I purchased a Samsung Plasma HP-T4264 Model Code HPT4264X/XAA off of Craigslist for twenty bucks. The unit would come on for just a few minutes then shut off. I would turn right back on and then play a few minutes longer and shut off again. I examined all of the caps on the power supply board and they looked good, no bulging or leaking. I removed the power supply and examined the solder joints around the heat sinks and IGBT'S associated with them and found the problem which was solder joints that had broken loose on the heat sink in the center of the board and the IGBT's Connected to it. I re soldered all of the bad joints and the TV has been playing great ever since. I am including a photo of the board with the heat sink circled that had the bad solder joints.
Samsung HP-T4264 Plasma Easy Repair on Power Supply
Re: Samsung HP-T4264 Plasma Easy Repair on Power Supply
Very common to have dry-joints on the devices mounted on heatsinks....
The heat/expansion/contraction on heating/cooling over time stresses out and fatigues the solder--that eventually cracks around the device's pins....
Some models of Sams. destroy the MOSFETS and drive circuits when this happens--Always worth re-soldering with Good Old Fashioned Leaded solder, those connections of things attached to heatsinks....
--The Transformers are also worth checking for similar dry-joints....TELEFIX
Assuming...7 Photos -
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
by cheeky2This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets... -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
by CookybabyHello Everyone, this is my first post and I am excited to be a part of such a great community. I've been reading these forums for awhile and there really is some good friendly people here. No bashing and being rude like 90% of other forums Ive been to. Lets get to the good stuff.
I have two years of college in Electronics Engineering Technology. Ive been tinkering with electronics sine about 1990. I know enough just to be dangerous, so be gentle.
Make: Samsung
Model: UN60ES6500FXZA
Power Supply P/N: BN44-00525A
Symptoms: The TV was... - Loading...
