Hello every one, fist thanks for having me here, i have very limited knowledge on electronics, still learning how to use a DMM. i bought this vizio for $30 off craiglist, so far i had check caps and volts on the power supply all good, bought an used tcon board from ebay that didn't fix anything, here are some pics of my tv
Lost with this vizio 32" VA320M
Re: Lost with this vizio 32" VA320M
im going to say panel fail,can you twist the frame,does anything change?Hello every one, fist thanks for having me here, i have very limited knowledge on electronics, still learning how to use a DMM. i bought this vizio for $30 off craiglist, so far i had check caps and volts on the power supply all good, bought an used tcon board from ebay that didn't fix anything, here are some pics of my tvfixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully! -
thanks for the reply, i took the frame off, i twisted i pressed the edge and still the same, when i take the t-cons ribbons off the panel this is what i getAttached Filesif you find these attachements useful please consider making a small donation to the site
try cleaning the ribbon contacts with iso,alc,and reinstall
it still could be tcon,panel,or mainboard issuefixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!Comment
Assuming...7 Photos -
by mrtekHi.
picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED... -
by howardc64Failure Symptom
No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
Where is the short?
Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but... -
by bobbyskillzHello, experts! I have a weird issue I've never seen before. I know some of you have definitely seen this. I think some have seen in. I'd greatly appreciate any advice you can give me.
I bought a E241i-a1 to use as a monitor. It powers on, displays the image, and has sound. I just can't get the OSD to go away. The TV doesn't respond to any input from the remote contol or buttons except for the power button. Is this a firmware issue? I can't access settings to reset it. A quick search for the firmware has no results. I'm lost. Please throw some ideas at me.
Thanks for... -
by JohnJonesMy Vizio P702ui-B3 won't turn on if the power goes out and comes back on. I have to unplug the TV for several hours before it will work again. If I plug it in too soon, I have to start the whole wait all over again. Any idea what might be wrong with it?07-22-2021, 09:59 PM
- Loading...
