Any help would be greatly appreciated, thank you!
Roku - change display resolution from 55" to 50"?
free from scraps. What can I say?
Any help would be greatly appreciated, thank you!Tags: None -
In the service you need to change the LVDS format from JEIDA to VESA or from VESA to JEIDA.
or change 8bit to 10bit or 10bit to 8bit.
en-US-.pdfAttached Filesif you find these attachements useful please consider making a small donation to the site
Do you know how to get into the service menu on these sets thanksIn the service you need to change the LVDS format from JEIDA to VESA or from VESA to JEIDA.
en-US-.pdfComment
Hi, It seems that i have wiped most of the critical information on this post when uploading images. I have since sorted it and will make a new post when i get a chance.
Would an admin kindly delete this post as i cannot seem to be able to remove it. Thank you all!Comment
by grimacelordHello again. This time it's a TCL 50S425 Roku TV that is stuck in a boot loop.
The TV will power on, display the TCL logo for a few moments, and then the TV restarts in an endless loop. It sounds to me like corrupt firmware.
So far, I have:
1. Disconnected the power cable and pressed and held the power button down for 30 seconds and tried powering on again - No change.
2. Pressed and held the RESET button for up to 60 seconds. - No change.
3. Tried disconnecting power cable in the middle of one of it's loops,... -
by ivtechi guys i have found model:ONN 100005396 roku tv is dead just stays black screen,no back light standby is red,when press ok menu buttom it blinks i can hear the roku sound .
I tried resetting with the remote and power and reset button no luck.
I wonder if the backlight burn out?
I don't have the original remote i have another roku box remote but has no power button, do i need remote power button to turn on tv?i thought when you plug it in it boots like any roku box?
any ideas, tomorrow i'm going to measure some points on the board. -
by nextTVI Have a 75" TCL 8K Roku TV (75R648) that I think has a bad T-CON or LED board.
The TV powers on and has audio, but the screen is grey and cloudy or has digital noise.
I can navigate the menu, but obviously, I can't see what I'm actually doing.
Tried power cycle w/ no results.
Without pulling out the multimeter and testing the individual boards, any ideas about what is going on here?
Images:
by luzminaI had a TCL that I replaced the main board now the picture is upside down, Does anyone know if Roku have a service menu to rotate the screen?
by bobbintbI have a TCL Roku 55S403TCAA. It quit working after a storm. Other electronics quit working as well so I am pretty sure the storm had something to do with it. Anyway, I took a look at it, no obvious damage, blown components, scorch marks, etc. I am looking at the power board first, 40-L141H4-PWG1CG. I've repaired bad caps and blown components but nothing more extensive beyond that. I am trying to troubleshoot it, but I can't even find the fuse on this board. There are markings on the PCB saying "replace fuse as marking" however. I attached a photo of the board. I am also testing the...
- Loading...
