LG 50PC1DA problem
+ More Options
Posts
  • Glitcher
    • Mar 2013
    • 673
    • USa
    Re: LG 50PC1DA problem
    Not sure if its just your camera or the actual tv itself, but the picture looks oversaturated in pink. (The pink suggests that the Z sus may be going bad)
    But I had one of these sets before with a blown FET on the buffer board. Replaced it, and the TV worked normal again, however half an hour later the FET blew again... So replaced it again with an added heat sink, TV back to normal. Another half hour later.. TV started flickering or eventually gave no picture and a black screen. Turning it off for ten minutes and restarting it, the picture came back but the problem continued like that.
    It seemed to be the Ysus board that was starting to go bad (IPMs probably needed replacing).
    • coopigeon
      • Jan 2014
      • 63
      • united kingdom
      Originally posted by tom66
      Hold on -- could still be a Y-sustain fault. You'd want to check the -Vy, Vsc and Vzbias voltages to be sure... post a picture of the sustain boards if you need help with this.
      Thanks tom .. i got a week off so ill strip it tomorrow and take a load of snaps. I take it the y sustain is different from the buffer boards i had done?
      ill snap everything and post the relavant ones.
      One thing i bever mentioned on my very first post but when i switched in on with original fault (the big white stripe) the tv would only stay on for about 8 seconds then a small pop and went off into standby. i would try it again and after a few switch ons it would stay on for good. since the FETS were done this has never happened so i guess i thought it may have been them being bad that switch it off
      • coopigeon
        • Jan 2014
        • 63
        • united kingdom
        it might just be my camera as was in a darkened room to help emphasize what its doing. the still pic was when attached to a freeview recorder box and as far as i can remember the colors have allways been a bit messed up on that box but you also may be correct. this is becomming a nightmare lol
        • coopigeon
          • Jan 2014
          • 63
          • united kingdom
          Hi
          i have taken some phots see below. Its on and working at the moment but when it starts to flicker there is a ticking noise coming from the y sus area ( the left hand side as you look at it . hard to see if its coming from the ysus itself or the attached buffer boards as they are attached. if you need anymore pics just let me know im at home all day. i have a multimeter turning up this evening for my use.
          pic 2 and 3 are just half and half of pic 1 .
          There is also a quite strong buzz tht sounds like its coming from the longer heatsink on pic 4 area. but this is there even when tv is working ok
          also dont know if this is anything but whenever i turn it on it says poor signal and i have to retune the inbuilt freeview .not once have i been able to switch it on and the channels are there unless i use my external freevie recorder. however it may not be the greatest signal granted but when it is tuned theres hundreds of channels
          i have left it on and so far it has not flickered at all in two hours , wonder is this is because the back is off and cooler
            Try using a hairdryer or hot air wand set to a low temperature - can you get the screen to flicker if either Z-sus or Y-sus are heated?
            • coopigeon
              • Jan 2014
              • 63
              • united kingdom
              #26
              ok i have a hot air gun which ill try .am i ok to do thus with the set on ?
              ill try thr ysus board first then the other one.
              do i need to be heating the whole thing or a selected area?
              thanks again for your replies..
              its just started doing it after 3hrs for seconds then comes back on /off for a minute.
                You can do it with a hot air gun, but keep the temperature as low as possible and if it has any tip on it to focus the heat to a point, remove that. Keep it 3-4 inches from the board. I'd start in the area which is ticking.
                • coopigeon
                  • Jan 2014
                  • 63
                  • united kingdom
                  #28
                  i am heating the ysus . It is flickering all the time now but has been since before i heated it.Shall I heat both boards up let them cool ?
                  • coopigeon
                    • Jan 2014
                    • 63
                    • united kingdom
                    #29
                    the ticking is almost certainly coming from this area somewhere around them fuses or under the top heatsink right next to it
                      That kind of area suggests a Y-sus ER IPM fault. Alastair knows all about these...
                      • coopigeon
                        • Jan 2014
                        • 63
                        • united kingdom
                        #31
                        hi
                        this is the noise
                        https://dl.dropboxusercontent.com/u/...224_124927.mp4
                        and again after being on standby for ten mins i get a poor signal floating around the screen and no tv unless i retune
                        • coopigeon
                          • Jan 2014
                          • 63
                          • united kingdom
                          #32
                          update :
                          so i have been out and came back switched telly on. flickering straight away followed by it being ok for a few seconds on , off on , off then a pop and in standby , when i go to switch on the telly thinks about it then goes back to standby. something has definitely gone now , mulitmeter will be with me within an hour
                          • coopigeon
                            • Jan 2014
                            • 63
                            • united kingdom
                            #33
                            Ok i have multimeter at hand so if anyone can give me any guidance on how and what to check first that would be great .
                            thanks in advance
                              With set powered on and flickering, check voltage across these capacitors on Y and Z-sus.
                              Expected range 80 to 120V steady, and matching other capacitor.
                              (You can test any in that bank - they are all in parallel.)
                              • coopigeon
                                • Jan 2014
                                • 63
                                • united kingdom
                                #35
                                thanks tom , only one problem the tv now longer switches on after something popped this afternoon. light goes to white for about 6 seconds then back to standby and nothing at all comes on screen . something made a largish popping noise and it went off. im hoping this makes things easier to suss out with it not working as opposed to playing up
                                • coopigeon
                                  • Jan 2014
                                  • 63
                                  • united kingdom
                                  #36
                                  can anyone shed any light on what i can check ?
                                  thankyou
                                    I think the ER-IPM has finally failed. You will probably have to replace the Y-sustain which might not be cost effective for an older set like this, needs two new IPMs plus they need to be soldered onto the board which is very difficult. I couldn't do it with my gear...
                                    • coopigeon
                                      • Jan 2014
                                      • 63
                                      • united kingdom
                                      #38
                                      it sounds like im flogging a dead horse with this set now perhaps ?
                                      • coopigeon
                                        • Jan 2014
                                        • 63
                                        • united kingdom
                                        #39
                                        anyone got a manual for this one as ive convinced myself the pop came from the middle power board so just want o have a final look before binning it
                                          Maybe of use:
                                          http://www.tgohome.com/ServiceManual...&Search=Submit
                                          I wouldn't bin it, I see these go on ebay for around £50 with Y-sus faults so I'd stick it on there and maybe someone else will invest the time into fixing it. But they really are a pain in the arse to fix when the IPMs fail.
                                          • theone111
                                            by theone111
                                            3. Problem: TV shuts down
                                            07-22-2024, 10:36 AM
                                          • Zeonalbasta
                                            Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                                            by Zeonalbasta
                                            i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                                            The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                                            09-13-2024, 01:17 PM
                                          • Gibon378
                                            Problem with stopping audio and video for no reason
                                            by Gibon378
                                            PC Specs:
                                            • CPU: Ryzen 5 1600
                                            • GPU: GTX 1080 Palit JetStream
                                            • MOBO: ASRock ab350 PRO4
                                            • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                                            • PSU: XFX 650W (don't remember what model)
                                            • OS SSD: ADATA SP920
                                            • OS: Windows 10 21H2
                                            Problem description:
                                            Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                                            11-19-2022, 09:41 AM
                                          • perzyk23
                                            Lenovo T580 - LCD Panel problem - error 0288
                                            by perzyk23
                                            Good morning,
                                            I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
                                            10-25-2024, 12:42 AM
                                          • SDNarcia
                                            Dell 15R-5521 keyboard problem (KBC?)
                                            by SDNarcia
                                            Hello, I have a Dell 15R-5521, with the problem that the Ctrl, Alt, Shitf and Num Lock keys do not work, I tested the keyboard with a keyboard tester and it is functional, I also got another new keyboard and the computer has the same problem with the same keys. Check continuity between the ZIF connector from the keyboard to the KBC and all pins are correct. I cleaned the ZIF connector and the KBC and I still have the same problem. I reinstalled windows just in case, and it didn't work. I updated the BIOS to the latest version A16 and there were no changes.
                                            As additional information,...
                                            07-20-2024, 10:47 PM
