Darkened screen Samsung ue75ju6400
  • wreksta79
    • Jun 2024
    • United kingdom
ID:	3291485Click image for larger version  Name:	IMG_0902.jpg Views:	0 Size:	2.65 MB ID:	3291483Hi all I have a ue75ju6400 Samsung tv with a darkened half screen can post pictures
    but when tv first turned on smart displays correctly
    any ideas
  • EazyBone
    • Jun 2023
    • 1362
    • United states
    Looks like your backlights went out. Some of them died
    • wreksta79
      • Jun 2024
      • United kingdom
      But they are all on from. The back
      • EazyBone
        • Jun 2023
        • 1362
        • United states
        I don't think so. Some are on, not all of them. If I saw that picture, I'd buy/pickup that tv because I don't have to diagnose anything, because I can see some of the backlights are out. Unless this is a weird broken screen.
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4542
          • Italy - Milan
          wThis is not bad backlight, is a very common issue with panel signals, more than this i see bad halo / blotches in the backlight, what's the story of the set? Seems someone replaced led strips but misplaced the foils (forgot spacers?)
          • EazyBone
            • Jun 2023
            • 1362
            • United states
            Let's find out. He may reply with that data. I don't see any halo? Also what is the"foil"?
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4542
              • Italy - Milan
              sorry sheets..
              seems.someone already opened it thinking it had to be fixed the leds but misplaced the sheets
              • EazyBone
                • Jun 2023
                • 1362
                • United states
                Haha let's see, I never done that. One time I put back a Toshiba fire TV without the diffuser and put it all back together turned it on and the screen had all the led dots and it was transparent. Very cool looking. I still feel like LEDs are out.
                • Diah
                  • Feb 2013
                  • 6601
                  your case if they were direct LED.. then you have first hard solid plate wrong.. the surface witch not smooth always should be downside..
                  no way to be mistake replanting strips position because the holes of the reflector sheet will not fit in place..
                  to the OP problem... it may broken the stand legs which hold the first plate.
                  Admin cant you fix this..... always text changed... and jumping.... only on your forum..
                  • Chrissygizmo
                    by Chrissygizmo
                    02-10-2025, 12:33 AM
                  • Tom C
                    Samsung QN55Q70AAFXZA Half Screen Dim
                    by Tom C
                    I’m working on a Samsung tv for my son. When I brought it home the left side of the screen was dim, right side ok. I’ve replaced the LED edge strips, main board and now the power board. The only difference is that the dim side has switched from left to right. Is there something else I should be looking at? I’ve also replaced the ground tape (Faraday tape?) from the LCD screen to the chassis. I probably have a week left on returning the parts.
                    Any suggestions would be appreciated.
                    thanks.
                    09-19-2024, 07:22 PM
                  • Chrissygizmo
                    samsung galaxy ao2s very temperamental after screen replaced
                    by Chrissygizmo
                    Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                    Ive eventually managed to get it on and working but it's very temperamental...
                    The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                    05-26-2024, 12:05 AM
                  • JunkmanJimbo
                    Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
                    by JunkmanJimbo
                    Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
                    No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
                    Please help. Thanks in advance!
                    08-12-2025, 11:45 AM
                  • Ryan.man
                    by Ryan.man
                    02-04-2025, 12:23 PM
