17pw15-8 repair question
  • tn245
    • Oct 2013
    • 530
    I'm doing a repair on this PSU. It seems these boards can either have Q809, or instead IC829 which is a 78L05 regulator.
    According to the schematic the 17pw15-8 should have the Q809 BC548C transistor. The board I have is marked for Q809, but had a 78L05 installed in its place. It looked like original soldering, not someone else's repair attempt but I'm not sure about that.
    So I'm confused, should I replace with the 78L05, or with the transistor?
    Re: 17pw15-8 repair question
    You should check to see if a zener and resistor are installed connecting to that middle ground pin. If not, and the ground pin is grounded, then use a 78L05. Otherwise, use the transistor.
    • tn245
      • Oct 2013
      • 530
      Thanks! There's a low value resistor (~0.2R) instead of the zener connecting the middle pin to ground. The other resistor R851 is not installed. So it looks like the 78L05 is the one to go with then.
      • elviramjw
        • Apr 2013
        • 56
        • uk
        just for reference the posted circuit diagram is WRONG
        ic802 is shown as a IRF7314 (FET) IT IS NOT A FET
        it is a L6562D http://uk.farnell.com/stmicroelectro...?ref=lookahead
        There are people selling repair kits such as Ohms.... & Char...H&S who state they supply the IRF7314
          Yep this is pretty common on Vestel schematics - they will use a footprint that matches, even if the part # is completely wrong!
          • magneh
            Behringer Eurolive B205D repair - help identifying transistor
            by magneh
            Hello
            Got this speaker from a friend , defective. Power led comes on and off , in a loop.
            Disassembled, got the board out, and after a bit of measuring I found a low resistance on a 5v6 line. With a bit of current I found a transistor heating up on that line (labeled T1 and 113 as on pic).
            After removing this guy, I got a value of 0.7 in diode mode on that 5v6 line, which before had 0.02 or something like that.
            I tested powering it up without the IC, and the speaker turns on and stays on, and works fine
            Still, I need to replace this transistor....
            06-18-2025, 02:34 AM
          • elsomer
            help to identify transistor msi ms-15ck1
            by elsomer
            hi people, i need some help to identify a transistor(q14) that is missing on the board, so the gpu has no voltage i think that q14 activate the phases for gpu, but i dont have schematic or boardview, but i think its the same transistor than q15 and q16, thanks...
            02-17-2025, 05:30 PM
          • rddube
            Help with blowing transistor NAD T752 receiver
            by rddube
            I guess I need help from the masters to try and find what is frying a 2SC5669 transistor on the left channel of this front center Amp for a NAD T752.
            Was working perfectly and all of a sudden I heard a pop, and then a glow from the amp. Not only did the 2SC5669 burn a leg, but R520 which is a 220 ohm resistor partially burned - it now measures 110 ohms.
            I bought this amp second hand fairly cheap as it was not working, it went into protection mode. I finally traced it down to the same transistor Q510, the one that just popped. It was shorted...
            09-01-2022, 05:19 AM
          • amigo744
            xbox series x u82 5 pin transistor voltages ?
            by amigo744
            hello there,
            xbox series x hdmi u82 transistor 5 pin,
            can anybody tell me voltages of this transistor in standby and power on mode ???
            on which pin of this transistor are the voltages ?
            regards
            08-16-2023, 08:05 AM
            AO4601 AO4601L Transistor (Applications Laptops) Datasheet
            Complementary Enhancement Mode Field Effect Transistor
            The AO4601 and AO4601L use advanced trench technology MOSFETs to provide excellent RDS(ON) and low gate charge. The complementary MOSFETs may be used to form a level shifted high side switch, and for a host of other applications. Standard Product AO4601 is Pb-free (meets ROHS & Sony 259 specifications). AO4601L is a Green Product ordering option. AO4601 and AO4601L...
            11-05-2024, 08:21 AM
