Samsung/UN65H6300AF LOGO APPEARS AND SHUTS OFF
  • Super360
    • Jul 2016
    • 243
    Hi as you can see from title, I have a samsung tv here that will show the smart tv logo and then no picture after that even hitting input or menu on remote and shows nothing but the backlight still appears to be on. The tv will turn itself off after a minute or so automatically. I'm somewhat confused if this is either a eeprom problem or a bad led strip problem. The power supply makes a pretty noticeable humming sound when it's turned on leading me to believe one of the leds are shorted but idk honestly. Any of you guys have any help for me? I have a good multi meter and can take pictures of whatever you need. I've also replaced entire led strips in tvs before so I kinda know the symptoms of a bad led tv but this one is throwing me off a bit. Thanks.
  • Bholu
    • 48
    • Saudi Arabia
    My friend, there is a 8 pin eprome ic attached to this board.rilace it with the new one same nomber remember you do not need to program new ic place the ic as it is. Thx
    • Super360
      • Jul 2016
      • 243
      Would this listing be what I would need to buy then?
      thanks.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4333
        • Italy - Milan
        Post the BN44- code of PS board, so i can search good pictures, or report the list of the PSB->MB connector signals..
        My 2 bets are for Bad leds or bad BGA solder on MB..
        • Diah
          • Feb 2013
          • 6376
          you have multi issue to narrow the issue
          1- disconnect the socket between mainboards and powerboards, plug in wall and see if the BL come one and remain... if not... you have many burned area at the powerboards... take it out from the TV and inspect resolder all parts again at any heated burned area at the hot area and cold area... be careful it will still charged at hot area
          • Super360
            • Jul 2016
            • 243
            The small chip is a closeup of the eeprom on the motherboard that bholu pointed to may be the issue.
            • Super360
              • Jul 2016
              • 243
              Disconnected mainboard and left just the led backlight plugged in and the leds light up and remain lit with no mainboard attached.
              • Diah
                • Feb 2013
                • 6376
                use freezer spray on the SPI winbond and the NAND to see if it boot complete.
                • EazyBone
                  • Jun 2023
                  • 1340
                  • United states
                  How often does this work for you? In general.. I have yet to have an instance where this works yet I see the suggestion slot from old posts and different people
                  • Diah
                    • Feb 2013
                    • 6376
                    his issue boot loop, the stage at loop he had just the logo.. this part at SPI, the rest at NAND. if NAND didn't response the SPI will repeat the start script.. freezing both first then each alone later... or you are waiting from me to write replace mainboards !!!
                    • yokoono
                      • Apr 2010
                      • 486
                      For me, nand memory cooling only worked on Samsung and only on the D series.​
                      • Diah
                        • Feb 2013
                        • 6376
                        you are right... but my suggestion never being attempt to repair... its just for diagnose the issue.
                        • lotas
                          • Jan 2016
                          • 4613
                          • Russia
                          The problem here is in the firmware, if you have a programmer, you can reprogram the spi flash (sometimes it helps), if it doesn’t help, then you need to reprogram the eMMC.
                          • EazyBone
                            • Jun 2023
                            • 1340
                            • United states
                            I'm asking how often freezing works lol that's all I want to know.
                            • Diah
                              • Feb 2013
                              • 6376
                              freezing any solid sectors around -40° will hell them.. some forever and some just temporary to let you able to dump the content 100%
                              • Super360
                                • Jul 2016
                                • 243
                                Froze the shit outta those both chips to no avail. Used almost a whole can freezing the whole board and nothing changed. Tv turns on displays the smart tv samsung logo and screen looks like it is on but no picture comes out and no visual. It then shuts off automatically after a minute.
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4333
                                  • Italy - Milan
                                  Does the spy led make a blinking code? Most suspected are all BGA solder on the MB. If it blinks 2 then it is screen.. wait also 2 minutes to get blinking code..
                                  if tcon is separated yo can make screen self test..
                                  • Diah
                                    • Feb 2013
                                    • 6376
                                    it sound firmware or dead eMMC , try download from Samsung usb firmware and try it
                                    • lotas
                                      • Jan 2016
                                      • 4613
                                      • Russia
                                      Froze the shit outta those both chips to no avail. Used almost a whole can freezing the whole board and nothing changed. .
                                      You were hoping for a miracle; freezing cannot restore the data in the chips; only a programmer will help.
                                      • Davi.p
                                        Hobbist Tech
                                        • Sep 2009
                                        • 4333
                                        • Italy - Milan
                                        Ah, yes, also the the firmware in the emmc is suspected as common with stuck logo.. forgot this..
                                          09-07-2024, 05:50 AM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
                                          Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook Specification for Upgrade or Repair
                                          This specification for the Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-X01DE boardview and NP950XCJ-X01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 06:20 PM
