Bad panel or bad mainboard? Visio E601i-A3
  • knoxrebel
    • Oct 2009
    • 168
    Visio E601i-A3
    Tv powers on and input is able to be selected/used, but the on screen menu closes as soon as it is opened and the there are some periodic "glitches" of the on screen menus in relation to position and size. I have tried all the system resets,but because the menus are not usable, i was unsuccessful. Does this seem like a panel issue? Odd that it only affects the menus and not the main input picture. I have already tried disconnecting front panel buttons assuming one was stuck down causing the input to continually be scanned or similar.
    https://www.youtube.com/watch?v=7YHmAbT_4Ew
    Please excuse the backlight blinking, i was shooting slow motion. The flash of "No channel in master list" at top of screen is what i'm referring to
    Mainboard = 1P-0128J00-4011 Rev1.1
  • EazyBone
    • Jun 2023
    • 1438
    • United states
    • Anything I can do with my hands
    Stick a firestick on it and see what happens.
    I'm not sure how a panel would effect the menu .. to me doesn't seem right to say panel but I am unsure. But do try a firestick or something and see if it runs fine
    • knoxrebel
      • Oct 2009
      • 168
      Ruku works just fine, Not seeing any video distortion on boot logo or on input signal, Only seems to be related to OSD. Can't find a factory reset sequence or firmware either, may be SOL on this one.
      • mmartell
        General Questions on the Relationship Between Mainboard, TCON and Panel
        by mmartell
        My goal here is to be able to use boards on hand to swap into faulty sets when the faulty board is not obvious.
        I will start by asking what is the format of the output from the mainboard and is it generic in any way or does it vary by manufacturer and/or model ?
        And as far as I know a tcon and panel must be a matching pair because the timing of the signals and the voltages required to drive the panel are specific to the panel itself. (That may be a blanket statement that isn't true in some cases where the panel creates its own sub-voltages on its panel boards?)...
        01-06-2024, 01:32 PM
      • hd8system
        Unlock hidden menus aptio American Megatrend mainboard TH410-D4
        by hd8system
        Hi everyone, I have a TH410-D4 motherboard whose security menus, iommu, and other features have been hidden by the manufacturer. I tried making changes to the BIOS, but reprogramming it didn't make them reappear. Unfortunately, there are no adaptable BIOSes available. Could someone work with the original file I'm attaching to unlock all the unlockable menus? Thank you very much. I need to use Proxmox and I need iommu to passthrough PCIe devices.
        Thank you so much! ...
        05-15-2026, 01:13 PM
      • stylishconsultant
        un60j620dafxza - Samsung No Display Problem
        by stylishconsultant
        Hi All,
        Need help.
        I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
        So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
        problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
        might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
        09-04-2024, 03:26 AM
      • re-atari
        MSI A520M Pro mainboard - need boardview and/or hires photo's of components surrounding RT8894 PWM controller
        by re-atari
        Recently I was donated a defective MSI A520M Pro rev. 1.0 mainboard, that I am now trying to get back on its feet again. The error description when I received it, was that it wouild not boot, with the CPU error led lighting up.
        When inspecting the board with a magnifying glass, I noticed someone had slipped with a screwdriver when installing the CPU cooler. Not just once, but 2 times at that. Go figure. In the end the result was 2 scratches with damaged copper traces and a few knocked off (and missing) components around the RT8894 PWM controller. No wonder the...
        01-21-2026, 11:58 AM
      • Chris24
        LG OLED77C2PUA CUSQLJR Does not turn on - solid standby light with one blink.
        by Chris24
        Hello, been a while since posting and always appreciate this forum and the help.
        Picked up an LG OLED77C2PUA that does not turn on.
        The standby light does come on when plugged in. Pressing the on/off button on TV (or LG remote) the red light turns off for 1 second and comes back on steady. I took off the back panel and tested the power supply. When pressing the power button, the 20V and 12V to Mainboard spike to 19.9 and 11.9 for a few seconds then slowly drop back off. Can tell the supply is coming on for 2-3 seconds. The 12V to TCON also spikes to 11.9 then drops back...
        01-27-2026, 12:03 PM
