Samsung UN50TU8000 - Dead Panel Forensic Questions
  • KYBOSH
    • Oct 2011
    • 581
    • Unknown
    I came across a 50inch TU8000 that wouldnt start up properly (blinking stand-by light, backlights would cycle on and off).
Name:	2024-08-09 22.05.46.jpg
    When i opened it up and removed the power to the mainboard the backlights powered up and everything looked uniform.
    When reconnected the mainboard but disconnected the flex cable to the panel i heard the TV startup with the intro sound.
Name:	2024-08-09 22.01.43.jpg
    Later I checked for shorts on the panel PCB boards but could not find anything.
    When I took a look with the FLIR i noticed the 2 resistors (2701 at R43 and R44) where really hot even though the panel was not working.
    I measured their resistance and they were about 5% lower than what they should have been (around 2400-2500 ohms). I didnt think this was too egregious but for good measure I was prepared to replace them as I didnt know if that was enough to cause the TV not to startup.
Name:	2024-08-09 22.01.29.jpg
    Before I did set out to change them out I disconnected the flex cable from the mainboard and measured again.
    I was surprised to find that the resistance had gone back up to within +/-1% spec.
    Can anyone explain the two phenoms to for me?
    1) Why the resistors were running hot even though the TV was not displaying an image (yes there is a short somewhere on the panel but Im expecting the mainboard to cut power to the panel or something).
    2) Why the resistance of the two resistors dropped when the flex cable was connected to the mainboard.
    I was able to isolate and mask off the one trace that was causing the bootloop but i was never able to get any picture even after several rounds of carefully masking off other traces.
    I gave up on the panel but questions still linger on my mind about the facts of the case.
    Thanks in advance
  • rzr
    • Jul 2025
    • 7
    • fr
    Can anyone see the attached images ?
    What is the blinking code of your TU8000
    Been told at https://www.reddit.com/r/TVRepair/co...t=share_button
    The double blink code means there is a communication error in the tft portion of the display.
    May this help, I am also trying to troubleshoot a UE50TU8005KXXC that ships a CC500PV6D
    • howardc64
      • Jun 2017
      • 650
      Click image for larger version  Name:	samsung-ue50tu8005k-black-screen-backlight-and-sound-ok-v0-g68j1lk1qref1.jpg Views:	27 Size:	74.2 KB ID:	3691521
      Your UE50TU8005K is probably similar to North America model UN50TU8000
      https://www.youtube.com/watch?v=6mm5zQSD_DM
      which has T-Con on main board, single flex to left panel board, flex from left panel board to right panel board. This kind of T-Con connection doesn't allow testing of left and right panel board independently so finding which side of the panel is shorted is difficult.. If fault is in left panel baord, there is no way to disconnect it and just test the right panel​.
      • rzr
        • Jul 2025
        • 7
        • fr
        Originally posted by howardc64
        If fault is in left panel baord, there is no way to disconnect it and just test the right panel.
        I think have isolated the short
        It is the right side, I had to cover pin 1 and 2 with tape to stop the reboot loop.. but I have no idea of the pinouts of the middle cable that connect both side of screen
        SFPCX465G-002_20086
        On the left side ( SN2 near SCOF1), I had to tape pin 1&2 (on right side of connector) to enable boot to sound
        https://www.taobao.com/list/item/661546742557.htm
          • 12306
          • U.S.
          Did you get a display or just quit looping?
          • rzr
            • Jul 2025
            • 7
            • fr
            No display, but i can see the backlught and hear the welcome sound and remote event
            See attached hack
              • 12306
              • U.S.
              I keep seeing these short killer devices and techniques on youtube. Wonder how good the success rate is.
                • 12306
                • U.S.
                This one is interesting but it's not in English, looks like he's very knowledgeable on how everything works together and where to test. Someone with lots of patience and determination could probably learn where to test and maybe pinpoint the short and kill it without damage to screen hopefully: https://www.youtube.com/watch?v=EZf10JQlvfE
                  • 12306
                  • U.S.
                  Maybe all new samsung tvs should come with one of those included.
                    • 12306
                    • U.S.
                    If anyone looking on has had success in this area, let us know, it's mildly interesting no?
                    • mmartell
                      General Questions on the Relationship Between Mainboard, TCON and Panel
                      by mmartell
                      My goal here is to be able to use boards on hand to swap into faulty sets when the faulty board is not obvious.
                      I will start by asking what is the format of the output from the mainboard and is it generic in any way or does it vary by manufacturer and/or model ?
                      And as far as I know a tcon and panel must be a matching pair because the timing of the signals and the voltages required to drive the panel are specific to the panel itself. (That may be a blanket statement that isn't true in some cases where the panel creates its own sub-voltages on its panel boards?)...
                      01-06-2024, 01:32 PM
                    • knoxrebel
                      Bad panel or bad mainboard? Visio E601i-A3
                      by knoxrebel
                      Visio E601i-A3
                      Tv powers on and input is able to be selected/used, but the on screen menu closes as soon as it is opened and the there are some periodic "glitches" of the on screen menus in relation to position and size. I have tried all the system resets,but because the menus are not usable, i was unsuccessful. Does this seem like a panel issue? Odd that it only affects the menus and not the main input picture. I have already tried disconnecting front panel buttons assuming one was stuck down causing the input to continually be scanned or similar.
                      https://www.youtube.co...
                      03-01-2025, 12:14 PM
                    • stylishconsultant
                      un60j620dafxza - Samsung No Display Problem
                      by stylishconsultant
                      Hi All,
                      Need help.
                      I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
                      So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
                      problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
                      might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
                      09-04-2024, 03:26 AM
                    • NSkyLab
                      Vizio D43f-J04 is panel dead?
                      by NSkyLab
                      TV Model: Vizio D43f-J04
                      Main Board: TPD.MT5583.PB751 (60103-00876)
                      T-Con: BOE_CC430LV2D_43001 V1.0
                      Panel: BOEI430WU1
                      The video of the defect is here: https://photos.app.goo.gl/fzfvmUqGXW3c1Nrg9
                      This is a dumpster find, don't know if it was hit, there are no visible cracks...
                      I though there may be something wrong with the panel voltages.
                      Those I managed to find on the T-Con board. Does it seem normal?
                      12V: 12.27v
                      VCC33: 3.28v
                      1.2V: 1.25v
                      VGL: -5.87v
                      AVDD: 16v
                      HAVDD: 7.47v
                      VCOM: 7.0v...
                      01-29-2023, 08:18 PM
                      Lenovo IdeaPad Flex 6 Hybrid (2-in-1) Flex Specification for Upgrade or Repair
                      This specification for the Lenovo IdeaPad Flex 6 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Flex 6 boardview and Flex 6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
                      09-06-2024, 02:30 PM
