Lg 50pg20-ua buffer compatibility
+ More Options
Posts
  • crdz66
    • Nov 2012
    • 242
    Hello fellas.
    I'm looking for a advice about buffer board compatible board.
    My plasma tv is lg 50pg20-ua and the bottom buffer board is
    ebr50039107 printed on sticker.
    Can't find this part.
    Do you know if the ebr50039101 it is a compatible board?
    Thanks.
  • cliff_hootarski
    • Jul 2006
    • 411
    Re: Lg 50pg20-ua buffer compatibility
    Did you search eBay for it. Looks like there are several for sale $75 and up.
    • crdz66
      • Nov 2012
      • 242
      Ebr50039107 none on ebay
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • howardc64
        by howardc64
        Problem
        08-04-2024, 10:36 PM
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
      • rustinjust
        Technika lcd 32 - 207, question about board compatibility
        by rustinjust
        My main board is a 17MB12-2 and reads underneath that the following number 160807 LF,
        Question is this board going to fit? ( see link) board is identical but from a different brand of tv but board number is same as in that it’s a 17mb12-2 board
        Link to part here https://www.ebay.co.uk/itm/222990805243
        This board is cheapest I can find. Also note:ordered one that was from a technica, an exact replacement, it arrived yesterday and when I fitted it it was a dead board, didn’t even show the standby light. When I piut the old board back in the tv worked but the issue...
        10-06-2023, 08:53 AM
      • edugimeno
        Vaillant 242 Gas Water heater. Shortcut in board anc compatibility with model 282
        by edugimeno
        Hi!!
        Yesterday I was installing a new Wifi thermostat for my domestic gas water heater model Vaillant 242/2-3, and accidentlly one wire from mains touched one wire from the thermostat output contacts. This shut off the heater so I finished installing the thermostat and then went out to check the heater
        I found one fuse blown (T2 250V). Replaced it with another equivalent fuse and it blew right away. I measured L-N in mains input and I sometimes got 4K but sometimes, not sure why, I got 100 Ohm...
        At a certain point, moving stuff around, I put all wires back in place and...
        03-24-2024, 02:31 PM
