Samsung QE82Q70RAT no backlight
  • EazyBone
    • Jun 2023
    • 1317
    • United states
    Yes! And that's with TV on? I'll have to look through thread again but I'm positive some of those should be 3 volts. Maybe we on to something
    • EazyBone
      • Jun 2023
      • 1317
      • United states
      Do you have a legend like this one does? If so does it show it as 3v point 1?
      • sansanpartida
        • May 2024
        • 17
        • Spain
        Originally posted by Diah
        the socket between PSU and LED driver boards are rail supply
        we are interesting on the socket between LED driver boards and MB this is the key control of signal
Name:	led driver.png
        So that is what I have on the 16-pin connector CN9001A. (I didn't measure the serial pins since I don't think a reading with the multimeter will be relevant. Just tell me if I should measure it or scope it.)
        Pin Name Measure
        1 GND 0V
        2 SEAMLESS 0V
        3 GND 0V
        4 SCL_LED 2,71V
        5 BLU_ON/OFF 3,223V
        6 TEST_SD 1,38V
        7 SDA_LED 2,70V
        8 GND 0V
        9 TEST_LD 0,9V to 1,2V
        10 VSYNC_IN Skipped
        11 SERIAL_STT Skipped
        12 SERIAL_UHR Skipped
        13 SERIAL_DATA Skipped
        14 GND 0V
        15 GND 0V
        16 CONTACT 0V
Name:	led driver connector.jpg
        • sansanpartida
          • May 2024
          • 17
          • Spain
          You are right I have the pin description table and I'm sorry I cropped it on my previous closeup picture I totally missed it. Here it is and you are right it show 3.3V... Do I have so bad luck that I've managed to order a defective driver board? 😥
          • Diah
            • Feb 2013
            • 6358
            Pin Name Measure
            1 GND 0V
            2 SEAMLESS 0V
            3 GND 0V
            4 SCL_LED 2,71V
            5 BLU_ON/OFF 3,223V
            6 TEST_SD 1,38V
            7 SDA_LED 2,70V
            8 GND 0V
            10 VSYNC_IN Skipped
            14 GND 0V
            15 GND 0V
            16 CONTACT 0V
            MB are fine... driver boards or LED fault
            • EazyBone
              • Jun 2023
              • 1317
              • United states
              #26
              I think also, I was able to find which pin number 1 on that legend was connected to, to the main board connector. When the connector was plugged in (all normal) that pin read 1.4v for me but when I disconnected the connector from LED driver to main and then tested that same pin (now at main board) the voltage was 3v.
              Let me know if that made sense lol.
              And I don't know for sure. But as that picture shows when it was working correctly for me that line was 3v.
              See if you can find the pin 1 is connected to, to the main board
              • sansanpartida
                • May 2024
                • 17
                • Spain
                #27
                Sorry, I don't think I understand your message..
                - If I unplug the cable coming from the motherboard and going to the driver board with the TV ON: I read 0.7V.
                - Then, as soon as I plug in the cable, I have 1.36V.
                • Diah
                  • Feb 2013
                  • 6358
                  I think also,
                  this set had edge or direct LED BL..? if edge tester will report fine but there fault at protect led zener
                  • sansanpartida
                    • May 2024
                    • 17
                    • Spain
                    #29
                    I'll test the backlight again tomorrow. I'm exhausted right now. Can someone write me a quick and comprehensive guide on how to test the LEDs to exclude a faulty LED strip assembly? I quickly tested all the ribbons with 84V and really low current, and the light was really faint. I thought that was OK, but maybe that doesn't mean the strip is fine...
                    Thanks in advance. I really appreciate your help!
                    • EazyBone
                      • Jun 2023
                      • 1317
                      • United states
                      #30
                      This is full array backlights
                      • EazyBone
                        • Jun 2023
                        • 1317
                        • United states
                        #31
                        Turn the tester to max volts/amps like I said. When not touching anything it'll read 330 or something and then when you test each led strip it should give like 100 milliamps and 84.6 (or whatever voltage) across the board then. There will be 64 light strips to test.
                        If you were getting them to light up dimly you were doing it right.
                        Make sure that switch is NOT on 1ma, set it all to max.
                        Then like I said, move down each pin on each side as you were doing. BUT if you don't have the 3.3 V to led driver. That's probably the issue.
                        And as for your 1.4v drops when disconnecting, yes you did that test fine and maybe I was mistaken on my numbers. But I think we are probably in the correct area if that doesn't have 3.3 v with the TV on
                        • sansanpartida
                          • May 2024
                          • 17
                          • Spain
                          #32
                          OK, I was afraid of blowing the LED by putting the tester to 300V max Amp… I'll go to my parents' house in a few minutes and keep you updated.
                          So, to be sure, I'll do the test correctly:
                          Tester on max settings; positive leads to the center of the ribbon and negative to the 8 outermost pins and see if they turn on.
                          Is that right?​
                          • EazyBone
                            • Jun 2023
                            • 1317
                            • United states
                            #33
                            Is that right?​
                            Yea, however you got it to work last time. If you accidentally switch the terminals it just won't work. It shouldn't blow anything no. Yes they find the correct voltage to run through, they also supply like 120mv when then tv turned on will supply like 400mv or much more so it's gonna be fine.
                            Definitely test again, but it's looking like we still found something at the led driver board, or at least that was my problem before and looking like it could be yours also.
                            • sansanpartida
                              • May 2024
                              • 17
                              • Spain
                              #34
                              So far, I'm observing the tester voltage dropping from 300V to 90V each time I touch a connected LED on the ribbon. The light is really faint though. Is this expected behavior? I think I've checked the voltage drop along the entire ribbon but haven't double-checked the light on the other side of the TV each time. Should I verify the voltage drop with a light? My little orange assistant isn't much help, and it's hard to check the ribbon on the backside of the TV and confirm if the LED is on 😅​
                              • EazyBone
                                • Jun 2023
                                • 1317
                                • United states
                                #35
                                If you look through the back of the TV they will light up and can see the light through the holes. But if they all read the same number exactly then I wouldn't try and look at other side (never have). Only if any of them read any number then the exact number would I consider opening the TV up even. This thing is huge to me, so if you had to take the screen off I'd want to be sure.
                                Yes if all 64 tests at 90v then you are probably good on LEDs.
                                • C152Heavy
                                  by C152Heavy
                                  Summary for TL-DR readers:
                                  • VCC pin (18) of PFC...
                                  01-11-2023, 02:53 PM
                                • m1ch43lzm
                                  by m1ch43lzm
                                  05-12-2025, 08:37 PM
                                • ermals
                                  Samsung UN55H8000AF - No Picture, Working Backlight, Replaced T-Con Board
                                  by ermals
                                  Hi all!
                                  I've recently run into an issue with my Samsung UN55H8000AF LED TV displaying no image. I've done quite a bit of research in terms of what could be wrong with it. Below are the steps I've taken prior to reaching out here for some assistance:
                                  1. I've tried replacing the T-Con board (BN95-01594A), twice and have still experienced the same issue with all the boards I've tested with.
                                  2. I've tried to remove one side of the ribbon cable that goes from the T-Con board to the panel and still not getting any image on left or right side.
                                  3. I've checked voltages...
                                  08-01-2022, 10:35 AM
                                • Hink85
                                  Samsung UN65RU8000FXZA Led Driver Board
                                  by Hink85
                                  Hi All,
                                  I picked up a Samsung UN65RU8000FXZA 4k Smart TV a few weeks ago, in hopes I could repair it and get it working. It was purchased in Nov 2019, Samsung already replaced this tv by the original purchaser.
                                  I have eliminated the main board and power supply, and back lights are working. It was cycling on and off when i got it, I disconnected ribbon cables until I pinpointed it down to an LED driver board, and with the suspect board or ribbon cable section, 3/4 of the TV will now stay on and it no longer cycles on and off. I haven't found any shorted capacitors...
                                  08-12-2020, 07:03 AM
