Lg 42ld450
  • sordids999
    • May 2013
    • 2161
    Lg 42ld450
    Hi
    This tv picture is fine but it seems to have like wavy lines going horizontal on the screen and the main board seems to be making a squealing sound,the guy I bought it off said the picture would play up so he had the knock the back of the TV where the main board is positioned
    Any ideas ?
  • sordids999
    • May 2013
    • 2161
    Re: Lg 42ld450
    Opps forgot the picture
      Re: Lg 42ld450
      Try changing input source frequency - one easy way is changing the output of a PS2 or PS3 (over composite video cable, yellow white red) from PAL to NTSC (50Hz/60Hz), or by using a computer and changing the frequency. When you do this, do the lines behave differently?
      • sordids999
        • May 2013
        • 2161
        Re: Lg 42ld450
        http://www.youtube.com/watch?v=isQV2UoS6qc
        tried changing on my pc tom but no difference ive added a short video showing the waves and the noise
          Re: Lg 42ld450
          What voltage do you measure across the 450V capacitors on the power board?
          • sordids999
            • May 2013
            • 2161
            Re: Lg 42ld450
            386 volts
              Re: Lg 42ld450
              Video private?
              • sordids999
                • May 2013
                • 2161
                Re: Lg 42ld450
                Opps public now not sure what happened
                  Re: Lg 42ld450
                  Can't see anything wrong with that image myself. The lines do not change with 50 or 60Hz?
                  • sordids999
                    • May 2013
                    • 2161
                    Re: Lg 42ld450
                    no tom tried 50 and 60 hz the tv has horizontal lines going up and down the video did not really show this but the noise is another thing its coming from the main board
                      Re: Lg 42ld450
                      Can you locate where on the main board the noise is coming from?
                      • sordids999
                        • May 2013
                        • 2161
                        Re: Lg 42ld450
                        hmmm thats going to be hard but ive also noticed to the right of the screen next the the plastic housing blue dotted lines going all the way down and red dotted line going all the way down on the left would have been hard to spot
                          Re: Lg 42ld450
                          Try using a toilet-roll tube to locate the source.
                          • sordids999
                            • May 2013
                            • 2161
                            Re: Lg 42ld450
                            clearer picture
                            • sordids999
                              • May 2013
                              • 2161
                              Re: Lg 42ld450
                              @tom i just put a toilet roll holder over on this part and it stopped the noise
                                Re: Lg 42ld450
                                That looks like a DC-DC converter section. Check the output voltages from the power supply, are they within range?
                                • sordids999
                                  • May 2013
                                  • 2161
                                  Re: Lg 42ld450
                                  Pin 1 nc pin 1 error
                                  pin 2 12v (12.19) pin 2 p.dim (2.48)
                                  pin 3 12v (12.19) pin 3 a.dim (1.70)
                                  pin 4 12v (12.19) pin 4 inv on/off (2.80)
                                  pin 5 gnd pin 5 gnd
                                  pin 6 gnd pin 6 gnd
                                  pin 7 3.5v (3.37) pin 7 3.5v (3.37)
                                  pin 8 3.5v (3.37) pin 8 3.5v (3.37)
                                  pin 9 gnd pin 9 gnd
                                  pin 10 gnd pin 10 gnd
                                  pin 11 20v (20.1) pin 11 20v (20.1)
                                  pin 12 power on (3.0) pin 12 20v (20.1)
                                  • sordids999
                                    • May 2013
                                    • 2161
                                    Re: Lg 42ld450
                                    tom if i touch this with my meter leads the noise goes but comes back after 30 seconds
                                      Re: Lg 42ld450
                                      Confirm full model number of your TV, including the suffix e.g. -XA. It might be written elsewhere on the label. Need to get service manual for this set and check main board voltages.
                                      • sordids999
                                        • May 2013
                                        • 2161
                                        Re: Lg 42ld450
                                        Model 42LD450-ZA
                                        Product code 42LD450-ZA.AEKWLJG
                                        • Tr0ll
                                          by Tr0ll
                                          Original T-con:
                                          First replacement T-con:
                                          10-07-2023, 07:48 PM
                                        • JJAAMM
                                          by JJAAMM
                                          Problem
                                          07-06-2023, 06:01 AM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • CyberPhoenix
                                          Issue with picture quality of Sony bravia TV
                                          by CyberPhoenix
                                          Hello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
                                          01-22-2024, 02:08 AM
