29F2G08ABAEA firmware for SHARP TV
  • vieuxchoub
    • Oct 2017
    • 34
    • france
    Hi driends!!!
    I have a SHARP tv LC-60LE652E with a QPWBXG135WJN2 that has its stand-by light blue on but that does not power on.... I have checked the power board which seems fine. Its seems that the defect comes from the main board....
    I would like to flash the nand chip: a 29F2G08ABAEA ic. Has someone its firmware, please?????
  • vieuxchoub
    • Oct 2017
    • 34
    • france
    Re: 29F2G08ABAEA firmware for SHARP TV
    I have found my firmware and I post the google drive link: https://drive.google.com/drive/folde...rhHFLWp0UZrZ21
    I hope this may help someone!!!!!!!!
    • lotas
      • Jan 2016
      • 4759
      • Russia
      My firmware did not help you?
      • oabdelmajid34
        • Sep 2022
        • 5
        • morocco
        NEED FIRMWARE
        • MF ELETTRONICA
          Hitachi 32HB4W56I NAND Firmware
          by MF ELETTRONICA
          Hi guys, have a nice day. I wanted to ask if anyone has the bin file for this nand MT29F4G08ABAEA. I'm attaching the model of my TV, the motherboard and the panel number. Please, if anyone can help me, thanks.
          11-28-2024, 02:35 AM
        • duwane
          A2141 (2019 16" MB Pro) Strange macOS install issues. NAND? WIFI? FIRMWARE?
          by duwane
          Hi All.
          Sorry ahead of time for the text wall. This is a strange problem and I have tried to explain it as best I can. I realise this is a hardware forum (mostly), but I am still not sure if this is even a hardware fault! I am hoping that someone more knowledgeable than me in the area of understanding installation logs, or someone that has had a similar issue in the past may have some ideas of what might be causing this.
          The issue:
          Unable to do a clean install of any macOS versions supported for this model, even after fully erasing and formatting the internal SSD,...
          10-26-2022, 07:02 AM
        • yucel-yucel
          Sharp LC-39LE652V Nand Flash
          by yucel-yucel
          Sharp LC-39LE652V model device could not be opened due to nand software error, we rewrote the nand software and it worked. But we were able to find the software without satellite, it does not see the internal satellite. Does this model have a working satellite version and software? Thanks in advance.
          Model ; Sharp LC-39LE652V
          Panel ; V390HK1-LE6
          Mainboard ; QPWBXG135WJZZ
          04-06-2023, 04:57 AM
        • raileanu
          TV SHARP LC-26P50E KD186 QKITPD186WJN3 (WE015169S) need working firmware dump set
          by raileanu
          Hi.
          Please if someone help me with a functional firmware dump for this KD186 QKITPD186WJN3 (WE015169S) motherboard from TV SHARP LC-26P50E.
          I think this motherboard it is found in several models.
          What I need is firmware for the NOR chip SST39VF1682 (IC2003) and for the two EEPROMs 24C64 (IC2002) and 24C32 (IC4501).
          I am especially interested in the NOR firmware because I think it has problems.
          The TV initially came only with the red STB LED on and it did not respond to any commands.
          I checked the power supply...
          07-11-2022, 10:07 AM
        • tranquility
          Onkyo TX-NR809 – no hdmi, DTS or NAND chip ? stuck at starting kernel
          by tranquility
          i want to repair an Onkyo TX-NR809 receiver.
          symptoms:
          on power on, display appears and i hear one click. enue functions is given.
          - no hdmi output
          - audio output not tested, but i think it is not there
          - usb sticks are not recognized
          if i read out the chips with display+standby button + tone+
          both dts show only ????
          chip is D830K013BZKB4
          things i have done:
          - reflow of the dts chip without taking off and reballing
          - changed the aluminium caps without the big one with 25v because i dont...
          08-25-2025, 01:04 AM
