AS15-G Chip
+ More Options
Posts
  • kevinm34232
    • May 2012
    • 1884
    AS15-G Chip
    I am replacing another AS15 gamma chip and one of the pads (pin #9) came off on removal of the old chip. The best I can tell scraping the board around where the pad was, there is no traces connected to it. The 2 pads adjacent do have traces. The pin is labeled as "Go" on the datasheet. Does anyone know if I'll be OK? Thanks!
    https://cdn.badcaps-static.com/pdfs/...61ea6520a5.pdf
    Re: AS15-G Chip
    "Go" is probably channel G output, if there is nothing connected to "Gi" (channel G input) you should be OK.
    • kevinm34232
      • May 2012
      • 1884
      Re: AS15-G Chip
      Great it doesn't look like anything comes to "Gi" either, thanks Tom.
      • kevinm34232
        • May 2012
        • 1884
        Re: AS15-G Chip
        That fixed it. TV had bad color/contrast symptom.
        Sony KDL-40Z4100 with T-Con 55.40T02.C06
          Re: AS15-G Chip
          Interesting, did not know 40" panels were affected too.
          • kevinm34232
            • May 2012
            • 1884
            Re: AS15-G Chip
            I've had this problem mostly in 40" models, and some 37". I love when I find them.
              Re: AS15-G Chip
              AU Optronics, Chi Mei, Samsung, Chungwha panel?
              • kevinm34232
                • May 2012
                • 1884
                Re: AS15-G Chip
                AUO T400HW01 V.3
                I think almost all I have done have been AUO panels.
                • Glitcher
                  • Mar 2013
                  • 673
                  • USa
                  Re: AS15-G Chip
                  Oh I had the same model sony with the same brightness contrast problem. Turned out to be the AS15 chip, but for some reason it was much harder to remove than the other tcons ive done. Ended up ripping off 10 traces and had to do a crazy wiring job for it...
                  • Nick's Tvs
                    • Jan 2014
                    • 621
                    Re: AS15-G Chip
                    Just got one of these panels with T-con 55.40T02.C06 however I can not find the chip for sale. Does anyone know where I could find it. Shopjimmy is out, even though there amazon listing says they have some.
                    Not really sure where to look.
                    Any help would be appreciated.
                    • Alastair E
                      Chief Womble
                      • Mar 2013
                      • 1963
                      • U.K.
                      Re: AS15-G Chip
                      Ive bought 'em on ebay in the past. Guess I must have been lucky, never had any problems with any of 'em--but some guys have....
                      I don't think these chips like too much heat when you change 'em--so keep in mind when fitting...
                      TELEFIX
                      • diif
                        • Feb 2014
                        • 6978
                        • England
                        Re: AS15-G Chip
                        I've got mine from AliExpress, and to echo what Alastair says they are sensitive to heat.
                        • Hamie
                          • Apr 2014
                          • 1383
                          Re: AS15-G Chip
                          As15-f is the same as as15-g
                          • Nick's Tvs
                            • Jan 2014
                            • 621
                            Re: AS15-G Chip
                            http://www.aliexpress.com/item/10PCS...467117129.html
                            Ok buying these guys and then some for future.
                            • acedogblast
                              by acedogblast
                              11-02-2024, 05:13 PM
                            • BMCappelletti
                              Asus Chromebox CN62 - wrong chip put on BIOS reader
                              by BMCappelletti
                              Long story short:
                              - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
                              - gave the computer to his son a couple years later
                              - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
                              - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
                              (seems like the story was not that short)
                              He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
                              01-08-2025, 07:27 PM
                            • Troystain
                              Help EZP2023+ updated chip database for w25q256jveq?
                              by Troystain
                              Hello, anyone here have updated ezp2023+ chip database in .dat file format.
                              I need to add w25q256jveq chip but I do not know what data should I type.
                              I'm using the ezp chip dabase editor posted from here https://www.badcaps.net/forum/troubl...ro-programmers
                              The currenty unit model that I am trying to detect is HP elitebook 640 g9 which is currently locked on admin bios....
                              11-25-2024, 12:53 AM
                            • inck243
                              Acer e15-e5-576g-5762 bricked. Bios chip won't interface in AsProgrammer.
                              by inck243
                              Thanks for any help. The board version is DAZAARMB6E0 REV: E. The bios chip is winbond 25Q64JVSIQ1736. W25Q64JV is not available in AsProgrammer -- only BV CV FV or FW_1.8c. The chip won't interface with asProgrammer and a CH341A. When I have this chip on the board, the laptop will not post but when I plug it in to power, the blue LED lights up, also the orange when the battery is connected. When I push the power on button, keyboard backlight turns on and the fan starts briefely then turns off. But I can't do anything to program this bios chip so I bought another one.
                              The BIOS...
                              07-25-2024, 09:17 AM
                            • thxd43
                              Lenovo laptop does not turn on, what does this number mean in a BIOS chip?
                              by thxd43
                              Hello, first of all, excuse me, I am using the translator, English is not my native language.
                              I have a Lenovo ideapad 330S - 14IKB laptop.
                              The tablet did not recognize me when I connected it, so I checked the device manager and I realized that there were many with the exclamation mark, so one by one I began to update their drivers until the sign disappeared of admiration, I even updated the BIOS, and the laptop rebooted normally and worked, so far so good, but the tablet still did not recognize me, I read on the internet that it could be due to a...
                              02-23-2023, 08:37 PM
