Panasonic th-50pz850 Flashing Red Light
  • Gadjet
    • Aug 2012
    • 248
    Currently I'm getting 2 flashing red lights when the power button is pressed. No obvious board damage.
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic th-50pz850 Flashing Red Light
    Sounds like common PSU fault with MC201/301 modules.
    http://www.youtube.com/watch?v=LjpGKaBt8hg
    • esqmooo
      HP Elitebook 845 G8 dead, only caps lock flashing 7 times. Charging light always on
      by esqmooo
      Hello everyone.
      This is my development machine. I've been using it since two years and half without any problem except sometimes it wouldn't wake up from sleep.
      Lately the issue became more frequent and powering it up would take few seconds to show the POST screen.
      Then the computer refuses to power on at all. Now only the caps lock button flashes 7 times then stops. The charging light is always on whenever a power source is connected (battery or charger).
      I tried long pressing on the power button, after several seconds it would go off then when the button is released...
      03-11-2025, 03:57 PM
    • learnmore
      Samsung QE55Q60TAUXXU - flashing backlight and flashing standy light--no image
      by learnmore
      Hello Community!
      CASE DETAILS
      Promblem Signs: Backlight on 1 sec off 7sec > repeat && Red standby light: 1blink, off 3 sec, 2 blinks, off 5 secs, 2 blinks, off 3 sec, restart cycle
      13V present on powerboard output. Backlight continues flashing after removing cables to pannel one at a time and even with both disconnected. NOTE: backlight STOPs flashing and remains on when connector between powerboard and mainboard (note Tcon built in) is disconnected.
      Tried inserting firmware on USB and left it in for a few hours, but no change
      03-03-2024, 09:49 AM
    • Green Probe
      Recapping a Denon AVR X6400h SMPS
      by Green Probe
      (TLDR: It was capacitor C6519 [Koshin KZH 50V22uF] and C6515 [Koshin KZH 25V47uF] on the power supply. I have questions at the end)
      Disclaimer: I'm an amateur hobbyist and will get things wrong.
      Always use caution when working around mains power and high voltage capacitors!
      Hey guys, I'm repairing a Denon AVR X6400h for my brother. It quit powering on after a power outage. It acted like this last time there was an outage, but after letting it sit overnight it started working again for a few years. This time letting it sit did not bring it back.
      SYMPTOMS:
      -No display...
      07-18-2025, 03:36 PM
    • CraigR
      Hp Spectra x360 Power light flashing, component id
      by CraigR
      Working on a hp x360 15-eb1043dx that will not turn on and the power light just flashes. It pulls 700ma when flashing. Under the thermocam I found a component I am unable to id that light up. If someone can help would be appreciated. I put the number that are on it in better test....
      05-07-2025, 11:06 AM
    • stephonwhyte
      un65tu7000fxza - Flashing Red Power Light
      by stephonwhyte
      un65tu7000fxza - I am experiencing the flashing red light on the power led. So I purchased the replacement kit for the mainboard and power supply. I still experienced the flash red power light. So I purchased a new ribbon cable, The flashing light stopped for a minute, I could hear sounds on the TV but no picture. I did the 60 second reset and it went back to flashing. What could possibly be the issue now? All the LEDs are lit up from what I can see.
      Thanks for all responses.
      11-22-2022, 12:03 PM
