LG 50PC1DA problem
  • coopigeon
    • Jan 2014
    • 63
    • united kingdom
    #41
    Re: LG 50PC1DA problem
    Originally posted by tom66
    Maybe of use:
    http://www.tgohome.com/ServiceManual...&Search=Submit
    I wouldn't bin it, I see these go on ebay for around £50 with Y-sus faults so I'd stick it on there and maybe someone else will invest the time into fixing it. But they really are a pain in the arse to fix when the IPMs fail.
    Ok tom thanks for your help throughout. ill take a peek at manual then if no good ill sell. how annoying brand new remote just turned up today lol
    • coopigeon
      • Jan 2014
      • 63
      • united kingdom
      #42
      just seen ubuntutorials video of a set same as mine with identical fault. I also have bulging caps and AC D foobed , Is it worth replacing these before as a last ditch . i know on the set he was on the an IPM was knackered in the end but if it hadnt have been would have been a cheap fix.
      what you think/?
        That's my channel. That one turned out to have a bad er ipm as well as bad caps. I think the er ipm was main issue.
        • vinceroger69
          • Mar 2012
          • 6714
          • uk
          #44
          wrong post ignore
          • coopigeon
            • Jan 2014
            • 63
            • united kingdom
            #45
            oh wow was that you tom ! sweet. if the ipm hadnt have been bad would replacing the caps have resolved the issue? how did you find out ipm was bad ? did you replace the caps etc and was still bad.?
              Once we had the caps replaced tv clicked on but the screen just flickered every second or so accompanied by a clicking sound from the er ipm.
              Turned out I was checking ac detect wrong and there was no fault with that.
              • theone111
                by theone111
                3. Problem: TV shuts down
                07-22-2024, 10:36 AM
              • Zeonalbasta
                Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                by Zeonalbasta
                i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                09-13-2024, 01:17 PM
              • Gibon378
                Problem with stopping audio and video for no reason
                by Gibon378
                PC Specs:
                • CPU: Ryzen 5 1600
                • GPU: GTX 1080 Palit JetStream
                • MOBO: ASRock ab350 PRO4
                • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                • PSU: XFX 650W (don't remember what model)
                • OS SSD: ADATA SP920
                • OS: Windows 10 21H2
                Problem description:
                Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                11-19-2022, 09:41 AM
              • perzyk23
                Lenovo T580 - LCD Panel problem - error 0288
                by perzyk23
                Good morning,
                I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
                10-25-2024, 12:42 AM
              • SDNarcia
                Dell 15R-5521 keyboard problem (KBC?)
                by SDNarcia
                Hello, I have a Dell 15R-5521, with the problem that the Ctrl, Alt, Shitf and Num Lock keys do not work, I tested the keyboard with a keyboard tester and it is functional, I also got another new keyboard and the computer has the same problem with the same keys. Check continuity between the ZIF connector from the keyboard to the KBC and all pins are correct. I cleaned the ZIF connector and the KBC and I still have the same problem. I reinstalled windows just in case, and it didn't work. I updated the BIOS to the latest version A16 and there were no changes.
                As additional information,...
                07-20-2024, 10:47 PM
