Samsung LED UHD TV - Bad Main Board or Bad T-Con Board? Pictures inside
  • Diah
    • Feb 2013
    • 6556
    so the BL come on and the T-con have 12V when MB disconnected from PSU....
    NO need to do any jumpers... just disconnect the 2 LVDS from T-con side and turn on.. see the screen if it turn on
    • Diah
      • Feb 2013
      • 6556
      Originally posted by E--Man
      Also posting picture of BL ON when PSU disconnected from MB. I notice that the sides of the screen show the BL but not in center of screen. Not sure if this is normal or not based on the technology
      this is just light leaking from the panel rand
      • E--Man
        • Oct 2017
        • 27
        To confirm, you mean with PSU connected to MB or not? If not, all I have is black screen in all cases. How to get pattern test display with PSU to MB disconnected and T-Con in standalone mode?
        What to disconnect from attached picture?
        Do you want me to just test to see if BL will come on?
        • Diah
          • Feb 2013
          • 6556
          PSU disconnect from MB... and 2 LVDS from MB disconnected from T-CON.... so only PSU and T-CON + panel all ribbon should be in place as original
          the screen if turn on color pattern
          • E--Man
            • Oct 2017
            • 27
            Completely understood and did it as per attached picture. When turn on, BL comes on but just black picture no pattern or image. Any way to trigger test pattern?
            • Diah
              • Feb 2013
              • 6556
              only signal generator can trick it.. not yours level sorry..
              put every things back... and fed the set with HDMI signal... let see the screen with signal with out menu
              • E--Man
                • Oct 2017
                • 27
                This is very unfortunate since I took it all apart to get to the BCB. Is there anything I can do before I put it all back together?
                Ideally, I'd like to be able to remove 1 or more connections from the T-Con and STILL have some sort of image displayed. My main issue as it pertains to diagnosis is that as soon as I disconnect ANY connections from the T-Con the BL stays on but there is absolutely no image so it is pointless to disconnect. No way to tell the T-Con to stay on?
                • Diah
                  • Feb 2013
                  • 6556
                  no need to put the back..LOL as its now when you did the test... just put back the LVDS and MB socket back then plug in HDMI signal..
                  from yours Photo at post #11 your screen have white bar and black with out lines.. mean yours panel are fine... now just need to roll out if T-CON or MB, so fed it with signal and show please the result... dont press menu at all.
                  • E--Man
                    • Oct 2017
                    • 27
                    Here you go. The issue seems to mostly be amplified when Brightness setting is lowered for dark/black colors, and whites when the brightness is increased above 80+. Again, the menus seem to be completely not effected.
                    Would really like to know if it's the MB or T-Con!
                    • Diah
                      • Feb 2013
                      • 6556
                      from the photos i would say its 80% T-con fault, as we can see the level of brightness and contrast how it effected , since we have 4 Gamma Chips on the T-CON.
                      don't blame me if my guess were wrong LOL
                      • Diah
                        • Feb 2013
                        • 6556
                        just one Note more from my side... the Fan cooler did it make noise? if it operated with 5V or 12V and there are over load it make it will effect the rail of 5 or 12V. just in case need to check it or try to disconnect it to check if the noise on picture remain or not.
                        • E--Man
                          • Oct 2017
                          • 27
                          Thanks Diah, in that case can you please explain why the menu is completely not effected whatsoever in any brightness setting? As mentioned some, the black areas of the menu are subject to the "Menu Transparency" setting but others menus such as the one I attached have no transparency and those are perfect even at the lowest setting.
                          Asking because I don't want to make the wrong decision since it may not be worth buying more than one board for this TV.
                          • Diah
                            • Feb 2013
                            • 6556
                            the set are Samsung, the firmware based on Linux , Menu are drawing written in format depending on many available such java or xml .. etc no gamma or brightness contrast control them,,, they will appear and take effect from the whole screen setting level. in short word... they are fixed drawing. video signal are another digital data effected with setting..
                            you have 75 Data set. ( Monitor ) with full function screen and BL. i was in hope to test for you T-CON with panel... but this impossible at yours side as we need signal generator ...this why i did judgment with explanation always... just because i am not sure 100% . so i gave 80..
                            look after the FAN note
                            • Diah
                              • Feb 2013
                              • 6556
                              by the way... its curve screen ?? from photo its look curve... if this true...we need to take out the bezel to inspect if there side COF ( this is possible issue too ) as many TVs effected with it.
                              • E--Man
                                • Oct 2017
                                • 27
                                I see. The screen is not curved. Fan seems to be operating normally. Should I measure voltage at the cooling fan?
                                What about using tape to exclude certain pins on LVDS on either the Main board or T-Con board? Might that work and if so how to determine which pins?
                                Thanks again.
                                • Diah
                                  • Feb 2013
                                  • 6556
                                  Thanks again.
                                  the cooling FAN if didn't make noise.. no need to do any messurments
                                  however.. you need to take out the bezel and see if there are side COF...
                                  why i asked this 2 time... because from yours photos i can see BL leaking from left and right side... this mean the screen move from it place... if there are Side COF there thrn the attached ribbon of the COF lost connection to screen glass... and this is happened on many screen so if there are side cof try press with finger on the glass where they attached to... it could the screen come clear---
                                  if no side COF i will try to find other way
                                  • Diah
                                    • Feb 2013
                                    • 6556
                                    well well well... from this photo when you have yes..full level the screen are fine to my eyes.. but this is source HDMI with out signal.... it mean my 80% on T-CON wrong... because you have 4 chips on MB SDP 1301 -3 -4-5 for VIDEO process and upscale .. so the rest 20& add on it 79% MB one of this chips play crazy with us... the rest 1% if there no side COF
                                    • advant
                                      by advant
                                      02-03-2020, 12:25 AM
                                    • ygorsan
                                      by ygorsan
                                      🧩 Problem Summary:
                                      • I
                                      07-28-2025, 08:34 AM
                                    • howardc64
                                      A1312 (27ā€ iMac 2009-2011) A1407 (Thunderbolt Display) A1316 (Cinema Display) Display Black Screen Repair
                                      by howardc64
                                      Problem
                                      08-04-2024, 10:36 PM
                                    • JDC
                                      (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
                                      by JDC
                                      ONN 100012588
                                      Issue: No Power, Then Rebooting After Main Board Change
                                      Short answer: replace main board and power board
                                      Technical answer: replace main board and Q306 & Q307 on power board.
                                      Long answer:
                                      TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
                                      07-15-2022, 07:39 AM
                                    • m1ch43lzm
                                      by m1ch43lzm
                                      05-12-2025, 08:37 PM
