Element Main Board CV318H-T Reverse Picture Problems
    Hi everyone!
    I have an issue with an Element ELDFW407 TV. The original CV318H-T (1205H0911A) main board displayed red only on the screen for television reception only. So I replaced the CV318H-T board (28H1494A) and all color is restored. Problem is the screen is upside down. I also believe control switches are in reverse. Has anyone seen this and if so is there a solution for it? Thanks a lot for any and all input!
    Re: Element Main Board CV318H-T Reverse Picture Problems
    i think this happen to me once, i think it was the wrong board many TVs will use the same board with different versions or different revisions, were you able to find another 1205h0911a? the different version maybe printed somewhere else or on a sticker
      sounds like a trip into the service menu,and go into config settings,normally the picture will be reverse at 180 degrees ,have you been playing around in the service menu...?,you also may need to re-configure the screen size settings
      fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
      please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
        If you get the picture fixed but the control buttons are still backwards, you can swap the wires. I once swapped the guts from a Polaroid into an Element and had the same control problem. I used my meter to determine which wire to swap VOL+ vs VOL-, pulled them out of the clip and reversed them. It worked fine after that. Even with the remote.
