samsung 32 UE32D400
    samsung 32 UE32D400
    Hi people I have a Samsung tv that is not showing a picture just the back light and it only plays the start up tune when I put a hdmi in it and play my dvd through it I get the sound out of the dvd player but no pic and it only plays the start up tune once I have put the hdmi in thanks
    Re: samsung 32 UE32D400
    So post some pictures of the boards in the set. you could have a blown fuse or a bad panel (water damage, etc.)
      fuse on tcon board? whats the voltage each side of it.
            Cannot get those images to enlarge, can you use Manage Attachments instead?
                  Is there a t-con board?
                    Only other board is one small one across the bottom with 1 ribbon into it from the screen
                      That is a t-con board... non replaceable though. Check if it has a fuse on it, if so, check voltage on both ends relative to chassis ground.
                          I can see one white fuse near the blue cable connector - test as Tom says.
                          There may be others you will need to check
                            12.12v I'm getting from ether side of the fuse
                              See any obvious test points for VGH, VGL and AVDD?
                                No can not see any
                                  I have found a havdd
                                    Is there no way to use manage attachments. Photo is too small to see any detail.
                                      How do I do that
                                        Below the post area there is a button with "Manage Attachments". Click on it, then browse for each file and click Upload.
