Panasonic TCP50S1 BLINKING TEN TIMES THEN REPEAT
  • Altonwaldon
    • Aug 2013
    • 16
    • usa
    JUST FOUND A PANASONIC TCP50S1 PLASMA IN THE HALLWAY TRASH AREA ITS GIVING THE TEN BLINK CODE THE FIRST THING I CHECKED WAS THE DISCONNECT THE SC CARD POWER AND DATA AND IT GAVE BACK 6 BLINK CODE WHAT DOES THIS MEAN ANY BODY HAVE ADVICE ALSO NO LED'S LIT ANYWHERE ON ANY CARD THE FANS BUMP ON FOR A SECOND THEN STOP BEFORE BLINKING SEQUENCE hheellppp!!!!!!!!!!!
  • tipat
    • Jan 2014
    • 23
    • canadian tire
    Re: Panasonic TCP50S1 BLINKING TEN TIMES THEN REPEAT
    mine got same problem, the sc board was short ,found 7 or 8 igbt short and a small diode .i still wait for 1 part to test it ... check for continuity at conector sc2 if i short the board need repair ..is it a tnpa4782ab ? also check resistance on sd/su board and ss board as well ...if you isolate the sc completely do you get around 200v dc on the power suply the "blue and white" ...when doing this check the led on the ss board. mine glow when sc board is discconect but dont glow when sc is plug that how i determine the ss was good ..
    • tipat
      • Jan 2014
      • 23
      • canadian tire
      found the manual here::
      tgohome.com/ServiceManuals
      • Altonwaldon
        • Aug 2013
        • 16
        • usa
        tipat where do you check continuity for short at the sc board is it at the blue and white wire connector?
        • Hombre
          • Jul 2013
          • 231
          • Croatia
          Yes, that's the one, SC2
          • Altonwaldon
            • Aug 2013
            • 16
            • usa
            I found sc2 connector is not shorted but still no led lit .
            Amended start up symptoms
            1. press start button
            2. red led on front lit 1 second
            3. cooling fans attempt to start simultaneous high pitch sound very faint sound might be from fans, then fans stop sound also
            4.10 blinks begins and repeats
            5. cannot shut off tv with power switch after this have to uplug and then wait 20 minutes minimum to attempt other tests someting staying open after 10 blinks
            I think this is the accurate description for what happens
            • Altonwaldon
              • Aug 2013
              • 16
              • usa
              After isolation of sc board ss led did glow 6 blinks can I isolate ss board should sc board led light ?
              • tipat
                • Jan 2014
                • 23
                • canadian tire
                ok you said the ss board light glow or just the power red light???on the ss board near r032 r031 is locate a small diode d253 that one should glow "green" when power up and the power led should blink 6 time(the sc board must be disconect)that indicate your ss board is ok.... also check the sd/su board resistance.you ave to unplug all conector of the board check resistance betwen vf ground and pin 2 at conector su 41 and sd 42 pin 9 reading should be near 2.4 m ohm (vf ground is where the screw link the sc to sd/su), i speak french sorry for error lol
                • Altonwaldon
                  • Aug 2013
                  • 16
                  • usa
                  thanks I will check these and get back to you guys later
                  • Altonwaldon
                    • Aug 2013
                    • 16
                    • usa
                    when checking su and sd boards do I have to disconnect the ribbon connects as well and the ground screw (vf) is it the middle one where three screws are 1 half inch from each other like this ('.') thanks guys
                    • tipat
                      • Jan 2014
                      • 23
                      • canadian tire
                      i check mine with ribbon cable disconnect and the vf ground screw is the 4 screw that link sc to sd/su..
                      • tipat
                        • Jan 2014
                        • 23
                        • canadian tire
                        check this...
                        • Altonwaldon
                          • Aug 2013
                          • 16
                          • usa
                          Thanks everyone for the extremely helpful info after rechecking all boards I found th sc board connector showing resistance on my auto ranging multimeter jumping around at this connector what should a short read like when I touch my test leads together I read .2 or .1 after a short fluctuation when checking connector at SC board it reads something but never settles down to a steady reading any one understand this also if this board is bad can it be fixed by changing components like caps and does this board have fuse circuit on it
                          • SLB007
                            Panasonic TX-32C300B stanbye light blinking 13 times
                            by SLB007
                            I get no image nor backlight, standby light blinks 13 times then stops. Any clues what it could be no evidence of damaged components
                            11-02-2025, 04:08 PM
                          • ahmarzo
                            Hp 15-cs laptop 5 times dc jack blinking white
                            by ahmarzo
                            I have two laptop hp15- cs1000tx with motherboard part no DAG7BDMB8F0 REV F
                            First one was not powering on when battery is connected the first n channel MOSFET was short and after changing the laptop started on power and battery and charging fine
                            Second laptop has water damaged on ram ic after cleaning and changing the ic the laptop is working fine now
                            But now I have power led continuously blinking 5 times in both the laptop even after shutdown and when it is powered on the led keeps blinking 5 times .both the laptop is charging and working on both battery...
                            12-28-2024, 04:46 AM
                          • YasaCh
                            Sony kdl 40p5500 red light keeps blinking 3 times
                            by YasaCh
                            Hello...
                            my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
                            i opened the back cover no sign of damage on the powery suply or motherboard
                            when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
                            another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
                            07-07-2025, 11:53 AM
                          • CoinCoin88
                            Panasonic PF50G20S blinking 13 times
                            by CoinCoin88
                            Hello there,
                            Google led me again to badcaps when trying to troubleshoot a dying Plasma that is sitting at my uncle's roughly 550 km from where I am. It's an old G20 from 2010 or so, that isn't being actively used so you can consider the panel "not too sollicitated".
                            Symptoms: TV starts, works for 5-10 minutes, then screen turns black and safety kicks in and spits a 13-blink code with the red LED. Once this code kicks in, the TV will not display any image anymore. Unplug it for a few minutes, plug it again, it'll work then fail a few minutes later.
                            06-30-2023, 05:43 AM
                          • NConstantinou
                            DELL INSPIRON P66F BLINKING AMBER 3 TIMES AND WHITE LIGHT 5 TIMES
                            by NConstantinou
                            I REMOVED INTERNAL BATTERIES AND I SUBSTITUTE RAM BUT STILL THE SAME.
                            WHEN I PLUGIN CHAGER I DO HAVE 3.3,5 AND 1.8 V. AND ON PL700 I GET 0.27V.
                            BIIOS PINS 7,8 I HAVE 3.3V
                            IS THE PROBLEM ON MOTHERBOARD OR BIOS.
                            08-21-2025, 03:23 AM
