Panasonic PF50G20S blinking 13 times
  • CoinCoin88
    • Nov 2014
    • 32
    • France
    Hello there,
    Google led me again to badcaps when trying to troubleshoot a dying Plasma that is sitting at my uncle's roughly 550 km from where I am. It's an old G20 from 2010 or so, that isn't being actively used so you can consider the panel "not too sollicitated".
    Symptoms: TV starts, works for 5-10 minutes, then screen turns black and safety kicks in and spits a 13-blink code with the red LED. Once this code kicks in, the TV will not display any image anymore. Unplug it for a few minutes, plug it again, it'll work then fail a few minutes later.
    I pulled a service manual but the blinking chart (p. 18) only goes up do 12. Very useful... Google led me here : https://www.badcaps.net/forum/showthread.php?t=58593 basically pointing towards a failing A-board and suggest for professional intervention. I'm a bit puzzled by the fact that it's for now a non-permanent failure and would have thought about failing PSU (not able to maintain proper load) rather than an IC.
    Any suggestion to troubleshoot more thoroughly ? I don't have my hands on the TV yet and can't ask my uncle to disassemble it.
    Thanks and cheers
  • andrewsawesomr
    • Jun 2022
    • 101
    • United States of America
    Re: Panasonic PF50G20S blinking 13 times
    Can you take the back off the TV and upload pictures of the circuit boards?
    Some common problems on this type of TV include bad capacitors and loose grounding screws.
    • diif
      • Feb 2014
      • 6978
      • England
      I suspect a failing BGA under the processor, it works until it gets hot and then not.
      One or more of the solder balls is cracked.
      • CoinCoin88
        • Nov 2014
        • 32
        • France
        Thanks for the suggestions! I unfortunately won't be at his place for the next month or so but I also had the feeling that it could be something warming up too much, then a safety kicking in (hence having to unplug for a while for things to start working again).
        Baking the A board was on the list of possible ideas (reballing an IC is probably above my competences even if I'm very good with a soldering iron). Possibly also, re-ironing most of the solder joints around it.
        More generally speaking, is there any systematic way to troubleshoot that (undocumented) 13 blinks ?
        • ahmarzo
          Hp 15-cs laptop 5 times dc jack blinking white
          by ahmarzo
          I have two laptop hp15- cs1000tx with motherboard part no DAG7BDMB8F0 REV F
          First one was not powering on when battery is connected the first n channel MOSFET was short and after changing the laptop started on power and battery and charging fine
          Second laptop has water damaged on ram ic after cleaning and changing the ic the laptop is working fine now
          But now I have power led continuously blinking 5 times in both the laptop even after shutdown and when it is powered on the led keeps blinking 5 times .both the laptop is charging and working on both battery...
          12-28-2024, 04:46 AM
        • YasaCh
          Sony kdl 40p5500 red light keeps blinking 3 times
          by YasaCh
          Hello...
          my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
          i opened the back cover no sign of damage on the powery suply or motherboard
          when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
          another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
          07-07-2025, 11:53 AM
        • NConstantinou
          DELL INSPIRON P66F BLINKING AMBER 3 TIMES AND WHITE LIGHT 5 TIMES
          by NConstantinou
          I REMOVED INTERNAL BATTERIES AND I SUBSTITUTE RAM BUT STILL THE SAME.
          WHEN I PLUGIN CHAGER I DO HAVE 3.3,5 AND 1.8 V. AND ON PL700 I GET 0.27V.
          BIIOS PINS 7,8 I HAVE 3.3V
          IS THE PROBLEM ON MOTHERBOARD OR BIOS.
          08-21-2025, 03:23 AM
        • NolesFan
          Sony kd-85x85j LED blinking red 6 times
          by NolesFan
          I know the 6 blinks are a backlighting issue, but when I pulled off the back cover and turn it on, the is a white flash from with the panel then I hear what sounds like a relay trip and the TV goes into the 6 blinking light code. Before I pull all the electronics off and checking the individual strips, there is a on the power board, a harness with 4 wires that run thru the panel, which are what I believe are the LED lines, but Im not a tech so no clue. Wires read OUT 1 + & - and OUT 2 + & - My first inclination was to remove the power board and use my LED tester and go to each + &...
          03-16-2025, 11:50 AM
        • riparo
          Panasonic Oled 55EZ950E, no picture, red led blinking every 4 sec
          by riparo
          Hi everyone, I have a Panasonic OLED TV model 55EZ950E, as soon as I turn it on I don't have any image the LED goes from green to red LED blinking every 4 sec, I found the service manual suggests checking OLED PANEL, PB BOARD, T-CON connectors but it seems like everything ok, I didn't find any burns under the pb board
          I attach a link to download the service manual, thank you for anyone who can help me
          https://tel-spb.ru/download/?brand=P...0E_LA73.rar​
          01-11-2024, 12:35 PM
