Firmware for 55PFL6008S
  • iganas
    • Mar 2016
    • 14
    • Denmark
    Good day everybody,
    I have just bought a replacement board for a 55PFL6008S TV taken out from a 60PFL6008S. The boards are identical, and the TV boots properly with the replacement, however there is vertical fragmentation in the image, which in my experience is due to incompatible firmware.
    Does anyone have a dump of 55PFL6008S or knows where one could find it?
    Thanks in advance
  • lotas
    • Jan 2016
    • 4524
    • Russia
    Have you tried that?
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4281
      • Italy - Milan
      My suspicion is that repl. board had newer SW than original one and updated tcon SW with the file for 60" one, now if you able to change panel type in SM and able to find newer version of SW then updating the tcon returns correct, or you can force updating keeping OK button or down button with usb flash in when connectiing power plug..
      • iganas
        • Mar 2016
        • 14
        • Denmark
        Thanks for the suggestion, I just did, and seems like the TV did respond to it, but after a reboot the lines/fragmentation is still there
        • Maalobs
          • Jun 2016
          • 120
          • Sweden
          If you go back to the menu again where you entered the Panel ID, has it reverted to the old value?
          As I recall, when you are in the "Factory mode", once you have changed the value you went in there to change, you also have to scroll down to the bottom of the list of values, which is maybe several pages long, and select EXIT_FACTORY or similar at the far end, to persist the changes to the NVM.
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4281
            • Italy - Milan
            These all words spread in the wind without pictures of the defect, especially if both main.board and screen hit by extra tension, so probably bad panel now
            • AustinComputerDoctor
              Sharp CC-60LE640U - after mainboard replacement, backlite turns on -- but cannot update firmware / see menu
              by AustinComputerDoctor
              I am looking / wondering if anyone knows where a good firmware download link is for a LC-60LE640U, the sharp support sight says the screen is archived but offers no links.
              I see backlite is active,
              but I cannot get the screen to return back to menus , etc
              This is all after replacing the mainboard...
              any assistance is greatly appreciated.
              03-25-2024, 12:43 PM
            • NanoTesting
              ThinkPad 11e Chromebook GLIMMER - Dead eMMC 16GB to 32GB replacement and flashing full firmware through programmer
              by NanoTesting
              I got a Chromebook with dead eMMC, so the logical thing to do would be to replace it.
              Its a SDIN8DE4-16G, anything i should know before replacing it with SDIN8DE4-32G?
              Is it possible to flash a full firmware using a CH341 to be able to boot into windows through USB? since that would be way cheaper, better and quicker.
              Or are there any other ways to run mrchromebox script without booting into ChromeOS?
              02-17-2024, 02:06 PM
            • merravid
              Updating Firmware on Toshiba 65X9863DB
              by merravid
              I have a flashing green/red light on this model which then goes to fixed red. No display whatsoever. Voltages at the power supply look OK, so I'm guessing it is a motherboard/firmware issue.
              I've downloaded the firmware for the model and serial number which contains three files:
              mb130_en_bin.gz
              mb130_PM51_connected.bin
              mb130_RomBoot.bin
              usb_auto_update_g10.txt
              Looking at the script file, it look like it wants mb130_en_bin.bin, which is inside the .gz, so I'm guessing I need to extract that before trying to flash?...
              12-01-2022, 03:35 AM
            • sikocan
              NP930XED Samsung Galaxy Book2 Pro Laptop PD Firmware Loop
              by sikocan
              I hope this message finds you well. I wanted to share a recent experience I had with a laptop that had a Type-C Port issue, specifically related to a PD (Power Delivery) controller problem. After replacing the damaged PD controller chip with a new one I purchased from AliExpress, the laptop now charges properly and negotiates power as expected, allowing the device to power up. I've replaced this chip twice just in case.
              However, it seems that the laptop's BIOS is detecting an older version of the PD Firmware on the newly installed chip. As a result, it attempts...
              01-11-2024, 01:47 AM
            • ebugs
              Asus laptop EC/SIO chip replacement
              by ebugs
              Asus Vivobook 15 (board X513ea R2.0) gone dead when user plugged an iPhone cable into the USB-C port during boot. Now there's no LED light, no power at all. I checked all MOSFETs and capacitors, no shorts found. The board only has 3.3V and 5V present, no other voltages.
              I injected 3.3V into the EC chip power rail (ITE IT5125VG 128), and it draws 80mA, while the 3.3V LDO chip RT8249C has a max output of 100mA. I checked the boardview and found there are only two chips on this 3.3V rail, EC and Realtek audio chip. So I think EC could be the problem.
              I found the EC chip...
              09-14-2024, 02:09 AM
