If you look at the datasheet you will see the circuit, it is likely that the ic has been damaged, like I said, check the gate resistors and diodes to start.
Sony Bravia KD-50X690E blown resistor
I have no continuity on the following:
R8602
R8603
R8604
R8614
R8617
ZD8601
Is it possible that one bad one can take out the rest? Or does this indicate that the spike went all the way through to the chip?Last edited by x_orange90_x; 07-31-2024, 08:20 PM.Comment
I don't know but have seen strange things from even slightly out of spec resistors, seems like they have been making the tvs too sensitive, is it the feedback section. I think sony is one of the biggest offenders of that.Comment
I don't know if it's the designers that are not totally competent or they are trying their hardest to make the tvs go to shit just out of warranty. I know one thing if a tv goes out on me right after warranty, I'm definitely not going right back to the same brand.Comment
Still haven't figured this out, but I haven't really messed with it anymore either. I'm thinking about ordering that board for $30 and HOPEFULLY get it working. At the start of this I checked the backlights with my tester and they lit. Hopefully they haven't gotten damaged since, somehow.Comment
So I have an update to share. I bought that board from eBay and the TV is alive again! However there is a caveat: a mystical black line that appears and disappears. It seems related to the OSD as well because the 4K X Reality bar across the bottom pops up randomly and brings the line with it.. When that banner goes away the line goes away too. I don't have a remote for it so I can't get into settings to play with anything. It's acting like it's in demo mode or something because it fades in a banner at the top as well that does the available streaming apps. I'm not sure if this is a panel issue, seems like it's not because the line comes and goes with those banners.Attached Filesif you find these attachements useful please consider making a small donation to the site
Nevermind, I'm an idiot! It IS in demo mode. The line is there to show two have of the image, one with a feature ON and the other half with it OFF.
I guess I need to get a remote then so I can get it out of demo mode.Comment
by JUCaESAlHola a todos, necesito el esquema electronico de la placa 1-983-356-11 de un televisor sony bravia KD-65AF9.
Hello everyone, I need the electronic diagram for the 1-983-356-11 board of a Sony Bravia KD-65AF9 television. -
by PopsCapsI have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
I do not hear any sound and I cannot see any backlight.
I have tried disconnecting every cable on each board one at a time to see if anything changes.
The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
My friend ordered another used power supply board but it is also doing the red indicator flash 3 times... -
by alegatorulsony bravia kdl-43w756c, no power, no sound
the charger brick has 19,2-19,3 vcc
changed the inverter board same result.
where should i start?
cheers -
by corrizeHello, I have 2 old chargers for Sony DV, and I found the same resistor fuse dead. Fuse is a crossing component : 0,47 Ohms (0,125W deduced because the lenght is 3mm). But I canāt find the same for buy.
So, I want to replace by another like 0 Ohms, 1 Ohms 0,125W,
It is the same please ? I guess itās the same, the only change should be the time to burn ? Thanks... -
by justin35Hello,
i have this sony bravia kdl-43w755c which boot loops. After sony logo, it shows the android animation loading then it restartsā¦
from what i read online it looks to be an emmc issueā¦
iām not familiar with this kind of tv repairs⦠iām repairing laptops and gpuāsā¦
i took out the board and say an samsung 16gb emmc
i donāt have an exact replacement, but i have a few 32 and 64gb emmsās from laptopsā¦
i could try to put one instead of the 16gb one, but will it work?
where do i get the software from?
any help will be much appreciated!...03-06-2024, 12:26 PM - Loading...
