SHARP 50FN4EA firmware need
  • robertt
    • Nov 2009
    • 11
    SHARP
    Model -50FN4EA
    Chassis:-4T-C50FN4EL2AB
    Main board-T.MT9685.716
    Need firmware,get to the logo and then restarted.
  • shopy
    • Jan 2012
    • 7
    Hello robert
    • shopy
      • Jan 2012
      • 7
      Hello robert
      Did you found this firmware i need it too
      • nomoresonys
        • 12331
        • U.S.
        Whoever owns Sharp these days may be getting creepy about the downloadable updates, I would contact them, tell them you need the latest update or just the firmware. They should be willing to send it to you, the tv isn't very old after all. Not sure off hand if this tv can auto update or if you need the screen and remote or button clicks. As usual start off nice, if they throw up a wall, tell them your blogging about how they wouldn't help you and their products are junk. Looks like sharp is off my list too. If they don't have firmware readily available on their website for a 1 year old tv, then that is a sad disgrace.
        • nomoresonys
          • 12331
          • U.S.
          Maybe try there and pick your area: https://global.sharp/support/download.html#eu
          • robertt
            • Nov 2009
            • 11
            I succeeded, it works with the 50EQ3EA software, if you still need the software I can send it to you
            • raileanu
              TV SHARP LC-26P50E KD186 QKITPD186WJN3 (WE015169S) need working firmware dump set
              by raileanu
              Hi.
              Please if someone help me with a functional firmware dump for this KD186 QKITPD186WJN3 (WE015169S) motherboard from TV SHARP LC-26P50E.
              I think this motherboard it is found in several models.
              What I need is firmware for the NOR chip SST39VF1682 (IC2003) and for the two EEPROMs 24C64 (IC2002) and 24C32 (IC4501).
              I am especially interested in the NOR firmware because I think it has problems.
              The TV initially came only with the red STB LED on and it did not respond to any commands.
              I checked the power supply...
              07-11-2022, 10:07 AM
            • AustinComputerDoctor
              Sharp CC-60LE640U - after mainboard replacement, backlite turns on -- but cannot update firmware / see menu
              by AustinComputerDoctor
              I am looking / wondering if anyone knows where a good firmware download link is for a LC-60LE640U, the sharp support sight says the screen is archived but offers no links.
              I see backlite is active,
              but I cannot get the screen to return back to menus , etc
              This is all after replacing the mainboard...
              any assistance is greatly appreciated.
              03-25-2024, 12:43 PM
            • zklgfs
              Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
              by zklgfs
              I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
              08-11-2025, 02:14 PM
            • gurj1979
              Ubiquiti firmware help. US-8-150W POE
              by gurj1979
              Hi guys.
              I've got a Ubiquiti US-8-150W POE switch which has issues with updating the firmware.
              Turned out to be a bad EEPROM chip. It would read the firmware and work as normal, but failed to write new firmware to it.
              So I took off the chip and read on EEPROM and saved it. Wrote to old chip and failed to write
              Got New chip and writes good.
              THE PROBLEM...
              It fails to fully load the firmware, POE lights fail to work during g firmware test during load. I'm suspecting bad EEPROM Read.
              Does anyone have a Good Firmware I can have?...
              07-22-2024, 05:13 PM
            • vieuxchoub
              29F2G08ABAEA firmware for SHARP TV
              by vieuxchoub
              Hi driends!!!
              I have a SHARP tv LC-60LE652E with a QPWBXG135WJN2 that has its stand-by light blue on but that does not power on.... I have checked the power board which seems fine. Its seems that the defect comes from the main board....
              I would like to flash the nand chip: a 29F2G08ABAEA ic. Has someone its firmware, please?????
              05-17-2023, 12:36 PM
