Panasonic TC-59R62 Overscan issues. How to adjust?
  • gre0013
    • Jul 2024
    • 4
    Hello. I need help opening the service menu on a Panasonic TC-59R62
    Its an old CRT with bad overscan. The top left of the screen is cut out and I need to adjust it. Ive tried multiple methods online ie, holding volume down on the TV then pressing recall (with the 30m timer as well). Nothing I have tried has been able to bring up the menu if there's one at all.
    Or is there an adapter I could use to fix this? Trying to use the TV for old retro games but again the top left of the screen is cut out and cant see anything displayed there.
  • R_J
    • 9623
    What makes you think there is a service menu? adjustments are likely done with controls on the board depending on which chassis is in this model.
    Is there a chassis number on the rear cover? if not post pictures of the chassis
    • gre0013
      • Jul 2024
      • 4
      So to fix the overscan I may need to open up the unit and mess with the boards within?
      • gre0013
        • Jul 2024
        • 4
        Anyone have any idea how to fix this or am I doomed?
          • 12328
          • U.S.
          This is a good question, haven't dealt with a crt in a long time. Saw this but not sure if it will help with your model tv or not: https://www.youtube.com/watch?v=YDTiqNOtPfE
            LCD LED TV Service Menu Codes
            ALL LCD LED TV SERVICE MENU CODES
            Service Menu Code with Board Name
            China Universal Board / Jumper Board Service Menu Code
            Changhong Ruba Service Menu Code
            Ecostar LED TV Service Menu Code
            Orient LED TV Service Menu Code
            Haier LED TV Service Menu Code
            TCL LED TV Service Menu Code
            Samsung LED TV Service Menu Code
            LG LED TV Service Menu Code
            Videocon LED TV Service Menu Code
            Supra LED TV Service Menu Code
            Toshiba LED TV Service Menu Code
            Symphony LED TV Service Menu Code
            Veste/ LED TV Service Menu Code...
            10-31-2024, 03:58 AM
          • HKS00
            Panasonic CF-20 Track pad issues
            by HKS00
            Hello Everyone,
            My name is Haris and, I am new to the forum. I would appreciate any help I can get.
            Little back story on me and the issues that we are dealing with...
            I work on a fleet that uses Panasonic CF-20s we have about 65 of them. Up until the beginning of the year they all had warranty so all the repairs were covered. Fast-forward to now and all of the units are out of warranty and it can't be extended past this point. We don't have the budget this year to replace them, so we will be stuck trying to fix any issues that may come up.
            03-08-2023, 10:34 AM
          • newgen2005
            Panasonic DMR-ES30V power issues
            by newgen2005
            I picked up a Panasonic DMR-ES30V (UK). When I first plugged in there was nothing, appeared completely dead, I then turned it on and off a couple of times at the mains supply and it came on. It accepts a cassette but then spits it out straight away, the DVD drive functions sometimes but then the unit turns off with nothing on the display. I took the back off and noticed the fan does not spin. The display for the DVD side does seem a little dim when it is working.
            I have looked on google and people say it is most likely a capacitor/s.
            Just looking for some advice on which...
            09-26-2024, 03:49 AM
          • BigPete
            Panasonic Heatpump Dryer Repair
            by BigPete
            I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
            The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
            In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
            Unfortunately the whole machine has to come apart to fix it.
            I have...
            11-01-2025, 06:40 PM
          • sputnikoff
            Roku Rnsmu7536 menu issues
            by sputnikoff
            Hi: I have this Roku rnsmu7536 that has menu all messed up as in short video .Have a suspicion that it's the motherboard.The screen comes on and on screen display keeps going from tv to component to hdmi1 etc keeps cycling....
            09-02-2023, 05:28 PM
