Insignia Ns-l22x-10a no picture only sound
You might want to hold up on putting the heatsink back on til after testing, it's ok to test without heatsink on as long as tv is not on for too long. -
For this purpose, there is Hot-melt adhesive STARS-922 HEATSINK PLASTER.
https://aliexpress.com/item/1005004000596248.htmlLeave a comment:
Maybe backlight problem. You can confirm it using flashlight point it to tv screen while tv is power on and check if you can see some display. If have display then you have a problem with your backlight or inverter.Leave a comment:
When i power on the tv a "please wait" image appears then goes away then nothing after that only sound
When i was removing the back cover i heard a rattle.
Removed the metal plate and the heat sink was off (see pic)
would this cause a no picture/image issue?
What is used to put back the heat sink
2 PhotosTags: None
by TR103Hi, I have a Samsung UE50TU with:
- it keeps rebooting
- without cable between mainboard and lcd panel and with a jumpered... -
by MgiffuneI have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started ‘fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
I ordered a supposedly ‘new' Tcon board this time, and... -
by IerwinHello everyone,
Anyway I still fully expect that there has been something seriously damaged... -
by jchangHi all
I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
Symptom:
No picture no sound.
When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
No sound at all.
What I tried:
1. I tried unplugging the left or right ribbon... -
so i took out one of my spare gigabyte ep35-ds3r mobos from storage for use to do some cpu, ram and video card testing of stuff i bought from ebay and got for free from momaka. he bought 50 e8400 cpus for cheap from ebay some years ago and i decided to help him relieve him of some of his supply since he had waaaay too many!!
what did we say about hoarding too much stuff and depriving others of them?! *cough* socialism *cough* lol!
i had to blow some dust off the board and heatsinks with the datavac as i didnt clean it up before putting it in storage. after finishing...-
- Loading...
