Updating Firmware on Toshiba 65X9863DB
  • merravid
    • Nov 2022
    I have a flashing green/red light on this model which then goes to fixed red. No display whatsoever. Voltages at the power supply look OK, so I'm guessing it is a motherboard/firmware issue.
    I've downloaded the firmware for the model and serial number which contains three files:
    mb130_en_bin.gz
    mb130_PM51_connected.bin
    mb130_RomBoot.bin
    usb_auto_update_g10.txt
    Looking at the script file, it look like it wants mb130_en_bin.bin, which is inside the .gz, so I'm guessing I need to extract that before trying to flash? The RomBoot file is also named differently, do I rename this?
    Just want to make double sure - don't want to risk bricking the mobo (if it's not already).
    Also, someone on some other thread, suggested commenting out the mboot part. Do you suggest I do that? What about the PM.bin part?
    Thanks.
    Code:
    #For pure PM.bin upgrade, use below part
    fatload usb 0:1 0x24000000 mb130_PM51_connected.bin
    spi_wrc 0x24000000 0x00000000 $(filesize)
    #For pure RomBoot.bin (include mboot.bin) upgrade, use below part
    fatload usb 0:1 0x24000000 mb130E_RomBoot_OLED.bin;
    ncishash 0x24000000 0x24010000 0x24020000 0x24030000 0x3800 0x24033800 0x200000
  • anlu
    Vestel Firmware - Toshiba 32W133DN
    by anlu
    Hello, i have an old Toshiba 32W1333DN (sorry, misspelled the headline) TV that had the standby led green/red flashing and no lightup problem, i repaired it by measure the led output as suspect led problem, i measured the LED:s one by one and found one bad led, i replaced the the led-straps and the TV works.
    Now i need to update the software because the new rc "RM-L890" does not work and i think maybe it could be an firmware issue?, i have struggled to find it without any success because all of the links where invalid, i contacted Toshiba but they do not support this model...
    02-04-2023, 12:59 AM
  • DarrenHD
    Firmware for older Toshiba TV 22CV100U
    by DarrenHD
    HI all, Does anyone know if there exists an archive for older firmwares for Toshiba TV's? I've searched all over Toshiba's various websites and also on Dynabook's site (they say they deleted all old firmwares due to "server space". ) Toshiba has not replied to my request.
    I'm looking for Firmware 1.07 for the 19/22/26/32 C100U series as described in this link:
    https://support.dynabook.com/support...tentId=2865076
    Thanks!
    06-16-2025, 11:56 AM
    09-06-2024, 05:27 AM
  • lberkani
    Request: USB firmware for Toshiba 65UL2163DG (Vestel 17MB180E) - panel VES650QNTX-N2-N42
    by lberkani
    I’m looking for the correct firmware for my Toshiba 65UL2163DG TV.
    The mainboard is Vestel 17MB180E, and my panel is VES650QNTX-N2-N42.
    The board I received is flashed for VES650QNDB_N41 and shows double “No signal”.
    I need the correct USB update package (upgrade_mb180.zip / upgrade.bin) for:
    - Toshiba 65UL2163DG
    - Vestel 17MB180E mainboard
    - Panel VES650QNTX-N2-N42
    - Version V1.28.100.0 if available
    If anyone has the file, please share a download link (WeTransfer, MEGA, Google Drive) and include version.txt...
    11-11-2025, 12:37 PM
    09-06-2024, 05:59 AM
