Toshiba/Vestel 50UL2063DB rebooting whenever it feels like
  • spleenharvester
    • Mar 2010
    • 921
    We've had this one about 4 years now, for the past year or so it's been rebooting roughly once a week. Always in the middle of playback from an Xbox Series S. Not sure if hardware or a software configuration issue as we changed our setup a while ago.
    I've tried putting the latest firmware .bin on a FAT32 formatted 4GB USB2 stick, 28617342_MB230_TOSHIBA_QUI_KYLO_V051300_SVN_328380, which I am 95% sure is the correct file. I then tried all the usual Vestel tricks (plug in USB stick, unplug TV, plug in TV while holding OK and/or power button). No response, it just boots straight to the interface.
    EDIT: Nvm just seen the software is already on this version, that's probably why no response I imagine. Any other ideas for what I can try?
    Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
  • spleenharvester
    • Mar 2010
    • 921
    Haven't pulled it apart yet but attached a pic of what should be the PSU board which I found online. 17IPS62 23521004
    E: Just took a look through the vents, it looks like the board is actually a 17IPS72.
    • yokoono
      • Apr 2010
      • 516
      You have the software from the manufacturer below. Unzip and put the 2 files directly on the stick. Try at your own risk.
      https://files.fm/u/fjkfrebkcg
      Valid for 3 days.​
      • spleenharvester
        • Mar 2010
        • 921
        Thanks for this - I tried various files but the TV gets stuck on "Preparing to update..." or something like that. I gave up in the end.
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4546
          • Italy - Milan
          Which is the AV board?
          • Jaime Morillo
            Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
            by Jaime Morillo
            Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
            The TV was stuck on the logo and I couldn't access the update menu.
            I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
            The image result was good, but the image is inverted.
            The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
            Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
            08-18-2025, 11:38 AM
          • TR103
            by TR103
            - it keeps rebooting
            01-22-2025, 04:12 PM
          • Russ17
            Toshiba (Vestel) 50UL2063DB - bad COF?
            by Russ17
            I have a Toshiba 50UL2063DB.
            Most times , screen shows no image, but backlight is on.
            Voltages:
            Vcc = 3.3v
            Vcom, Havdd, Avdd, Vgh & Vgl ate all 0v
            If the right side t-con ribbon is disconnected I can see an image on the left , and get the following voltages on the screen PCB for the left (right side of screen has grey and white bars as there is no ribbon connection):
            Vcc 3.3 = 3.28v
            Vcom = 7v
            Havdd = 7.47v
            Avdd = 16v
            Vgh = 24.7v
            Vgh = -6.9v
            If the left side t-con ribbon is disconnected...
            02-26-2022, 06:26 AM
          • France_53
            Vestel tv, how to flip the image?
            by France_53
            Hello everyone from Italy, I'm here to ask for help on a Vestel TV, I've had a Vestel TV branded "XD" with a broken screen for years, but now I've found a Telefunken (still Vestel but older) and I've mounted the panel on the "XD" TV, it works, but the screen is upside down, given that Vestel does not allow you to rotate the image from the service menu, does anyone know how to solve the problem? the original panel is marked ves315WNDS-2D-N12 while the main board 17mb110, the panel I mounted instead in the tv (from the telefunken) is a ves315WNDA-02. ... It is not worth repairing...
            05-12-2024, 05:22 AM
          • plytek
            Samsung QE50Q60TA rebooting
            by plytek
            Hi all.
            I'm trying to fix my Samsung QE50Q60TA TV.
            IT's rebooting every few seconds.
            I have done some tests and it looks like it stops rebooting when I tape pin 46 (I thinks it's FB_1) on the ribbon tape that connects two boards atteched to screen, but nothing is visible, just backlight is solid and I can hear sound. Taping over other pins doesn't work.
            Have also soldered two pins on the motherboard to check if I can get an image on the rights side of the tv, but it keeps rebooting.
            Can anyone suggest what I can test and do to get it working again please?...
            02-08-2025, 06:02 AM
