AS15-G Chip
+ More Options
Posts
  • kevinm34232
    • May 2012
    • 1884
    AS15-G Chip
    I am replacing another AS15 gamma chip and one of the pads (pin #9) came off on removal of the old chip. The best I can tell scraping the board around where the pad was, there is no traces connected to it. The 2 pads adjacent do have traces. The pin is labeled as "Go" on the datasheet. Does anyone know if I'll be OK? Thanks!
    https://cdn.badcaps-static.com/pdfs/...61ea6520a5.pdf
    Re: AS15-G Chip
    "Go" is probably channel G output, if there is nothing connected to "Gi" (channel G input) you should be OK.
    • kevinm34232
      • May 2012
      • 1884
      Re: AS15-G Chip
      Great it doesn't look like anything comes to "Gi" either, thanks Tom.
      • kevinm34232
        • May 2012
        • 1884
        Re: AS15-G Chip
        That fixed it. TV had bad color/contrast symptom.
        Sony KDL-40Z4100 with T-Con 55.40T02.C06
          Re: AS15-G Chip
          Interesting, did not know 40" panels were affected too.
          • kevinm34232
            • May 2012
            • 1884
            Re: AS15-G Chip
            I've had this problem mostly in 40" models, and some 37". I love when I find them.
              Re: AS15-G Chip
              AU Optronics, Chi Mei, Samsung, Chungwha panel?
              • kevinm34232
                • May 2012
                • 1884
                Re: AS15-G Chip
                AUO T400HW01 V.3
                I think almost all I have done have been AUO panels.
                • Glitcher
                  • Mar 2013
                  • 673
                  • USa
                  Re: AS15-G Chip
                  Oh I had the same model sony with the same brightness contrast problem. Turned out to be the AS15 chip, but for some reason it was much harder to remove than the other tcons ive done. Ended up ripping off 10 traces and had to do a crazy wiring job for it...
                  • Nick's Tvs
                    • Jan 2014
                    • 621
                    Re: AS15-G Chip
                    Just got one of these panels with T-con 55.40T02.C06 however I can not find the chip for sale. Does anyone know where I could find it. Shopjimmy is out, even though there amazon listing says they have some.
                    Not really sure where to look.
                    Any help would be appreciated.
                    • Alastair E
                      Chief Womble
                      • Mar 2013
                      • 1963
                      • U.K.
                      Re: AS15-G Chip
                      Ive bought 'em on ebay in the past. Guess I must have been lucky, never had any problems with any of 'em--but some guys have....
                      I don't think these chips like too much heat when you change 'em--so keep in mind when fitting...
                      TELEFIX
                      • diif
                        • Feb 2014
                        • 6978
                        • England
                        Re: AS15-G Chip
                        I've got mine from AliExpress, and to echo what Alastair says they are sensitive to heat.
                        • Hamie
                          • Apr 2014
                          • 1383
                          Re: AS15-G Chip
                          As15-f is the same as as15-g
                          • Nick's Tvs
                            • Jan 2014
                            • 621
                            Re: AS15-G Chip
                            http://www.aliexpress.com/item/10PCS...467117129.html
                            Ok buying these guys and then some for future.
