to put the TV into Analogue TV mode (which was NOT mentioned), then quickly enter 062596 followed by the 'TV Menu' button (manual just said press 'Menu', despite the fact that the remote has two of these!). This takes you into the first part of the Service Default Mode (SDM) which simply displays alphabetical characters that respond to stored information such as operating hours, software version and errors. If needed, you can look these up on the service manual. Service Default Mode is indicated by the letters 'SDM' in the top right corner. From here, there are several options, including one that requires entering the Display Option Code, which can be found on a lable on the back/side of the TV. However, simply to reset the NVM, quickly press 062596 and the i+ (or OSD) button to get into the Service Alignment Mode (SAM) menu. Once in here, you can finally select to 'Clear' the NVM - though I found two 'Clear' options and selected to clear both. Finally, exit Service Mode by pressing the Power/Standby button.
      Once you've done this, power up the TV and, again in Analogue TV mode, hold in the Menu button on the side or top of the TV (NOT on the remote) and hold it for 10-20 seconds, until you get the New Install menu, which asks you to select Language, Country etc.. Once these are set, do a FULL Channel Scan (if asked, agree to deleting all old channels), which will, finally, give you all of your channels and KEEP them!
      Hope this is helpful to someone.
      • vinceroger69
        • Mar 2012
        • 6714
        cool thanks for taking time to post the fix.
        • cheeky2
          • Dec 2012
          • 339
          Thanks I had identical issue where I couldn't reset the TV to factory settings. I had to apply this factory reset a number of times before I could get it to correctly retune the Freeview channels and store them. It took me a little while to try and find the ' i+' until I turned the light on to examine the remote properly. Its to the left of the 0 key!
          I noticed that the MENU key when pressed on the side of the TV wouldn't appear on the screen. After the factory reset had finally worked the MENU appeared on the screen when pressed!
          Thanks for the useful information.
          • ictc
            Philips MDP 3380/12 Blu-ray Player – No Power, Reset Signal Always High
            by ictc
            I'm troubleshooting a Philips MDP 3380/12 Blu-ray player that shows no signs of life. The display remains off, and no buttons respond.
            Inside, the power supply is working correctly, and all expected voltages on the mainboard match the service manual specifications. The CPU warms up slightly (checked with a thermal camera), the crystal oscillator is functioning, but the reset signal remains high at all times.
            The reset circuit appears to consist of two NPN transistors, one driven by 5V VCC and the other by 3.3V STBY, as shown in the attached schematic. Should the reset...
            02-25-2025, 12:15 PM
          • sheffieldyorky
            ZAB/ZAB A,B/ZYJA BLOCK DIAGRAM Acer Aspire
            by sheffieldyorky
            Hey there people
            While working on my Acer Aspire with the OS failing to load, I encountered a motherboard number of DA0ZHQMB6E 0 REV: E. I was getting nowhere fast or slow, for that matter.
            This is what I tried, but not in any order.
            Google
            YouTube
            BIOS
            Command Prompt (administrator privileges)
            On Google AND YouTube, I was getting mixed messages, try this and try that, but when you cross reference the advice it is either the wrong model (even though you enter the correct search term) a YouTube case in point, with the search term "how to...
            10-25-2025, 02:22 AM
          • Sharpa
            Repair attempt Philips 55OLED804/12
            by Sharpa
            I bought a SH Philips 55OLED804/12 TV with known defect in an attempt to repair it for personal use.
            The symptoms when bought: Philips logo appears then tv turns off
            Things tried so far:
            1. Powering it on: Philips logo shows on the screen, sometimes with some minor artefacts then shuts down. Red status led flickers rapidly into two batches then repeats
            2. Put it in recovery mode by pressing joystick down then plugging it to mains: The tv shows the logo then shows the android animation along with some minor artefacts on the screen...
            Yesterday, 08:30 AM
          • alro7779
            Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
            by alro7779
            Hello, guys!
            The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
            09-14-2025, 12:25 AM
          • G33RT
            Philips 8200 series 65PUS8204/12 stuck at Philips Logo
            by G33RT
            Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
            It does power up when pressing the power button.
            I already try the power button while plugin the plug with no result.
            Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
            Could this be an PSU or eMMC issue ?
            07-19-2025, 03:43 AM
