Guide : Philips OLED TVs how to remove the protection mode NVM.EED
  • Diah
    • Feb 2013
    • 6363
    most failure with windows users, they have the option of displaying the hidden extension active, so they rename files and at the end will have 2 extension like upgrade_loader.pkg.pkg
    so need to set the windows explorer option to show files extension.
    at other hand if the Tv blinking red... need to disconnect the lower LVDS between MB and T-CON and do the upgrade or downgrade in blind way till the TV reboot
    • ness4004
      • Feb 2011
      • 5
      #42
      hello, im new here and i have some update regarding blinking red light fast not avbe to flash nvm.eed to disable error. i tried everything and didnt manage to do it. dif usbs, formats, etc. only one time did work and i did the following, disconnect from mains, discconect both lvds from t con comming from MB, put usb with nvm.eed and only then i got the green light on MB working. discconected from mains again put the lvds back in and voila screen came on. now it still going to error after 3 attempts to boot but im working on that. cheers
      philips 55oled803/12
      • ness4004
        • Feb 2011
        • 5
        #43
        quick update when i put nvm.eed on flash tv does nothing. flashes error. when i pit the same file but rename it to nvm.bin tv does flash and turn the mainboard(green leds) shows logo starts to boot and reset it self..does that 3 times and goes to error again(fast flashing red standby led) due to bad LVDS cable (lower one 51pins). waiting for the new cable to continue teouble shooting.
        • ness4004
          • Feb 2011
          • 5
          #44
          still the same thing, nvm.bin turns the screen on, cycles for 3 times crashing on android dots and restarts the problem. ive changed the lower LVDS due to an issue with loosing connection (bad cable) but still the same thing. the mobo is new also and taken from working set (broken screen).
          • ness4004
            • Feb 2011
            • 5
            #45
            quick update, tv only works when i put factory on nvm.eed and the screen is damaged (water damage or moist idk). it doesnt want to disable the error with nvm.eed. only nvm.bin works..i guess ill keep it on factory mode and use it on hdmi as monitor...
            • Diah
              • Feb 2013
              • 6363
              this is above NVM, to handle ignore SOS of Panel. yours ways only like you wrote or the Panel error pins at 51 pins LVDS socket bring it down.. but be aware it could make fire same to to F. Mode, cuting the metal are the best way to have look and test on buffer boards.
              • ness4004
                • Feb 2011
                • 5
                #47
                im using tv as monitor on factory mode for few days now, nothing catched fire or similar. the picture is damaged but tv stays on until i plug it out of socket. im bot shure what to do with pin 51. my lower lvds cable is kinda damaged it looses connection to MB when i touch it with my finger (part that goes to t-con). and since i live in serbia i cant get a replacement...
                • Abulkasam
                  • Jul 2025
                  • United Kingdom
                  #48
                  I have a Philips 65OLED707.
                  The TV was stopping after 5 minutes.
                  So I got a motherboard replacement.
                  The board is the same. However I am stuck on the 4 lights blinking situation.
                  How to identify next steps especially if it's to do with nvm?
                  Which nvm do I need?
                  How to identify the chassis? I don't see it anywhere. Only model and board details:
                  703TQMPL176
                  715GC790-65OLED707-12
                  https://tvonderdelen.nl/en/996592203...scription=true
                  Any steps much appreciated. Happy to jump on a call if you want.
                  Which software.
                  Can you please provide exact steps. (Feel free to write in native language or use chat gpt as needed)
                  • peterkos2
                    • Nov 2020
                    • 42
                    • Slovensko
                    #49
                    Hello. Does anyone have the NVM file for the Philips 50PUS8545/12 TV? Chassis TPM20.1E LA I replaced the mainboard that came from the Philips 58PUS8505 TV and now I have two images side by side. Thank you
                    • peterkos2
                      • Nov 2020
                      • 42
                      • Slovensko
                      #50
                      The original board caused the TV to freeze on the logo after turning it on.
                      • howardc64
                        by howardc64
                        Problem
                        08-04-2024, 10:36 PM
                      • djordje
                        Philips 55 oled 804/12 red light blink
                        by djordje
                        Hello all,
                        I have Philips Oled 55 (804/12) with black screen and red light blink.
                        I have opened TV and tested voltages based on similar oled topics, on power supply board i am getting ps_o/f 3.3v and 5v for t-con_o/f while panel_o/f is 0v. And i get black screen.
                        Also i have done self psb test and i am getting on psb +12V_t and also + 24V for panel. (Measurements on dmm are + 12.3V fot t-con and 22.4 for panel)
                        When i power only psb and tcon with 4 ribbons for panel i only get black screen.
                        My questions is what should i do next...
                        01-03-2025, 04:00 PM
                        ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook Pro 15 OLED Specification for Upgrade or Repair
                        This specification for the ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Vivobook Pro 15 OLED D3500QC-L1351W boardview and Vivobook Pro 15 OLED D3500QC-L1351W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                        09-07-2024, 04:30 AM
                        Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook Specification for Upgrade or Repair
                        This specification for the Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 16 OLED BSF-A3LA964SP boardview and 16 OLED BSF-A3LA964SP schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                        09-07-2024, 07:12 AM
                        Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook Specification for Upgrade or Repair
                        This specification for the Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 OLED BMF-72ESBB4SH boardview and 14 OLED BMF-72ESBB4SH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
