Philips 58PUS7805 Menu working but no/weird picture from video sources
  • Ierwin
    • Jul 2017
    • 103
    I got a 58pus7805 that shows some weird behavior.
    The menu and remote work fine and the picture is looking crisp and flawless while navigating the menu.
    However, when a video source is displayed the screen either goes solid green (HDMI), solid black (SAT TV) or shows some fragments on mostly green background (AVI Playback from USB).
    I tried to reinstall the firmware through the menu which was rejected saying it already had the latest version.
    I managed to install the latest official firmware by holding the control button while plugging it in, but the behavior remained unchanged.
    Some other minor things I found not working are:
    - the first step of the initial setup is to pair the remote control. The paring starts but never finishes and eventually a message is displayed that pairing was not possible. The remote works just fine in the menu but I assume that voice control will not work.
    - Network connections do not work at all. During installation there is no option to select WIFI but only cable for connection. But even with a LAN cable connected the setup process never manages to connect to the router.
    I will try to connect to the service port using UART and hopefully get some more information.
    If anyone has an Idea what else I could try I would really appreciate the input.
    Best regards
    Ier
  • Diah
    • Feb 2013
    • 6365
    since WLAN disappeared from installation menu mean 2 things
    1- module defect and it caused the rail 5V to disrupted ( remove the module ans check the sources)
    2- some one play before with service menu or replaced MB.. screen option are wrong and could be other value too.
    • Ierwin
      • Jul 2017
      • 103
      thank you for your input.
      I removed the module but it seems to make no difference.
      If the settings in the service menu have been messed with or the mainboard is actually a replacement that maybe came from a different size tv:
      Is there any way to find working settings or fix this?
      I will attach the log I recorded via UART
      • Diah
        • Feb 2013
        • 6365
        from the log. Kernel Panic with USB and wifi both depending on 5V rail, so check this rail DC to DC on MB.
        also write the panel ID as you have on the cover... the last things log in service menu and inspect the info from serial to panel to size
        • Ierwin
          • Jul 2017
          • 103
          I will check the 5v tomorrow.
          For now I already found out that on the rear sticker it says "set option 040".
          A Sticker on the inside that I assume states the panel type says "TPT580F2-PV5D.Q".
          According to the service manual that should be panel ID 155
          I checked the CSM and it shows the same serial number as on the back stricker and the correct set type wit the correct size.
          Panelcode 155 is also set correctly.
          It shows an Ethernat MAC Address but no Wireless MAC Address there (which makes sense because the mainboard cant communicate with the wifi board)
          • Ierwin
            • Jul 2017
            • 103
            Did a quick check on the wifi board when I realized it has very nice labeled test points.
            GND to VCC reads 5.0V
            • Ierwin
              • Jul 2017
              • 103
              New Problem:
              I wanted to make sure that the set option is correct and performed the steps from the service manual shown above:
              062598 + HOME + 040.
              I think I misstyped the 040 when I first did this.
              After the restart the screen was split in half, with both sides showing the same picture that should be fullscreen.
              Since then I have üerformed the same process many times but it never changes back to normal.
              Before I changed anything I made sure to perform every "write to USB" option the service menu has, so I hope I have the original value somewhere in that backup
              *EDIT*
              Fixed that one. Option code 1 and 15 had been changed. I had taken a screenshot of the original values.
              For some reason Option 15 was 155 now and 104 before. I changed it back to 104 and the screen works as before
              • Ierwin
                • Jul 2017
                • 103
                Now I also checked the factory menu (1999 + BACK).
                It shows PANEL_ID 104 so I am starting to lean towards this not beeing the original MB and that some of the settings are wrong.
                Or maybe the panel was changed at some point for the other version in the SM and the sticker wasnt updated
                • Diah
                  • Feb 2013
                  • 6365
                  at this point when VCC 5V exist, then the MT SOC I2C gate one or more suffer from BGA,, so the Kernel panic exist cause no communication
                  • Ierwin
                    • Jul 2017
                    • 103
                    "suffer from BGA" you mean the soldering joints on the chip?
                    • lotas
                      • Jan 2016
                      • 4595
                      • Russia
                      Rather, you need an NVM file. bin for your panel (58PUS7505_NVM...), something like this and update via usb.
                      • Diah
                        • Feb 2013
                        • 6365
                        yes,, take a look at the SOC diagram at yours service manual and you will see it control all ports which at yours set didn't work and make conflict
                          LCD LED TV Service Menu Codes
                          ALL LCD LED TV SERVICE MENU CODES
                          Service Menu Code with Board Name
                          China Universal Board / Jumper Board Service Menu Code
                          Changhong Ruba Service Menu Code
                          Ecostar LED TV Service Menu Code
                          Orient LED TV Service Menu Code
                          Haier LED TV Service Menu Code
                          TCL LED TV Service Menu Code
                          Samsung LED TV Service Menu Code
                          LG LED TV Service Menu Code
                          Videocon LED TV Service Menu Code
                          Supra LED TV Service Menu Code
                          Toshiba LED TV Service Menu Code
                          Symphony LED TV Service Menu Code
                          Veste/ LED TV Service Menu Code...
                          10-31-2024, 03:58 AM
                        • Retro140
                          Unnlock Menu for 2007 DU-27FB32C comerrcial CRT TV
                          by Retro140
                          So I was referred here when I made this poste over on AVForums: https://www.avsforum.com/threads/loc...lg-tv.3257234/
                          To summarize, this is a commercial TV and I can't get a menu of any kind. I know the overlay is working because when I change channel, adjust volume, turn on sleep timer I do see text. But I have not ever seen the user menu nor the installers menu. I've tried a bunch of remotes(more info on the AVF post) and tried every button...
                          06-18-2023, 06:13 PM
                        • G33RT
                          Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                          by G33RT
                          Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                          It does power up when pressing the power button.
                          I already try the power button while plugin the plug with no result.
                          Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                          Could this be an PSU or eMMC issue ?
                          07-19-2025, 03:43 AM
                        • madcrow
                          Tearing-like display artifacts on Philips BDM4065UC
                          by madcrow
                          Hi There,
                          Anyone familiar with this kind of display artifact?
                          Gallery: https://imgur.com/a/tYc2dWK
                          At a superficial glance, it sort of looks like screen-tearing. But that square-wavy boundary is weird...
                          The phenomenon was detected on
                          • 3 screen <=> PC combos consisting of
                          • 2 different screens (same model: Philips BDM4065UC)
                          • driven by 2 different PCs via
                          • 2 different Nvidia GPU models (one desktop, one mobile) multiple generations apart,
                          • running on 3 different Nvidia drivers, each with siginficant age-gap,
                          • under Win10 Pro 22H2.
                          Connections...
                          10-26-2024, 01:38 AM
                        • Rauni
                          Philips 58PUS7805/12 showed no picture; after T-Con replacement, shows halo
                          by Rauni
                          Hello, this is my first post on this forum, and my first attempted to repair a TV.
                          My Philips 58PUS7805/12 stopped working recently. It is not that old, about 5 years. We were on a trip for a few days and when we came back, it had stopped working out of a blue (Perhaps our house was hit by a lightning strike? Don't know.)
                          Read from a guide that I should test if the screen shows picture with one of the T-Con cables disconnected. Did that, it showed perfect picture (first on left, later on right side).
                          Read also that we should test what happens if we...
                          10-01-2023, 12:06 AM
