Samsung LE40R87BD
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4367
    • Italy - Milan
    Re: Samsung LE40R87BD
    licbal you idiot, don't hijack other one's thread.. (Readed all thread until i've seen it's from 2014..)
    • licbal
      • Jun 2014
      • Potugal
      Just wanted to know what ic is this. of fixed value 1117
        So what are the Voltage readings right now on each pin?
        • licbal
          • Jun 2014
          • Potugal
          On the board is a plate to make protection and that also should make dissipation, underneath this plate is 4 ic and there is the error is that the heatsink is detached from the IC. Necklace also sinks on the ic EM6A9320BI-4MG and does not happen anymore the power turns off.
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
          • ohren
            Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
            by ohren
            I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
            I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
            The models launched in 2018 and 2019 respectively....
            09-08-2023, 05:24 PM
          • C152Heavy
            Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
            by C152Heavy
            Summary for TL-DR readers:
            • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
            • Have obtained Samsung schematic & service documents - Can upload if helpful.
            • Have read ALL applicable threads
            • C1818 and CP820 replaced as low hanging fruit
            • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
            • VCC pin (18) of PFC...
            01-11-2023, 02:53 PM
            09-07-2024, 05:50 AM
