LG OLED77B29LA shuts itself down/doesn't start
  • ILoveZeroTwo
    • Aug 2024
    • 14
    I'm trying to fix a TV that got damaged by rain (open window during a storm).
    The TV at first would start up and work completely normal, with no lines on the screen or anything. But after about 30 seconds, it turned itself off. After it shut itself down, starting it up directly afterward is no longer possible.
    The standby light is red and it blinks once on the power-on command by the remote. The relay also does not click anymore when plugged into the wall.
    Standby voltages are all present and stable, approximately 13V for the 20V line and approximately 8V for the 12V line. For 2 seconds after pressing the power-on button, the voltages hold their rated values (12V and 20V) but go straight back to standby.
    It turns on again for somewhere between 3-30 seconds after waiting roughly 24 hours. The longer the wait time, the longer it seems to stay on.
    I tested the PSU (3.5V to PWR_ON, 12VT_ON, and DRV_ON) while connected to the TCON and not connected to the mainboard. All voltages were present and stable (12V, 20V to the mainboard, and 12V + 23V to TCON for 10+ minutes).
    On another try, I removed the lower LVDS cable between TCON and the motherboard, with everything else connected, to stop the SOS signal. The relay clicked and the TV started (USB started lighting), but after 30 seconds the relay closed again (no USB light).
    Then I removed the heatsink from the mainboard to check if there were shorts on capacitors or oxidation from the rain, but everything seemed fine. Only the step-down output has a quite low resistance path of 24 ohms to ground, but I don't know whether this is fine or not.
    I also checked all connectors, and they look good.
    I would be glad for any help.
    Click image for larger version  Name:	IMG_20240805_143634.jpg Views:	0 Size:	1.47 MB ID:	3324452 Click image for larger version
ID:	3324451 Click image for larger version  Name:	IMG_20240805_143701.jpg Views:	0 Size:	1.49 MB ID:	3324453 Click image for larger version  Name:	IMG_20240807_165704.jpg Views:	0 Size:	1.64 MB ID:	3324454 Click image for larger version  Name:	IMG_20240807_165720.jpg Views:	0 Size:	1.96 MB ID:	3324456 Click image for larger version  Name:	IMG_20240807_120841.jpg Views:	0 Size:	2.15 MB ID:	3324457 Click image for larger version  Name:	IMG_20240807_120856.jpg Views:	0 Size:	1.70 MB ID:	3324459
  • Diah
    • Feb 2013
    • 6573
    don't do any things... put it under sunshine days long till the wet went out from cells
    • EazyBone
      • Jun 2023
      • 1362
      • United states
      If this got wet, chances are it made it down to the ribbons on the bottom.
      It's not the boards you got to worry about it's the panel.
      I would get a fan and try and put it towards the bottom of the TV not super close to move the water but just to help evaporate it, if there is any openings (usually sealed well) and try and see if any residual water may be in there will evaporate. Id leave it for couple days then try it again. Put the boards on also so they dry out also.
      Then I would try again.
      Edit
      Looks like diah has same idea.. maybe that's better actually so it doesn't move water into places you don't want it.
        • 12330
        • U.S.
        To be safe I think I would give it at least a week to dry out.
        • ILoveZeroTwo
          • Aug 2024
          • 14
          Ok, thanks everyone for the recommendation. I will let it stay for a week and hope for the best.
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4540
            • Italy - Milan
            Hi, how much hot is the temperature there in this time? If it's very hot maybe all tv parts are already dry, this is revealed by the tv fully working for few.. my bet is that one part of a board is severely oxidated, the place where dirt water better stays for long is under the BGA chips.. the most important thing to do is to make a fast self test of the couple PSB+screen, it is already described how to in the other threads, if you come down to a bad main board, well you decide what to do if buy another one or try to fix it, there is a simple fix for it but i can't describe it sorry..
            further tips to test it, locate the bad chip by freezing it with duster spray can, the freezed chip that permits tv to boot or work for longer is the defective one and you can also let to reball it from a repair center.. also the bad chip would get abnormally hot when tv is running "well"..
            • ILoveZeroTwo
              • Aug 2024
              • 14
              Hi, it's mostly between 20-25°C. It was standing for a few days, but with the casing on, so there was only restricted airflow. I will try letting it stand for some time with the covers off in the sun and then try again.
              There was some oxidation on the upper part of the mainboard that I already cleaned, but that didn't cause any shorts (checked the caps and the transistors). I will attach a picture. Everything else looked good. Obviously, I don't know how it looks underneath the BGA. The only other mentionable thing would be that the thermal cooling pad from the MB chip crumbled off. The other ones on the TCON came off easily. I'm not sure if that is a phenomenon of moisture or simply more heat.
              • Diah
                • Feb 2013
                • 6573
                Originally posted by ILoveZeroTwo
                the worse scenario if you have moister went to Panel Module Edge boards.. the idea of EasyBone good that you flip it, but try to use Isopropanol​ 99,9% with spray to wash edge boards and let the alcohol go out as you flip it... then give the time for complete dry.
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4540
                  • Italy - Milan
                  trust me, you don't have to see the oxidation, but is present!, bga balls became unusable, also the cooling pad disntegrated is a sign of very high temperatures.. or mostly direct oxidation of the pad (it is metal added and silicone can develop mould)
                  • ILoveZeroTwo
                    • Aug 2024
                    • 14
                    Quick update for everyone who gave me their advice. I left the TV without a cover for another 10 days, replaced the broken cooling pad on the motherboard, cleaned the LVDS connectors with isopropyl and it is working properly again. It has worked for over 15 hours with no sign of a problem.
                    Thank you all for your advice.
                      • 12330
                      • U.S.
                      glad to hear it, your patience has been rewarded.
                      • Diah
                        • Feb 2013
                        • 6573
                        good done
                        • EazyBone
                          • Jun 2023
                          • 1362
                          • United states
                          Nice!! 🙂
                          • riko 656
                            Lenovo Legion Slim 5 16APH8 (RTX 4070) - Turns on for a few seconds then shuts off. BIOS issue.
                            by riko 656
                            I need help with my Lenovo Legion laptop. It turns on for a few seconds and then immediately shuts down. I believe this is a BIOS corruption issue.
                            Laptop Model:
                            • Model: Lenovo Legion Slim 5 16APH8
                            • GPU: NVIDIA GeForce RTX 4070
                            • Main BIOS chip size: 32MB
                            • VBIOS chip size: 16MB
                            Problem Description: The laptop was working perfectly. Now, when I press the power button, the keyboard lights up and the laptop powers on for just a few seconds, then it shuts itself off completely. After researching, I am convinced it's a corrupt BIOS.
                            What I Have Tried So Far:
                            1. I
                            11-04-2025, 05:14 AM
                          • chaos-theory
                            Asrock z97x starts then shuts off after 4 seconds, sometimes more, no post
                            by chaos-theory
                            I have a really weird problem, this motherboard was working normally, someday it just started and all fans were running but didn't want to post, tried resetting bios, checking CPU and it was getting warm tried external gpu, flashed bios with programmer, but same problem.
                            Next day after several attempts the board goes into protection mode, no more staying on, I turn on the PSU fans starts directly turning, it used to not start until I press the pwr button, now it starts directly and fans spins, and shuts off after 3 seconds sometimes less, then won't start again unless I unplug the PSU and...
                            03-14-2025, 05:37 PM
                          • riki_22
                            ASUS B5402CEA – Laptop powers on for a few seconds then shuts down
                            by riki_22
                            I’m working on an ASUS B5402CEA notebook.
                            B5402CEA_MB_R2.2
                            HA4YT LA-L861P
                            REV:1B
                            The board powers on, fan spins for a few seconds, then it shuts down by itself.
                            I suspect the BIOS might be corrupted.
                            Could someone please check and clean (repair) the attached BIOS dump?
                            I’ve also attached a few photos of the motherboard for reference.
                            Thanks in advance for your help!
                            11-03-2025, 04:38 AM
                          • APOPAP
                            Panasonic National NV-M3 VHS Camera shuts down after some seconds
                            by APOPAP
                            Hello everybody,
                            First post here. I have been reading posts here for some time now, but today I made my first account and post.
                            The same question is also posted on another site, here it is:
                            Just found an old Panasonic National NV-M3 VHS Camera without the original charger but with a special bag with a led, switch and fuse that is designed for a lead-acid 12v 6Ah battery. It has two cables coming off the bag that leads to the camera terminals (Only + and - ). Pretty sturdy design I think.
                            I tried connecting it to a Computer PSU (12.7v) but I get battery error...
                            08-25-2025, 10:12 AM
                          • tec3000
                            Sony LED 65X9005A shuts down after few seconds - looking for help
                            by tec3000
                            Hi community! Germany calling I am wondering if you guys can help me out. I have an issue with my Sony LED TV. I've been told this is a good place to ask. Thanks for anyone who will reply and offer advice. Appreciated!
                            I have a KD-65X9005A Sony 4k LED TV. For a few weeks I've got this problem where I turn on the TV and within a few seconds the TV starts getting darker until it shuts itself off and I get the 4 blinking error code. HOWEVER there is one exception: Whenever I switch to the i-Manual, a full screen on-screen instruction manual, the TV never turns off. I tested for hours!...
                            03-20-2024, 07:29 AM
