Testing LED TV Mainboard without SMPS
  • learnmore
    • Mar 2022
    • 107
    • England
    Hello Community,
    I've been looking at the TV160 mainboard tester for LED/LCD screens and wondered if there was a device for providing the required voltage to test a TV mainboard using the TV160 without the SMPS.
    Doing so may allow me to work on the main board away for the larger unit with the panel and SMPS
    Thanks,
    LL
  • learnmore
    • Mar 2022
    • 107
    • England
    bump 😎, still looking for a way to power any mainboard that test it works by outputting display to a TV160 (mainboard tester), without the use of a SMPS--Essentially freeing myself form being next to the panel and SMPS, while repairing mainboards
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4539
      • Italy - Milan
      Hi, there's not much to know, today's mainb. have one or two supply tensions, the lower is 5v, the higher is 12/16v, some others have 5/12/24, very few have 3,3v, so this means you.80% of the times can drive all things with a common ATX PSU, an old 200w does the job, for.the 24v them are for sound you can avoid them, but not in oled sets..
      • learnmore
        • Mar 2022
        • 107
        • England
        Hey Davi,
        Thanks for the tip. Btw, will I need to solder output wires from the ATX to the 5v and 12v lines on the mainboad? or is it possible to interface a powersupply directly onto the mainboard connector that usually goes to the SMPS?
        As for Oled do you mean I should avoid this method (powering mainboard without SMPS)?
        I've been thinking about this item on Ali, seems to even offer 24v, what do you think?
        https://www.aliexpress.com/item/3305...8dasrTmM2&mp=1
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4539
          • Italy - Milan
          1) remove the correct wires from the normal tv cable by sliding them out the connector using miniature flat screw screwdriver, then cut the normal molex pc connector from the atx and put both atx and tv cables into a screw mammuth connector
          2) sorry, my mistake, also on oled tv the 24v on the MB is for only audio, you can avoid
          • Diah
            • Feb 2013
            • 6564
            TV mainboards wasn't a Radio or simple device / machine to fed it with DC and it will work,
            TVs depending on many sectors one of them AC DETCT , and it sync Return from PSU, also the Firmware script Timing., in time you are thinking you are testing boards... but you are going to killing the boards.
            scripts found in SPI / NOR / eMMC not for cosmetic to show logo or play start sound.. its send IO to turn on and Off exact circuits depending on Timing and steps.
            Mainboards Testing only at own TV PSU., if yours PSU working... so why we need external to testing..?? Chinese simple boards where the LVDS just wires not Ribbon or flat LVDS will not work on modern TVs.
            Modern TVs Mainboards each brands had base station where we can install the MB on it to do test fed firmware and execute scripts for calibration / Testing / diagnose / repair
            • learnmore
              • Mar 2022
              • 107
              • England
              HI Diah,
              Thanks for joining and sharing your knowledge. I've also got a few faulty mainboards and would like to have a go repairing them. In the absence of the original panels and SMPSs, I wondered if there was a way to test them using a portable power supply and a TV160 for a display? I'm hoping the get better at voltage checks, Nor, Nand, emmc, boot loader and firmware updates using programmer and fly wires etc
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4539
                • Italy - Milan
                use atx supply and go in peace..
                • Diah
                  • Feb 2013
                  • 6564
                  Originally posted by learnmore
                  HI Diah,
                  this is swimming in ocean , no end no result... you have defects MB... but did you know whet are the issue... each issue had it own check process... checking volts need service manual to know on which parts you are testing.. ATX we can use only to for testing DC to DC circuits on MB... but is this all you have on MB..? as oi wrote before many include MICOM are depending on IO and this parts with out it yours time and offered like the ocean swimming.
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4539
                    • Italy - Milan
                    Have you got an atx supply? Post a main board example, let we see how to do.. try.at.least, not.much time takes this effort
                    • learnmore
                      • Mar 2022
                      • 107
                      • England
                      Fair enough, I'm going to test the waters. Hopefully I'll learn something by messing aorund with the boards--nothing to loose but some time
                      • learnmore
                        • Mar 2022
                        • 107
                        • England
                        I'm going to post my ATX and the boards if got in a bit, thanks!
                        • learnmore
                          • Mar 2022
                          • 107
                          • England
                          Here are photos of my three test mainbaords and my ATX PSU:
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4539
                            • Italy - Milan
                            i appreciate the effort but these photos are totally waste of space and time, you need to photograph the power supply board silkscreens of signals, so you know which tensions the board needs, you don't have those boards probably but need to search their photos by the web or get manuals..
                            • learnmore
                              • Mar 2022
                              • 107
                              • England
                              Okay
                              • Mirenia
                                Dell Latitude 7420 - Touchscreen not working since Mainboard replacement
                                by Mirenia
                                I've got a little "problem child": my Dell Latitude 7420 2-in-1, which had a faulty mainboard.
                                I replaced it, but ever since, the touchscreen no longer works — and honestly, I’m running out of ideas…
                                In Windows Device Manager, I just see an I2C HID Device with error code 10. Sporadically, the touchscreen is recognized correctly for just a few seconds, but I haven’t been able to determine under which circumstances this happens.
                                The touchscreen also doesn’t work in UEFI/BIOS, although it’s enabled...
                                03-30-2025, 06:47 AM
                              • orcic
                                MASTER TL240 and new mainboard LW36BKC01
                                by orcic
                                I have an old MASTER TL-240 LED TV. Since it stopped working and it had a DVB-T receiver that is being dismissed in Italy, I've decided to replace the mainboard with a DVB-T2 one.
                                The original problem was that when switching on the TV, the power LED was transitioning from red to steady blue, without showing video or audio.
                                After checking some voltages on the power supply board (HKL-240101-B Rev. 1.4, HKL from now on) someone suggested me to replace the mainboard.
                                Now I have some doubts about how to connect the new mainboard to the old power supply.
                                First of...
                                05-12-2023, 08:10 AM
                              • stylishconsultant
                                un60j620dafxza - Samsung No Display Problem
                                by stylishconsultant
                                Hi All,
                                Need help.
                                I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
                                So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
                                problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
                                might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
                                09-04-2024, 03:26 AM
                              • dkneyle
                                Onkyo DX-V500 Laser Disc Player - weird SMPS fault
                                by dkneyle
                                This relic from a technology path that came to a dead end (but still has historical interest) was brought in with a dead SMPS, which is based around a MK1210 device. I got it going after a battle. It seems to have a strange design - if it's not getting feedback that the secondary is OK it cause the big FET to go into full conduction and overloads resulting in a blown fuse at best or something worse! I'm using a Dim Bulb Tester (70W/230V) which thankfully has saved the day a number of times whilst repairing.
                                Now, it loads a CD OK. The motor voltage output (which is built onto the SMPS...
                                02-01-2022, 02:08 AM
                              • shamsudeen
                                Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                                by shamsudeen
                                Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                                I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                                i know that in linear power supply the noise will be very low comparing to SMPS supply....
                                07-19-2025, 07:14 AM
