Picked up a Sanyo 47 inch for free yesterday plugged it in and the sound comes on and the remote works as far as turning the volume down and changing the inputs but the backlight just strobes on and off. Was thinking maybe the t-con board? any suggestions?
Sanyo dp42647
Tags: None
Re: Sanyo dp42647
continuous once powered up, i left it on for 15 mins to see if there was a change but no changeComment
Re: Sanyo dp42647
OK, do you have a digital multimeter available?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Re: Sanyo dp42647
Start by removing the back cover and getting pictures of the power board.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Re: Sanyo dp42647
Will do, im stuck at my lovely job for the next 3.5 hours but i will get them posted as soon as i get home. already have the back off the television and did a quick inspection of the capacitors, looks like one has been replaced. it has a green mark on the top and is a different color from the rest.Comment
Re: Sanyo dp42647
OK, on the left hand side of the power board you have some connectors for the 24V, etc. What voltage do you get on the pins marked 24V? Multimeter on volts DC (200V/400V if manually ranging), red probe for pins marked 24V, black probe on chassis, and TV powered on with backlight flickering. Observe any noticeable changes in the voltage as it flickers.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Re: Sanyo dp42647
Thank you I will get this done this afternoon after i get out of work or tomorrow and report back.
by cj_rehaHey all
I've been working on a 1984 Sanyo 27" color TV which had a smattering of bad caps in the video switching circuit. I found this oddball little 1uF 25V cap which looks to me like an early polymer, but I can't find concrete info proving it. I know Sanyo was a big player in early polymer cap development and this is the time period where they were just getting on the market, so I'm wondering if anyone has crusty old datasheets that could help identify it and determine if my suspicions are right? It has the same epoxy end seal and font/formatting as some old stock Os-Cons I've got laying...
Channel: General Capacitor Questions & Issues
by toddw65Hey All,
I have a Sanyo DP5834 that did have an issue with the backlights, but I disassembled the unit and repaired the LED strips by resoldering all of the connectors. Now I've reassembled it and I have backlights and sound, but a grayish screen. I can tap on the screen and see that it's on, but no picture. All voltages seem to be correct on the power board.
Based on the LCD Flat panel TV troubleshooting guide by Bud Martin, I'm thinking the T-Con has failed because I'm getting 12v both into and out of FP1 on the T-Con. Am I on the right track?
Thanks,...5 Photos -
by Dan20701Hello all, I have a Dell Latitude 5420, before I upload the bios I thought I would ask. All I am getting is are coloured screens from one colure to another continuous that's all its doing.
I have searched on google some say this is a graphics problem and not a bios problem. I did try another bios file from the forum it stops at the Dell logo.
With the original chip fitted I am getting error code 3 amber and 3 white flashes.
Any advice please ?.09-02-2024, 03:43 AM -
by hugocarmoHi again guys.
Today I have a problem with this Sanyo VCR.
I bought it online, It worked sometimes.
I recap the Power supply and it started working fine.
Image is perfect and all digital effects too.
All of a sudden it stopped outputting sound. I checked for dried solders an all boards and soldered when needed, no fix.
I have no sound on playback, on tuner, or aux in.
On symptom I noticed is when it was working fine, the HI-FI led was on when I power up the VCR, now is OFF, A-B leds are on but when I put a tape they go off.
On one of the sound processing... -
by m4a2t0tWhat type of caps can I use to replace these Rubycon (K) caps? Can I use a film cap? I cant find any aluminum electrolytic caps that go that low. They are .033 uf and .047 uf1 Photo
- Loading...
