LG 32LX2R No Power
Re: LG 32LX2R No Power
Well what usually happens is you have the 5v going to the main board and it does a few tests and tells the power supply to power up fully to produce the 24v. The test signals are usually 3.3v and 1.8v and these are derived from the 5v on the motherboard using the voltage regulators.
So connect it all up and set your meter on 20vdc put the black lead on the
copper groundscrew pad and test the 5v pin on the main board.
Then for now just try for any voltages on any of the voltage regulators.
I couldnt see any fuses - anything on the back of the board?.
We are really stuck with no camera .Please upload pictures using attachment function when ask for help on the repair
http://www.badcaps.net/forum/showthread.php?t=39740Comment
Hi i couldnt see any fuses either and at about 2am i gave up for the night.
This morning though, a bunch of new caps arrived and after an hour i wished id not asked my brother to order me a new soldering iron because it was clearly a £2.99 special offer that was only worth poking humans with for fun, 28 joints unsolderd and 280 joints resoldered with it and the nibs gone, proberbly melted into the solder, and i have a 3 blistered thumb and a scorched middle finger i poked myself just to test it was actually hot.
Anyhow, They worked
Its sat behind me on right now playing away, it hasnt exploded .... yet, and there was just one disapointment. No freeview tuner built in, shame that, ohwell my sister can have it lol
thank you for confirming the cap problems.
i have just got hold of the same tv with just solid standby light.
took it apart and like you said, all caps look fine, anyway i replaced all caps,and now tv is up and running.
thats what i call a quick fix.Comment
Just got this same set in stuck in standby with red led, Owner says the only way he could get it to work was leave it beside a radiator to heat it up then it would turn on, Does this sound like the same CAP fault? Also was it all caps need replaced or just a few?Comment
Assuming...7 Photos -
by PantherDaveHi all!
https://www.badcaps.net/forum/troubl...-hardware-devi... -
by GLISITHi all,
A few weeks ago I was using the laptop (on battery power) for a Zoom meeting. The battery was running very low (long meeting) but I wasn't worried about... -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
This specification for the HP Pavilion Power Pavilion Power 15-cb009nl Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 15-cb009nl boardview and Pavilion Power 15-cb009nl schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...09-06-2024, 05:59 AM
- Loading...
