Guide : Philips OLED TVs how to remove the protection mode NVM.EED
  • Diah
    • Feb 2013
    • 6343
    extract the file and put it on the USB to flash it.... only this file on USB no other one... when TV reboot 2 time remove the USB
    • kozejk555
      • Jan 2025
      • 13
      • czech
      thanks but it doesn't work. However, the image is always restarted when loading when the colored balls are moving. It looks like it won't just be an error in the oled. I will still try to install the latest firmware and apply NVM to it.
      • Diah
        • Feb 2013
        • 6343
        use different USB stick small size and formated FAT32 in MBR mode... search how to convert USB Stick in MBR Mode
        TV disconnect it from wall socket then insert the USN then plug it wall socket
        • kozejk555
          • Jan 2025
          • 13
          • czech
          so should I format the usb disk to MBR format and insert it into the TV and not copy anything to the usb?
          • Diah
            • Feb 2013
            • 6343
            after you format it in mbr fat32 only put the file nvm.eed on it
            • kozejk555
              • Jan 2025
              • 13
              • czech
              #26
              I converted the usb drive to MBR and then formatted it to FAT32. I put NVM.eed on the disk but the tv does not boot. The red diode is flashing and I have no picture. If there is NVM.BIN on the disk, the image starts, 4 green LEDs light up on the mainboard, and in the process of loading, when the colored balls move, it falls and starts loading again. I don't know where the error could be. But thank you very much for your help.
              • kozejk555
                • Jan 2025
                • 13
                • czech
                #27
                I have a question for you, the picture is working on the TV, but it crashes when loading the android. I found that the +3.3-NT controlled via Q4101 turns off and that is controlled by +1V1-NT-OK. The control voltage is released by U4103 controlled by BE-PWR-EN. What could be the reason that U4103 stops sending +1V1-NT-OK during loading?
                I have 3.3V on BE-PWR-EN and then it disappears, I think that is the reason​
                • ToL1
                  ToL1
                  • Jan 2025
                  • 6
                  • Norge
                  #28
                  Hi guys, I need some help with my 55oled803. I had 40+ red light blinking error nd have downloaded the NVM file and reset the TV. Everything was working but I was stupid enough to reset the TV through the settings. Now the TV turns on and I can only increase the volume. The red light blinks 6 times nd the screen does not show anything else. I know it's a problem with a main board. I have tried inserting an USB with a software but it would not instal. What do I do?
                  Thanks for any help. I am new to the forum and still learning things.
                  • lotas
                    • Jan 2016
                    • 4458
                    • Russia
                    #29
                    You need service firmware "TPM171E _ 105.001.002.006", regular firmware will not help you.
                    • ToL1
                      ToL1
                      • Jan 2025
                      • 6
                      • Norge
                      #30
                      I have been looking where to download it for a while, maybe you have a link? I would really appreciate it.FOUND IT!
                      • ToL1
                        ToL1
                        • Jan 2025
                        • 6
                        • Norge
                        #31
                        Renamed the file to upgrade_loader, inserted it into USB, turned on the TV and the same thing. Android logo comes on, TV blinks 6 red lights and I can only adjust the volume.
                        • Diah
                          • Feb 2013
                          • 6343
                          yours TV Chassis from 2020 TPM191E
                          ​i think you have already updated the TV via online to android 12, download this last firmware android 11 upgrade_loader on USB stick formatted FAt32 MBR Mode, after it Finnish and reboot play the env.eed file
                          • lotas
                            • Jan 2016
                            • 4458
                            • Russia
                            #33
                            55oled803 - TPM171E
                            https://onedrive.live.com/?redeem=aH...228970&o=OneUp
                            • ToL1
                              ToL1
                              • Jan 2025
                              • 6
                              • Norge
                              #34
                              Hi, lotas I have found the same file and did all of the steps. Tried with two different USBs, both of the TV USB ports. File is upgrade_loader. Downloaded Rufus and formated USBs with MBR mode. The USB sticks light once inserted into USB ports but the situation is still the same. TV turns on, Android logo and just black screen (sound can be adjusted). Is there anything else I can try?
                              • Diah
                                • Feb 2013
                                • 6343
                                Originally posted by lotas
                                55oled803 - TPM171E
                                yes TPM171E typo from me
                                • ToL1
                                  ToL1
                                  • Jan 2025
                                  • 6
                                  • Norge
                                  #36
                                  As I understand since the mainboard is problematic and I tried to reinstall the TV through settings, something happened during the process and the TV is basically stuck now. The problem is that it doesn't not want to start the reinstall process through the USB ports and I looked up the 6 blinking red light error. It has something to do with standby 5v/12v line.
                                  • Diah
                                    • Feb 2013
                                    • 6343
                                    use Disk Part in windows instate of rufus, i wrote how in command
                                    • Diah
                                      • Feb 2013
                                      • 6343
                                      Code:
                                      # Show all disks (aka drives, like hard drives or removable media).
                                      DISKPART> list disk
                                      # Select a disk to operate on.
                                      DISKPART> select disk [number identifying USB flash drive]
                                      # Delete all partitions, resulting in a blank disk.
                                      DISKPART> clean
                                      # If the USB drive is using the GPT layout, the "list disk" command output
                                      # above will show an asterisk in the last "Gpt" column. If this is the
                                      # case, issue this command to change it to the MBR layout.
                                      DISKPART> convert mbr
                                      # Create a primary partition (using MBR).
                                      DISKPART> create partition primary
                                      # Show all partitions (should just be the one newly-created partition).
                                      DISKPART> list partition
                                      # Select the primary partition to operate on (only 1 partition exists).
                                      DISKPART> select partition 1
                                      # Make the primary partition active (aka bootable).
                                      # This command will fail if the USB drive is using the GPT layout.
                                      DISKPART> active
                                      # Format the active primary partition using FAT32.
                                      # To do a full format, instead of a quick format, omit the "quick" flag.
                                      DISKPART> format fs=fat32 quick
                                      # Assign a drive letter to the primary partition
                                      # (just in case Windows didn't already do it).
                                      DISKPART> assign
                                      # Quit DiskPart.
                                      DISKPART> exit
                                      • lotas
                                        • Jan 2016
                                        • 4458
                                        • Russia
                                        #39
                                        Try to first turn off the TV from the network, turn off the power, wait 5 minutes, then insert a USB flash drive (look at the USB socket with the inscription "service", if there is one) and plug it into the socket, if the update does not work, try holding down the OK button on the remote control....
                                        • ToL1
                                          ToL1
                                          • Jan 2025
                                          • 6
                                          • Norge
                                          #40
                                          Tried everything, I give up 😅 Thank you both Lotas and Diah for your time and effort! Really appreciate it! I think I will let the TV sit in a basement and wait for someone who would be selling the same TV with a broken screen.
                                          Best of luck to you all and Happy Easter! 🙂👍
                                          • howardc64
                                            by howardc64
                                            Problem
                                            08-04-2024, 10:36 PM
                                          • djordje
                                            Philips 55 oled 804/12 red light blink
                                            by djordje
                                            Hello all,
                                            I have Philips Oled 55 (804/12) with black screen and red light blink.
                                            I have opened TV and tested voltages based on similar oled topics, on power supply board i am getting ps_o/f 3.3v and 5v for t-con_o/f while panel_o/f is 0v. And i get black screen.
                                            Also i have done self psb test and i am getting on psb +12V_t and also + 24V for panel. (Measurements on dmm are + 12.3V fot t-con and 22.4 for panel)
                                            When i power only psb and tcon with 4 ribbons for panel i only get black screen.
                                            My questions is what should i do next...
                                            01-03-2025, 04:00 PM
                                            ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook Pro 15 OLED Specification for Upgrade or Repair
                                            This specification for the ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Vivobook Pro 15 OLED D3500QC-L1351W boardview and Vivobook Pro 15 OLED D3500QC-L1351W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                            09-07-2024, 04:30 AM
                                            Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook Specification for Upgrade or Repair
                                            This specification for the Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 16 OLED BSF-A3LA964SP boardview and 16 OLED BSF-A3LA964SP schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-07-2024, 07:12 AM
                                            Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook Specification for Upgrade or Repair
                                            This specification for the Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 OLED BMF-72ESBB4SH boardview and 14 OLED BMF-72ESBB4SH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
