Polaroid P43D300 (vestel 17MB97) issues (bluetooth & various sw bugs)
  • snimmits
    • Apr 2023
    • 3
    • United Kingdom
    Good afternoon,
    I have a Polaroid P43D300.
    It shipped with WiFi and Bluetooth.
    Two weeks ago, I ran through the first time installation.
    This did a full reset and went through the first time setup.
    Once complete, I went to settings > sound.
    selected Audio Link, changed setting from disabled to enabled, pressed green button on remote and the tv does a search (discovery) for Bluetooth devices.
    search completes and doesn't find any devices.
    I have tried everything I can think of.
    Can someone provide me with the latest software and configuration files for this tv.
    I have pasted as much information as I can from the service menu.
    PANEL:43 VESUNDLN12_2D FHD_D_N_FO_V_97_197571-V2.00 - SVN:INVALID-xxxxxxxx
    PO: POTool MB97 OEM FHD 171413-SVN: INVALID Build Time: 2016-01-04 11:19:38
    PROFILE: 9720EMPOLLO3AGBEN B9GR 1MB8YV12YYYMS21Y0000019243
    HW Profile Version: 111 SW Profile Version: 228 Lang Profile Version: 464
    PEQ FILES: GRUP 1-6W 8W-V001-SVN:INVALID EDID: VES-43FHD LCD
    29.03.2016 17:58:55 CEYHUNH
    iplayer Cert File: Browser Version: Opera3.6
    I hope I can get this tv set fixed, all I did was a factory reset via first time installation and Bluetooth no longer discovers devices.
    King regards,
    Dan.
  • Diah
    • Feb 2013
    • 6376
    tell your mainboards code 17MB ????
    did you play before with profile file editor?
    do you know how to download and upload profiles on the TV or access service menu?
    • vinceroger69
      • Mar 2012
      • 6714
      Just in case you missed it diah the mainboard numbers in the title (vestel 17MB97)
      • Diah
        • Feb 2013
        • 6376
        yes thanks..... you did factory reset from user menu... right? if this is the case you need to log in service menu and from there make hard reset.
        • snimmits
          • Apr 2023
          • 3
          • United Kingdom
          Hi, thankyou everyone for your responses.
          This mainboard is 17MB97
          There is no reset option in the user menu's, you can choose first time installation and this does the factory reset and reboots to the welcome screen.
          I have tried the first time installation from the channel user menu, this does not work.
          I have also tried the factory reset from the service menu (4725) - this does not fix the problem.
          Bluetooth was working fine until I did the first time installation (from channels menu).
          I have tried everything, sw upgrade, checked profile and made some changes - still didnt work.
          I am thinking - in the sw or hw profile - is there any config data to switch on the bluetooth (enable the device).
          I understand that the bluetooth module usually wakes up when you enable a feature that requites bluetooth (for example - Audio Link or Smart Remote) once one of the features is enabled - you can discover devices.
          If there is a simple bit of data to enable the module for the TV explicitly then this could be the cause.
          I have seen in hex that there appears to be some bit of data above the bluetooth features that can be enabled (i.e smart glasses, hid, headset etc) - all these features have a true or false (0 or 1) value to enable them.
          Bluetooth itself may have a value, ill do some trial and error.
          Kind regards,
          Dan
          • Diah
            • Feb 2013
            • 6376
            i don't think yours TV had BT ... if it does then its MAC will show at Service menu register.
            • snimmits
              • Apr 2023
              • 3
              • United Kingdom
              My TV does have Bluetooth.
              I had my wireless speakers connected.
              I have also taken the back off the tv and there is a Bluetooth module connected to the WiFi module by wires.
              If i remove the module and power on tv, the option for audio link and smart remote dissappears.
              The module is set to use MAC from LAN.
              I could try changing this.
              • Diah
                • Feb 2013
                • 6376
                common Man... i will lost all my head hair...LOL
                Speaker LINK ( Smart Remote by Vestel are WIFI link. / View/ Network Remote when TV share at home same Router GATE IP.
                MAC of WIFI will never share with any other module, just because easy things... WLAN Protocol are deterrent from BT Protocol.
                show me please the module
                  • 12206
                  • U.S.
                  Try something simple, unplug all accessories, unplug tv from power, hold power button on tv in for 30 seconds, wait 10 minutes then plug it back in, try un-pairing or repairing.
                    • 12206
                    • U.S.
                    Do you have/did you try other bluetooth devices with with the tv?
                    • Diah
                      • Feb 2013
                      • 6376
                      dont bother when no Photos added..
                      this is his boards and the wifi module.... its wifi direct ( Direct / view / Link and normal 2.4 WLAN function ) had nothings to do with BT. but if he like to add he can add USB BT the linux will install it driver if its kind of plug in driver.
                        • 12206
                        • U.S.
                        Well I'm befuddled, you mean it's a joke and he never had bluetooth on this tv?
                        • Diah
                          • Feb 2013
                          • 6376
                          I don't mean its joke. but many user could think one function its BT but in fact its WIFI
                            • 12206
                            • U.S.
                            Ok, that makes sense, my bad, I had another misinterpretation
                            • lotas
                              • Jan 2016
                              • 4619
                              • Russia
                              It can also be equipped with WI-FI + BT.
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                yes there are a few wifi + bt boards available for this tv model number on uk ebay
                                  • 12206
                                  • U.S.
                                  Thinking this has to be something fairly simple, what are the odds the module went bad at the same time as the reset was done.
                                  • Diah
                                    • Feb 2013
                                    • 6376
                                    good catch Lotas... let see the owner module photo
                                      • 12206
                                      • U.S.
                                      Just to cover the obvious, make sure your device is turned on, is charged or has fresh batteries, and is in range of the tv you want to connect to.
                                      • cheeky2
                                        by cheeky2
                                        05-25-2024, 03:27 AM
                                      • France_53
                                        Vestel tv, how to flip the image?
                                        by France_53
                                        Hello everyone from Italy, I'm here to ask for help on a Vestel TV, I've had a Vestel TV branded "XD" with a broken screen for years, but now I've found a Telefunken (still Vestel but older) and I've mounted the panel on the "XD" TV, it works, but the screen is upside down, given that Vestel does not allow you to rotate the image from the service menu, does anyone know how to solve the problem? the original panel is marked ves315WNDS-2D-N12 while the main board 17mb110, the panel I mounted instead in the tv (from the telefunken) is a ves315WNDA-02. ... It is not worth repairing...
                                        05-12-2024, 05:22 AM
                                      • FlailingEngineer
                                        Help with Bush Tv (Vestel 17mb95m Mainboard)
                                        by FlailingEngineer
                                        Hi, I was recently given a Bush Smart TV by a friend and the main board seems to be hanging on by a thread.
                                        Before we get to that, my first obstacle was figuring out the model number since the back sticker has gone for a walk. Upon taking off the back case, I noticed the following Vestel parts, 17MB95m mainboard, 17IPS71 (what I'd assume is power supply) and a VES420UNVL-3D-S02 display panel. After doing some research I think the TV I have is a Bush ELED42240FHDCNTD3D, based on the matching image here (https://www.manualslib.com/manual/11...td3d.html#manu...
                                        05-31-2023, 06:52 AM
                                      • massimomax
                                        Firmware TV Hitachi 32HE4500 scheda madre Vestel 17MB211S matrice: VES315UNVL-2D-N11
                                        by massimomax
                                        Chiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende più,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
                                        spero che qualcuno può averlo per riprogrammare eprom. grazie
                                        Post in English !!!
                                        I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
                                        02-28-2025, 07:27 AM
                                      • Dr.xyz
                                        Vestel 17MB97 motherboard quirks
                                        by Dr.xyz
                                        Anybody familiar with these?
                                        50" Finlux TV with 17MB97 came in for repair. CPU/SoC was shorted, replaced it with another one from a working 48" donor board.
                                        It appears that software somehow prevents booting if SoC and NAND are not from the same chassis. TV is working if I use also NAND from donor board, problem is that picture is upside down.
                                        Verified this behaviour with two other boards, no boot if SoC and NAND are not from same board, it just keeps flashing stby LED.
                                        I was hoping to retain "identity" and features...
                                        08-16-2020, 06:44 AM
